Sybase 12.53 установка Linux
Поможите кто может. Скачал Sybase 12.53 пытаюсь установить Linux ASP 7.3 Все попытки заканчиваются kernel Adaptive Server Enterprise Express Edition (Limits: 1 Engine, 2GB Memory, 5GB Disk space). kernel Using config area from primary master device. server Configuration Error: Configuration file, '/opt/sybase/GAS3.cfg', does not exist. kernel Warning: A configuration file was not specified and the default file '/opt/sybase/GAS3.cfg' does not exist. SQL Server creates the default file with the default configuration. kernel Warning: Using default file '/opt/sybase/GAS3.cfg' since a configuration file was not specified. Specify a configuration file name in the RUNSERVER file to avoid this message. kernel os_find_good_keyfile: Found shared memory segment: key 0xf6028331, id 0 kernel os_find_good_keyfile: If SQL Server using it is not running, remove it by hand kernel os_find_good_keyfile: Trying a different key kernel os_find_good_keyfile: Found shared memory segment: key 0xf6028332, id 229381 kernel os_find_good_keyfile: If SQL Server using it is not running, remove it by hand kernel os_find_good_keyfile: Trying a different key kernel Internal run-time model set for Linux - Native kernel Using 1024 file descriptors. kernel Adaptive Server Enterprise/12.5.3/EBF 12406 ESD#1/P/Linux Intel/Enterprise Linux/ase1253/1900/32-bit/OPT-Express-Edition/Mon Jan 24 22:11:33 2005 kernel Confidential property of Sybase, Inc. kernel Copyright 1987, 2005 kernel Sybase, Inc. All rights reserved. kernel Unpublished rights reserved under U.S. copyright laws. kernel kernel This software contains confidential and trade secret information of Sybase, kernel Inc. Use, duplication or disclosure of the software and documentation by kernel the U.S. Government is subject to restrictions set forth in a license kernel agreement between the Government and Sybase, Inc. or other written kernel agreement specifying the Government's rights to use the software and any kernel applicable FAR provisions, for example, FAR 52.227-19. kernel Sybase, Inc. One Sybase Drive, Dublin, CA 94568, USA kernel ASE booted on Linux release 2.6.9-ac12 version #6 SMP Wed Dec 1 13:53:48 MSK 2004. kernel Using '/opt/sybase/GAS3.cfg' for configuration information. kernel Logging ASE messages in file '/opt/sybase/ASE-12_5/install/GAS3.log'. kernel Platform TCP network is forced to IPv4-only. kernel SQL Server booted with TCP_NODELAY enabled. kernel SSL Plus v3.1.10 security modules loaded successfully. kernel Network and device connection limit is 1014. server Number of blocks left for proc headers: 3232. server Proc header memory allocated 1616 pages for each per engine cache server Size of the 2K memory pool: 8192 Kb server Memory allocated for the default data cache cachelet 1: 8192 Kb kernel Enabling (RT) Posix asynchronous disk I/O strategy. kernel Extended cache size '0' is invalid. Provide the appropriate size value. kernel Initializing virtual device 0, '/opt/sybase/data/master.dat' with dsync 'off'. kernel Virtual device 0 started using asynchronous i/o. kernel Worker Thread Manager is not enabled for use in SQL Server. kernel Either the config parameter 'use security services' is set to 0, or ASE does not support use of external security mechanisms on this platform. The Security Control Layer will not be initialized. No external security mechanisms will be supported. kernel Unix interval timer enabled for sysclk interrupts. kernel engine 0, os pid 1636 online Где мне руки править ... |
| 01.03.2005, 11:44 |
