перенос базы с Intel на OpenPower
АSE 12.5.3 на intel и openpower. Ситуация такая: есть база на интеловской машине. Надо перенести базу на систему openpower. при загрузке базы (load database): Backup Server: 4.58.1.1: Database sbase: 11805636 kilobytes LOADed. Backup Server: 4.58.1.1: Database sbase: 11805644 kilobytes LOADed. Backup Server: 3.42.1.1: LOAD is complete (database sirena). Started cross-platform conversion for database sirena. Started cross-platform conversion for system objects. Cross-platform conversion for database sbase: 10000 pages completed. Cross-platform conversion for database sbase: 20000 pages completed. Cross-platform conversion for database sbase: 24211 pages completed. Completed cross-platform conversion for system objects. Started cross-platform conversion for user objects. Cross-platform conversion for database sbase: 59178 pages completed. ... Cross-platform conversion for database sbase: 5873878 pages completed. Completed cross-platform conversion for user objects. Started cross-platform conversion for log records. ... Use the ONLINE DATABASE command to bring this database online; SQL Server will not bring it online automatically. все вроде бы нормально. но при попытке перевести базу в режим online: Database 'sbase' appears to be at an older revision than the present installation; SQL Server will assess it, and upgrade it as required. Database 'sbase': beginning upgrade step [ID 1302]: Upgrade SARGs in SYSINDEXES to 2-byte column IDs. Database 'sirena': beginning upgrade step [ID 1017]: adding column (table syscolumns, column remote_type) ... Database 'sbase': beginning upgrade step [ID 1307]: executing SQL statement (if not exists (select 1 from syscol) Msg 247, Level 16, State 1: Server 'OP', Line 1: Arithmetic overflow during explicit conversion of INT value '16777216' to a TINYINT field . Msg 906, Level 23, State 1: Server 'OP', Line 1: Could not locate row in sysobjects for system catalog 1 in database 4. This system catalog should exist in all databases. Run DBCC CHECKTABLE on sysindexes in the database. The SQL Server is terminating this process. Arithmetic overflow occurred. и все. OP - sql сервер. при попытке подключения к базе пишет: the database sbase was either created For Load or is marked as suspect or offline. it cannot be opened. Вопрос! - как ее заонлайнить? может кто встречался с такой проблемой! зы: чекпоинт базы не делал. возможности зделать чекпоинт постоянно нет, потмоу как база загружена очень сильно. может причина как раз в этом, что не был сделан чекпоинт базы? хотя такое было, но тогда база вообще не загружалась, а здесь вылазит ошибка уже после загрузки, перед онлайном базы. выручите?! ... |
| 19.06.2006, 13:19 |
duhas Вопрос! - как ее заонлайнить? может кто встречался с такой проблемой! зы: чекпоинт базы не делал. возможности зделать чекпоинт постоянно нет, потмоу как база загружена очень сильно. может причина как раз в этом, что не был сделан чекпоинт базы? хотя такое было, но тогда база вообще не загружалась, а здесь вылазит ошибка уже после загрузки, перед онлайном базы. выручите?! были ли проделаны все рекомендованные документацией шаги? Source: http://docs.sybase.com/onlinebooks/group-as/asg1253e/newfeatures1253_rev/@Generic__BookTextView/731;pt=2333?DwebQuery=sp_flushstats&DwebSearchAll=1#X http://docs.sybase.com/onlinebooks/group-as/asg1253e/newfeatures1253_rev/@Generic__BookTextView/2333;nh=1;pt=2333;uf=0?DwebQuery=sp_flushstats&DwebSearchAll=1#X ... |
| 19.06.2006, 13:42 |
1> sp_flushstats 2> go Msg 2812, Level 16, State 4: Server 'MAIN', Line 1: Stored procedure 'sp_flushstats' not found. Specify owner.objectname or use sp_help to check whether the object exists (sp_help may produce lots of output). Сервер майн стоит на интеловской патформе. ... |
| 20.06.2006, 05:58 |
duhas1> sp_flushstats 2> go Msg 2812, Level 16, State 4: Server 'MAIN', Line 1: Stored procedure 'sp_flushstats' not found. Specify owner.objectname or use sp_help to check whether the object exists (sp_help may produce lots of output). Сервер майн стоит на интеловской патформе. select @@version ? ... |
| 20.06.2006, 11:05 |
на интеле версия: Site 'SQL Server/11.0.2/P/SCO/SCO_SV r3' на openpower'е: Adaptive Server Enterprise/12.5.3/Linux/ase1253/ задача: перенести с 11.0.2 sco интела на 12.5.3 linux openpower. пока получалось делать через промежуточный этап при помощи ase 12.5.3 linux на интеловской платформе. есть ли возможность перенести/поднять версию на openpower без промежуточного этапа??? ... |
| 22.06.2006, 05:45 |
p.s. sp_flushstats на sco 11.0.2 не работает. не знает sql такой команды, потому и приходится делать промежуточный этап. а без этой процедуры база не загружается и не встает в онлайн. ... |
| 22.06.2006, 05:48 |
duhasна интеле версия: Site 'SQL Server/11.0.2/P/SCO/SCO_SV r3' на openpower'е: Adaptive Server Enterprise/12.5.3/Linux/ase1253/ задача: перенести с 11.0.2 sco интела на 12.5.3 linux openpower. пока получалось делать через промежуточный этап при помощи ase 12.5.3 linux на интеловской платформе. есть ли возможность перенести/поднять версию на openpower без промежуточного этапа??? оп-па, вот это рокировка ;) кхм, кроссплатформенные дампы возможны только с версии 12.5.3 (если память не изменяет) а вы хотите аж с 11-ой ;) надо сначала на одной платформе подняться до 12.5.3, а уж потом переносить дамп на другую платформу или пойти другим путем - переливка базы вручную ... |
| 22.06.2006, 10:29 |
duhasp.s. sp_flushstats на sco 11.0.2 не работает. не знает sql такой команды, потому и приходится делать промежуточный этап. а без этой процедуры база не загружается и не встает в онлайн. и в чем то он прав, что не знает ;) ... |
| 22.06.2006, 10:30 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2012766]: |
204ms |
36ms |
| others: | 206ms |
| total: | 489ms |
