Переход ASE с 12.5.0 на 12.5.3
Пытаюсь поднять базу на новой версии ASE. После поднятия master из дампа сервер валиться. 00:00000:00000:2006/03/16 17:43:15.65 kernel Checked out license ASE_SBE 00:00000:00000:2006/03/16 17:43:15.65 kernel Adaptive Server Small Business Edition 00:00000:00000:2006/03/16 17:43:15.65 kernel Using config area from primary master device. 00:00000:00000:2006/03/16 17:43:15.66 kernel Internal run-time model set for Linux - Native 00:00000:00000:2006/03/16 17:43:15.66 kernel Using 1024 file descriptors. 00:00000:00000:2006/03/16 17:43:15.66 kernel Adaptive Server Enterprise/12.5.3/EBF 13204 ESD#6/P/Linux Intel/Enterprise Linux/ase1253/1945/32-bit/OPT/Thu Jan 19 22:46:02 2006 00:00000:00000:2006/03/16 17:43:15.66 kernel Confidential property of Sybase, Inc. 00:00000:00000:2006/03/16 17:43:15.66 kernel Copyright 1987, 2006 00:00000:00000:2006/03/16 17:43:15.66 kernel Sybase, Inc. All rights reserved. 00:00000:00000:2006/03/16 17:43:15.66 kernel Unpublished rights reserved under U.S. copyright laws. 00:00000:00000:2006/03/16 17:43:15.66 kernel 00:00000:00000:2006/03/16 17:43:15.66 kernel This software contains confidential and trade secret information of Sybase, 00:00000:00000:2006/03/16 17:43:15.66 kernel Inc. Use, duplication or disclosure of the software and documentation by 00:00000:00000:2006/03/16 17:43:15.66 kernel the U.S. Government is subject to restrictions set forth in a license 00:00000:00000:2006/03/16 17:43:15.66 kernel agreement between the Government and Sybase, Inc. or other written 00:00000:00000:2006/03/16 17:43:15.66 kernel agreement specifying the Government's rights to use the software and any 00:00000:00000:2006/03/16 17:43:15.66 kernel applicable FAR provisions, for example, FAR 52.227-19. 00:00000:00000:2006/03/16 17:43:15.66 kernel Sybase, Inc. One Sybase Drive, Dublin, CA 94568, USA 00:00000:00000:2006/03/16 17:43:15.66 kernel ASE booted on Linux release 2.6.9-34.ELhugemem version #1 SMP Wed Mar 8 00:47:12 CST 2006. 00:00000:00000:2006/03/16 17:43:15.66 kernel Using '/opt/sybase/ASE-12_5/ipsoft.cfg' for configuration information. 00:00000:00000:2006/03/16 17:43:15.66 kernel Logging ASE messages in file '/var/log/sybase/ipsoft.log'. 00:00000:00000:2006/03/16 17:43:15.66 kernel SQL Server booted with TCP_NODELAY enabled. 00:00000:00000:2006/03/16 17:43:15.67 kernel SSL Plus v3.1.14 security modules loaded successfully. 00:00000:00000:2006/03/16 17:43:15.67 kernel Network and device connection limit is 1014. 00:00000:00000:2006/03/16 17:43:15.74 server Number of blocks left for proc headers: 3232. 00:00000:00000:2006/03/16 17:43:15.74 server Proc header memory allocated 1616 pages for each per engine cache 00:00000:00000:2006/03/16 17:43:15.76 server Size of the 2K memory pool: 8192 Kb 00:00000:00000:2006/03/16 17:43:15.76 server Memory allocated for the default data cache cachelet 1: 8192 Kb 00:00000:00000:2006/03/16 17:43:15.76 kernel Enabling Linux Kernel asynchronous disk I/O strategy. 00:00000:00000:2006/03/16 17:43:15.76 kernel Initializing virtual device 0, '/opt/sybase/SystemDevice/master.dat' with dsync 'on'. 00:00000:00000:2006/03/16 17:43:15.76 kernel Virtual device 0 started using asynchronous i/o. 00:00000:00000:2006/03/16 17:43:15.76 kernel Worker Thread Manager is not enabled for use in SQL Server. 00:00000:00000:2006/03/16 17:43:15.76 kernel Either the config parameter 'use security services' is set to 0, or ASE does not support use of external security mechanisms on this platform. The Security Control Layer will not be initialized. No external security mechanisms will be supported. 00:00000:00000:2006/03/16 17:43:15.76 kernel Unix interval timer enabled for sysclk interrupts. 