ASE stack traces
Adaptive Server Enterprise/12.5.1/EBF 11665 ESD#2/P/NT (IX86)/OS 4.0/ase1251/1838/32-bit/OPT/Fri Feb 20 04:11:31 2004 Периодически в логе появляется следующее : 00:00000:00052:2005/12/09 16:19:22.85 server Error: 11068, Severity: 20, State: 1 00:00000:00052:2005/12/09 16:19:22.85 server Transaction was found in the incorrect state of 'Command-attached'. The expected state was 'Done command-attached'. 00:00000:00052:2005/12/09 16:19:22.85 server Error: 11068, Severity: 20, State: 1 00:00000:00052:2005/12/09 16:19:22.85 server Transaction was found in the incorrect state of 'Command-attached'. The expected state was 'Done command-attached'. 00:00000:00052:2005/12/09 16:19:22.85 kernel ************************************ 00:00000:00052:2005/12/09 16:19:22.85 kernel SQL causing error : execute dbo.usp_good_place_date;1 @GOOD_ID = 34862.00000000000000, @CURRENT_DATE = '12-9-2005 15:12:44.000' 00:00000:00052:2005/12/09 16:19:22.85 kernel ************************************ 00:00000:00052:2005/12/09 16:19:22.85 server SQL Text: execute dbo.usp_good_place_date;1 @GOOD_ID = 34862.00000000000000, @CURRENT_DATE = '12-9-2005 15:12:44.000' Причем Error: 11068 возникает при выполнении абсолютно различных процедур и запросов (я закономерности не выявил). После перезапуска сервера некоторое время (несколько дней) ошибок нет, потом появляюся опять... Может, кто нибудь сталкивался с подобным ?? ... |
| 11.12.2005, 16:23 |
ASE stack traces
вот что говорит Sybase про это: "Getting stacktrace when query is running in parallel or dynamic sql is used. Error: 11068, Severity: 20, State: 1 Transaction was found in the incorrect state of 'Command-attached'. The expected state was 'Done command-attached'. Also is there another way to determine how much the number of sort buffers parameter should be increased? Key Words: stacktrace Tip or Workaround CR 380801- XACTMGR: parallel query hits error 11068 (transaction in incorrect state) The error 11068, "Transaction was found in the incorrect state of 'Command-attached'." will be raised if a parallel select into fails due to lack of memory. Workaround: Take action to avoid the error preceding error 11068: for error 701, increase the procedure cache (and/or decrease the number of sort buffers). Fixed: 12.5.3 ESD3 Resolution CR 380801- XACTMGR: parallel query hits error 11068 (transaction in incorrect state). Upgrade to ASE 12.5.3 ESD3. " вердикт прост - Upgrade to ASE 12.5.3 ESD3. ;) Для начала предложил бы подняться до 12.5.2 ESD2 - более-менее стабильный :) ... |
| 11.12.2005, 16:50 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2013200]: |
168ms |
27ms |
| others: | 208ms |
| total: | 446ms |