А проблема-то в чем ? Я чего-то ничего криминального не вижу пока. ... |
| 01.03.2005, 12:19 |
Говорит Building master device... Task failed Server 'GAS3' was not created dataserver: master device size for this server: 30.0 Mb dataserver: master database size for this server: 6.0 Mb dataserver: model database size for this server: 2.0 Mb The product configuration failed. И все на этом ... |
| 01.03.2005, 12:26 |
Может дело в версии Linux ASP 7.3 ? ... |
| 01.03.2005, 12:54 |
Есть 3 компа ядра 2.4.18 2.4.27 2.6.9 пробовал с glibc-2.2.5-37asp.i386 glibc-2.2.5-37asp.i686 glibc-2.2.5-44asp.i386 glibc-2.2.5-44asp.i686 результат одинаковый. Где собака порылась. ... |
| 01.03.2005, 13:56 |
kOmЕсть 3 компа ядра 2.4.18 2.4.27 2.6.9 пробовал с glibc-2.2.5-37asp.i386 glibc-2.2.5-37asp.i686 glibc-2.2.5-44asp.i386 glibc-2.2.5-44asp.i686 результат одинаковый. Где собака порылась. хм, у меня такая засада была как раз с glibc-...-i386, поставив i686 все заработало..., правда ASE 12.5.1, и RH 7.3... ... |
| 01.03.2005, 14:08 |
kOmЕсть 3 компа ядра 2.4.18 2.4.27 2.6.9 пробовал с glibc-2.2.5-37asp.i386 glibc-2.2.5-37asp.i686 glibc-2.2.5-44asp.i386 glibc-2.2.5-44asp.i686 результат одинаковый. Где собака порылась. А что ASP сертифицирован Сайбэйзом? Ставьте на редхат или Суси и пререквизиты по пакаджам посмотреть надо, что ему собаке надо прям по списку чего хочет а что есть. ... |
| 01.03.2005, 17:26 |
Ну чего ему не хватает. Примерно можно сказать по логам? Доставить всегда можно. Linux он и в африке linux. Неужели все так печально. ... |
| 02.03.2005, 08:22 |
Я ставил ASE12.52Express на Linux Whitebox Resine1. Проблем особых не было. Если не ошибаюсь - это сброка RedHat Enterprise Server. ... |
| 02.03.2005, 15:00 |
Anatoly KЯ ставил ASE12.52Express на Linux Whitebox Resine1. Проблем особых не было. Если не ошибаюсь - это сброка RedHat Enterprise Server. Ну так собственно и Экспресс не совсем то же что ASE ... |
| 02.03.2005, 15:51 |
у меня на woody 12.5.2 не вставала с libc6 2.2.5-11.5 зато на sarge c libc6 2.3.2.ds1-20 без проблем. попробуй библиотеку поставить по новее. ... |
| 02.03.2005, 22:24 |
Приведите полное содержимое файлов: Код: plaintext 1. ... |
| 03.03.2005, 10:19 |
GAS3.log 00:00000:00000:2005/03/02 17:25:28.71 kernel Checked out license ASE_DEV 00:00000:00000:2005/03/02 17:25:28.71 kernel Adaptive Server Enterprise Developer Edition. 00:00000:00000:2005/03/02 17:25:28.87 kernel Using config area from primary master device. 00:00000:00000:2005/03/02 17:25:28.87 server Configuration Error: Configuration file, '/opt/sybase/GAS3.cfg', does not exist. 00:00000:00000:2005/03/02 17:25:28.87 kernel Warning: A configuration file was not specified and the default file '/opt/sybase/GAS3.cfg' does not exist. SQL Server creates the default file with the default configuration. 00:00000:00000:2005/03/02 17:25:28.91 kernel Warning: Using default file '/opt/sybase/GAS3.cfg' since a configuration file was not specified. Specify a configuration file name in the RUNSERVER file to avoid this message. 00:00000:00000:2005/03/02 17:25:28.93 kernel Internal run-time model set for Linux - Native 00:00000:00000:2005/03/02 17:25:28.93 kernel Using 1024 file descriptors. 00:00000:00000:2005/03/02 17:25:28.94 kernel Adaptive Server Enterprise/12.5.2/EBF 11949 ESD#1/P/Linux Intel/Enterprise Linux/ase1252/1838/32-bit/OPT/Sat May 29 01:03:02 2004 00:00000:00000:2005/03/02 17:25:28.94 kernel Confidential property of Sybase, Inc. 00:00000:00000:2005/03/02 17:25:28.94 kernel Copyright 1987, 2004 00:00000:00000:2005/03/02 17:25:28.94 kernel Sybase, Inc. All rights reserved. 