00:00000:00000:2006/03/16 17:43:15.77 kernel engine 0, os pid 10929 online 00:00000:00000:2006/03/16 17:43:15.77 server No active traceflags 00:00000:00001:2006/03/16 17:43:15.77 kernel libomni1 - Component Integration Services loaded; version 'libomni1 - Component Integration Services/12.5.3/EBF 13204 ESD#6/P/Linux Intel/Enterprise Linux/ase1253/1945/32-bit/OPT/Thu Jan 19 22:46:02 2006'. 00:00000:00001:2006/03/16 17:43:15.77 kernel libomni1 - Component Integration Services: using 'Sybase Client-Library/12.5.1/P-EBF12823 ESD #10/DRV.12.5.1.4/Linux Intel/Linux 2.4.18-18.7.xsmp i686/BUILD1251-043/OPT/Wed Aug 10 19:53:54 2005' 00:00000:00001:2006/03/16 17:43:15.77 server Opening Master Database ... 00:00000:00001:2006/03/16 17:43:15.77 server Loading SQL Server's default sort order and character set 00:00000:00001:2006/03/16 17:43:15.78 server Error: 7114, Severity: 22, State: 1 00:00000:00001:2006/03/16 17:43:15.78 server Page 2031 is not a valid text page. 00:00000:00001:2006/03/16 17:43:15.78 kernel ************************************ 00:00000:00001:2006/03/16 17:43:15.78 kernel curdb = 1 tempdb = 0 pstat = 0x0 00:00000:00001:2006/03/16 17:43:15.78 kernel lasterror = 7114 preverror = 0 transtate = 1 00:00000:00001:2006/03/16 17:43:15.78 kernel curcmd = 0 program = 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x880b5f5 ucbacktrace+0x89(0x0,0x1,0x93783f4,0x16,0xe) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x81b4229 terminate_process+0xb21(0x0,0xffffffff,0x93783f4,0xf4b0a5ec,0x820d7bd) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x820d5d1 close_network+0x19(0x93783f4,0xf4b0a684,0xf4b0a638,0x8309a22,0x47) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x820d7bd hdl_default+0x49(0x47,0xe,0x16,0x1,0xf4b0a684) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x8309a22 text_handler+0x3a(0x47,0xe,0x16,0x1,0xf4b0a684) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x820d224 ex_raise+0x2f8(0x47,0xe,0x16,0x1,0x7ef) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x82f719f gettxtpage+0x2bf(0xf4b0a888,0xf51abedc,0x7ef,0x93783f4,0xf4b0a858) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x830697e txt_open+0x2de(0xf4b0a858,0x93783f4,0x9415b60,0xf4b0b796,0x0) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x81b58d0 ld_sort_char+0x4e8(0x0,0x0,0x0,0x0,0x0) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x824632b ex_cleanup(0x0,0xf4b0b958,0x895eed31,0x0,0x0) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x884d0a4 kpexit(0x0,0x0,0x0,0xf4acb900,0x4) 00:00000:00001:2006/03/16 17:43:15.78 kernel pc 0x895eed31 init_dummy+0x8094c991(0x0,0xf4acb900,0x4,0x1,0x5374616b) 00:00000:00001:2006/03/16 17:43:15.78 kernel end of stack trace, spid 1, kpid 196611, suid 0 ... |
| 16.03.2006, 19:45 |
Может база битая была еще в 12.5.0. А так - стектрейсы только Sybase разбирает. Им слать надо. Но базу на 12.5.0 я бы почекал. ... |
| 16.03.2006, 20:01 |
да нет. Если поднимаю базу из этого дампа на 12.5.0 то все нормально. ... |
| 17.03.2006, 09:48 |
У меня падала БД на text, когда переходил с 11.9.2 на 12.5.2 Помогло вот это http://]http://www.sybase.com/detail?id=1012153 ... |
| 17.03.2006, 09:54 |
Поставил 12.5.2 тоже самое. После заливки дампа тоже ошибка 7114. Master - чекал вроде все нормально. Может с ключами надо? Ткните носом тогда. ... |
| 20.03.2006, 11:41 |
ВигвамПоставил 12.5.2 тоже самое. После заливки дампа тоже ошибка 7114. Master - чекал вроде все нормально. Может с ключами надо? Ткните носом тогда. скажи на милость - что ты делаешь то? "После поднятия master из дампа сервер валиться." - для чего мастер из дампа поднимать? ты у сервера версию поднимаешь? или на 12.5.3 пытаешься пользовательскую бд с 12.5-го поднять? ... |
| 21.03.2006, 10:40 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2012966]: |
169ms |
40ms |
| others: | 193ms |
| total: | 449ms |
