BCP ошибка Msg 7751
При запуски bcp на Adaptive Server Enterprise/12.0.0.4 под Solaris строкой bcp.12 TABLECONFIG in TABLECONFIG.bcp -c -E -Uuser -P*** возникают ошибки: Server Message: - Msg 7751, Level 16, State 1: Unable to SET IDENTITY_INSERT to ON/OFF for table 'TABLECONFIG' because the object either does not exist or cannot be opened. CTLIB Message: - L1/O1/S1/N183/1/0: ct_options(): user api layer: external error: An error was returned from the ser ver while setting the options, check the server message for details. Setting connection options failed. Помогите разобраться в чем дело... ... |
| 17.03.2005, 17:30 |
BCP ошибка Msg 7751
The information about the set commands is only valid for the current session. To correct the problem the user who did the set identity_insert on for the subsequently dropped table needs to log out of the server and then log in again. The information about the set command on the dropped table is lost after logging off the server. The error 7747 arises when an attempt is made to set identity_insert on for a table when another table in the database already has this function set. Set identity_insert on can only be done on one table per database at any given time. ... |
| 28.03.2005, 16:05 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2013757]: |
422ms |
23ms |
| others: | 246ms |
| total: | 744ms |
