Восстановление БД ASE 11.9.2.6
Добрый день! При перезапуске сервера база не восстановилась. Сообщение в логе: Recovering database 'namedb'. 00:00000:00001:2005/08/31 13:47:58.68 server Redo pass of recovery has processed 4 committed and 0 aborted transactions. 00:00000:00001:2005/08/31 13:48:03.15 server Error: 7411, Severity: 21, State: 1 00:00000:00001:2005/08/31 13:48:03.15 server Table 'systhresholds' in database 'namedb' is not in its correct sort order. Either the clustered index is missing or there is data corruption in the table. 00:00000:00001:2005/08/31 13:48:03.17 server Error: 3414, Severity: 21, State: 1 00:00000:00001:2005/08/31 13:48:03.17 server Database 'namedb' (dbid 9): Recovery failed. Check the SQL Server errorlog for further information as to the cause. 00:00000:00001:2005/08/31 13:48:03.18 server Recovery complete. Каким образом можно приконнектиться к базе и восстановить Table 'systhresholds'? ... |
| 31.08.2005, 16:04 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2013424]: |
154ms |
45ms |
| others: | 232ms |
| total: | 478ms |
