32-bit & 4+ Gb
При поиске инфы по 64-битным процессорам попалась информация о Sybase ASE под Linux на странице http://www.sybase.com/detail?id=1030009 Заинтересовала фраза "On Windows, Address Windowing Extensions (AWE) provide such an API. However, Linux provides a window of virtual address space that keeps moving over a shared memory file system, allowing 32-bit applications to address more than 4GB of memory. With ASE 12.5.2, DBAs can now configure up to 64GB of memory for data caches on a 32-bit Linux platform .With this feature, customers can now deploy large enterprise - class databases on the 32-bit Intel/Linux platform, achieving higher scalability and performance while maintaining a low TCO, characteristics that have been the hallmark of Sybase ASE." Никто не пробовал это в действии ? Евгений ... |
| 01.04.2005, 16:17 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2013742]: |
155ms |
28ms |
| others: | 251ms |
| total: | 480ms |