00:00000:00000:2005/03/02 17:25:28.94 kernel Unpublished rights reserved under U.S. copyright laws. 00:00000:00000:2005/03/02 17:25:28.94 kernel 00:00000:00000:2005/03/02 17:25:28.94 kernel This software contains confidential and trade secret information of Sybase, 00:00000:00000:2005/03/02 17:25:28.94 kernel Inc. Use, duplication or disclosure of the software and documentation by 00:00000:00000:2005/03/02 17:25:28.94 kernel the U.S. Government is subject to restrictions set forth in a license 00:00000:00000:2005/03/02 17:25:28.94 kernel agreement between the Government and Sybase, Inc. or other written 00:00000:00000:2005/03/02 17:25:28.94 kernel agreement specifying the Government's rights to use the software and any 00:00000:00000:2005/03/02 17:25:28.94 kernel applicable FAR provisions, for example, FAR 52.227-19. 00:00000:00000:2005/03/02 17:25:28.94 kernel Sybase, Inc. One Sybase Drive, Dublin, CA 94568, USA 00:00000:00000:2005/03/02 17:25:28.94 kernel ASE booted on Linux release 2.6.9-ac12 version #6 SMP Wed Dec 1 13:53:48 MSK 2004. 00:00000:00000:2005/03/02 17:25:28.94 kernel Using '/opt/sybase/GAS3.cfg' for configuration information. 00:00000:00000:2005/03/02 17:25:28.94 kernel Logging ASE messages in file '/opt/sybase/ASE-12_5/install/GAS3.log'. 00:00000:00000:2005/03/02 17:25:28.99 kernel Platform TCP network is forced to IPv4-only. 00:00000:00000:2005/03/02 17:25:28.99 kernel SQL Server booted with TCP_NODELAY enabled. 00:00000:00000:2005/03/02 17:25:28.99 kernel SSL Plus v3.0.8 security modules loaded successfully. 00:00000:00000:2005/03/02 17:25:28.99 kernel Network and device connection limit is 1014. 00:00000:00000:2005/03/02 17:25:29.07 server Number of blocks left for proc headers: 3232. 00:00000:00000:2005/03/02 17:25:29.07 server Proc header memory allocated 1616 pages for each per engine cache 00:00000:00000:2005/03/02 17:25:29.09 server Size of the 2K memory pool: 8192 Kb 00:00000:00000:2005/03/02 17:25:29.09 server Memory allocated for the default data cache cachelet 1: 8192 Kb 00:00000:00000:2005/03/02 17:25:29.09 kernel Extended cache size '0' is invalid. Provide the appropriate size value. 00:00000:00000:2005/03/02 17:25:29.13 kernel Enabling (RT) Posix asynchronous disk I/O strategy. 00:00000:00000:2005/03/02 17:25:29.13 kernel Initializing virtual device 0, '/opt/sybase/data/master.dat' with dsync 'off'. 00:00000:00000:2005/03/02 17:25:29.13 kernel Virtual device 0 started using asynchronous i/o. 00:00000:00000:2005/03/02 17:25:29.13 kernel Worker Thread Manager is not enabled for use in SQL Server. 00:00000:00000:2005/03/02 17:25:29.13 kernel Either the config parameter 'use security services' is set to 0, or ASE does not support use of external security mechanisms on this platform. The Security Control Layer will not be initialized. No external security mechanisms will be supported. 00:00000:00000:2005/03/02 17:25:29.13 kernel Unix interval timer enabled for sysclk interrupts. 00:00000:00000:2005/03/02 17:25:29.18 kernel engine 0, os pid 6639 online GAS3.cfg все DEFAULT Я с Sybase дело не имел. Наверное ошибаюсь. Но прежде настраивать надо установить ? или нет. ... |
| 03.03.2005, 10:42 |
kOmНо прежде настраивать надо установить ? или нет. Правильно ли я понимаю, что вы не *установили* Sybase как положено, а просто пытаетесь запустить бинарные файлы? ... |
| 03.03.2005, 11:03 |
Я запускаю setup, а он ругается ... |
| 03.03.2005, 11:40 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2013824]: |
170ms |
67ms |
| others: | 205ms |
| total: | 492ms |
