PHP(FreeBSD) - Sybase(ASP Linux)
всем привет! помогите реализовать связку: PHP(FreeBSD) - Sybase(ASP Linux) ... |
| 12.02.2004, 07:19 |
rm -R /usr/local/* tar xvzf termcap-1.3.1.tar.gz cd termcap-1.3.1 ./configure make make install cd ../ tar xvzf mysql-5.0.18.tar.gz cd mysql-5.0.18 make clean ./configure --prefix=/usr/local/mysql --sysconfdir=/usr/local/etc --with-mysqld-user=mysql --with-unix-socket-path=/tmp/mysql.sock make make install mkdir /usr/local/mysql/var /usr/local/mysql/bin/mysql_install_db useradd -p /usr/local/mysql -s /bin/false mysql groupadd mysql chown mysql:mysql /usr/local/mysql/var cd ../ rm -R mysql-5.0.18 tar xvzf apache_1.3.36.tar.gz cd apache_1.3.36 ./make clean ./configure #make #make install cd ../ rm -R apache_1.3.36 tar xvzf php-4.4.2.tar.gz cd php-4.4.2 make clean ./configure --prefix=/usr/local --with-apache=../apache_1.3.36 --with-mysql=/usr/local/mysql --with-gd --with-zlib-dir=/usr/bin/zip --enable-sigchild --disable-zend-memory-manager --with-config-file-path=/usr/local/etc --with-zlib-dir=/usr/bin/zip make make install cd ../ rm -R php-4.4.2 cd apache_1.3.36 ./configure --prefix=/usr/local/httpd --activate-module=src/modules/php4/libphp4.a --enable-module=rewrite --enable-shared=rewrite --enable-shared=max make make install cd ../ rm -R apache_1.3.36 echo "AddType application/x-httpd-php .php NameVirtualHost *:80 include /srv/www/vhosts.conf/*.conf DirectoryIndex index.php index.html index.htm" >> /usr/local/httpd/conf/httpd.conf #/usr/local/apache/bin/apachectl start ... |
| 18.07.2006, 10:28 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2012720]: |
177ms |
30ms |
| others: | 250ms |
| total: | 507ms |
