Установка ASE 12.5
Ставлю rpm, даю права пользователю sybase на директорию куда все установленно ( /opt/sybase-12.5) c другой консоли захожу под юзером sybase делаю ./startd.sh /opt/sybase-12.5/SYSAM (файл лицензии лежит в папке licenses) Создаются 2 логфайла Содержимое lmgrd.log -------------- 21:30:41 (lmgrd) FLEXlm (v6.1g) started on localhost.localdomain (linux) (12/21/2004) 21:30:41 (lmgrd) FLEXlm Copyright 1988-1999, Globetrotter Software, Inc. 21:30:41 (lmgrd) US Patents 5,390,297 and 5,671,412. 21:30:41 (lmgrd) World Wide Web: http://www.globetrotter.com 21:30:41 (lmgrd) License file(s): /opt/sybase-12.5/SYSAM/licenses/license.dat 21:30:41 (lmgrd) lmgrd tcp-port 29722 21:30:41 (lmgrd) Starting vendor daemons ... 21:30:41 (SYBASE) FLEXlm version 6.1g 21:30:41 (lmgrd) Started SYBASE (internet tcp_port 36291 pid 6211) 21:30:41 (SYBASE) Server started on localhost.localdomain for: ASE_SBE 21:31:12 (SYBASE) Server started on localhost.localdomain for: ASE_SBE 21:31:12 (SYBASE) Updating feature ASE_SBE --------------- Далее делаю lmgr Получаю ----------------- bash-2.05b$ ./lmgr Starting Studio Installer in License mode... Can't load library "/opt/sybase-12.5/shared-1_0/jre-1.2.2/lib/i386/libjava.so", because /opt/sybase-12.5/shared-1_0/jre-1.2.2/lib/i386/libjava.so: symbol __libc_wait, version GLIBC_2.0 not defined in file libc.so.6 with link time reference Could not create the Java virtual machine. Forcing license daemon to re-read license file to pick up changes... lmutil - Copyright (C) 1989-1999 Globetrotter Software, Inc. lmreread successful ----------------- Все нужные библиотеки вроде стоят. ... |
| 21.12.2004, 21:37 |
Установка ASE 12.5
bash-2.05b$ bash-2.05b$ ./asecfg Incorrectly built binary which accesses errno or h_errno directly. Needs to be fixed. Error opening display :(null) Ensure that the $DISPLAY enviroment variable is set correctly bash-2.05b$ ./asecfg Incorrectly built binary which accesses errno or h_errno directly. Needs to be fixed. Error opening display :(null) Ensure that the $DISPLAY enviroment variable is set correctly bash: pwd: write error: Success ... |
| 21.12.2004, 22:12 |
Установка ASE 12.5
Недурственно было бы, если б Вы написали, что у Вас за система. Очевидно, используется некий linux, но какой? Ну а Error opening display :(null) это понятно DISPLAY='127.0.0.1:0.0';export DISPLAY надеюсь, что иксы работают. ... |
| 22.12.2004, 11:46 |
Установка ASE 12.5
Сорри Линух ASP Server II , сейчас попробовал сгенерировать лицензию на АСП 7.3 получилось А насчет совета про иксы, пасип, както не подумал :) просто на серваке нету иксов, вечером дома попробую. ... |
| 22.12.2004, 13:15 |
Установка ASE 12.5
Ну вроде запустил :) Делаю создать новый сервер Выбираю пути для maste и subsystem Нажимаю создать Building Adaptive Server 'test': Writing entry into directory services... Directory services entry complete. Building master device... Task failed 00:00000:00000:2004/12/22 19:42:07.11 kernel current process (0x60006) infected with 11 . . таких повторов около 500 метров . with 11 00:00000:00000:2004/12/22 19:42:07.12 kernel current prWriting RUN_adygtelecom file... RUN_adygtelecom file complete. Starting server... Task failed Unable to boot Adaptive Server 'adygtelecom' because the master device (/opt/sybase-12.5/DB/main.dat) does not exist. Server 'adygtelecom' was not created. Done ... |
| 22.12.2004, 20:06 |
Установка ASE 12.5
glibc онго хочет другой. У нас такое же было на альтах. И у других людей. Нам помогла замена glibc на 686 версию. Собсна здесь обсуждалось, заюзайте поиск ... |
| 23.12.2004, 10:13 |
Установка ASE 12.5
ТёмКаСтавлю rpm, даю права пользователю sybase на директорию куда все установленно ( /opt/sybase-12.5) c другой консоли захожу под юзером sybase делаю ./startd.sh /opt/sybase-12.5/SYSAM (файл лицензии лежит в папке licenses) Создаются 2 логфайла Содержимое lmgrd.log -------------- 21:30:41 (lmgrd) FLEXlm (v6.1g) started on localhost.localdomain (linux) (12/21/2004) 21:30:41 (lmgrd) FLEXlm Copyright 1988-1999, Globetrotter Software, Inc. 21:30:41 (lmgrd) US Patents 5,390,297 and 5,671,412. 21:30:41 (lmgrd) World Wide Web: http://www.globetrotter.com 21:30:41 (lmgrd) License file(s): /opt/sybase-12.5/SYSAM/licenses/license.dat 21:30:41 (lmgrd) lmgrd tcp-port 29722 21:30:41 (lmgrd) Starting vendor daemons ... 21:30:41 (SYBASE) FLEXlm version 6.1g 21:30:41 (lmgrd) Started SYBASE (internet tcp_port 36291 pid 6211) 21:30:41 (SYBASE) Server started on localhost.localdomain for: ASE_SBE 21:31:12 (SYBASE) Server started on localhost.localdomain for: ASE_SBE 21:31:12 (SYBASE) Updating feature ASE_SBE --------------- Далее делаю lmgr Получаю ----------------- bash-2.05b$ ./lmgr Starting Studio Installer in License mode... Can't load library "/opt/sybase-12.5/shared-1_0/jre-1.2.2/lib/i386/libjava.so", because /opt/sybase-12.5/shared-1_0/jre-1.2.2/lib/i386/libjava.so: symbol __libc_wait, version GLIBC_2.0 not defined in file libc.so.6 with link time reference Could not create the Java virtual machine. Forcing license daemon to re-read license file to pick up changes... lmutil - Copyright (C) 1989-1999 Globetrotter Software, Inc. lmreread successful ----------------- Все нужные библиотеки вроде стоят. Цитата с http://www.sybase.com/detail?id=1012824 : авторNOTE: With this evaluation copy of the Adaptive Server Enterprise the installation instructions will need to modified slightly. Please skip the step that starts the license daemon as the license daemon is not needed for an evaluation license. After the license key has been entered the following message will be displayed "Forcing daemon to re-read license". This will be followed by an error message indicating that the lmreread command failed. This is expected in this situation as the license daemon has not been started. ... |
| 28.12.2004, 15:30 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2013997]: |
153ms |
48ms |
| others: | 207ms |
| total: | 450ms |
