Проблемы с запуском репсервера
имею ASE 12.0, RS 12.0 все на Win2000AS жил был сервер и все работало остановили службы и выключили машину, перенесли в другую комнату и загрузили, служба SQL сервера стартанула без проблем... в логе ошибок нет - все как обычно, служба реп сервера после некоторого времени переходит в состояние starting, если запускать через батник история такая же лог RS I. 2006/07/21 10:50:17. 'Replication Server/12.0/P/PC Intel/Windows NT 4.0/1/OPT/Fri Dec 10 16:47:21 PST 1999' I. 2006/07/21 10:50:17. 'Confidential property of Sybase, Inc. (c) Copyright 1992, 1999 Sybase Inc. All rights reserved. Unpublished rights reserved under U.S. copyright laws. This software contains confidential and trade secret information of Sybase, Inc. Use, duplication, or disclosure of the software and documentation by the U.S. Government is subject to restrictions set forth in a license agreement between the Government and Sybase, Inc. or other written agreement specifying the Government's rights to use the software and any applicable FAR provisions, for example, FAR 52.227-19. Sybase, Inc. 6475 Christie Avenue, Emeryville, CA 94608, USA.' I. 2006/07/21 10:50:17. Logging messages in file 'C:\sybase\logs\cserv_rs.log'. I. 2006/07/21 10:50:17. Using interfaces file 'c:\sybase\ini\sql.ini'. I. 2006/07/21 10:50:17. Server name is 'cshop_rs'. I. 2006/07/21 10:50:17. Reading 'C:\sybase\REP-12_0\install\cshop_rs.cfg' for configuration information. I. 2006/07/21 10:50:17. Using config file encrypted password for the RSSD primary user. I. 2006/07/21 10:50:17. Using config file encrypted maintenance password for the RSSD maint user. I. 2006/07/21 10:50:17. Using config file encrypted password for the ID user. I. 2006/07/21 10:50:17. Using the 'cp1251' character set. I. 2006/07/21 10:50:17. Using the 'us_english' language. I. 2006/07/21 10:50:17. Using the 'nocase' sort order. I. 2006/07/21 10:50:17. Using server 'hold_rs' for an ID Server. I. 2006/07/21 10:50:17. Using config file password for the ID user. I. 2006/07/21 10:50:17. Using user 'us_rs_rsi' for the ID Server. I. 2006/07/21 10:50:17. Using config file maintenance password for the RSSD maint user. I. 2006/07/21 10:50:17. RSSD maintenace user is 'maint'. I. 2006/07/21 10:50:17. Using config file password for the RSSD primary user. I. 2006/07/21 10:50:17. RSSD primary user is 'prim'. I. 2006/07/21 10:50:17. RSSD database is 'RSSD'. I. 2006/07/21 10:50:17. RSSD server is 'cshop'. I. 2006/07/21 10:50:17. Reading 'cserv.RSSD..rs_config' for system configuration parameters. I. 2006/07/21 10:50:17. Value of the 'memory_limit' config parameter is: 20 megabytes. I. 2006/07/21 10:50:17. Maximum outbound connections allowed: 64. I. 2006/07/21 10:50:17. System outbound connection fadeout time: '30'. I. 2006/07/21 10:50:17. System table cache size: 100 rows. I. 2006/07/21 10:50:17. Maximum number of Open Server threads allowed: 50. I. 2006/07/21 10:50:17. Maximum number of Open Server mutexes allowed: 128. I. 2006/07/21 10:50:17. Maximum number of incoming client connections allowed: 30. I. 2006/07/21 10:50:17. Maximum number of Open Server message queues allowed: 178. I. 2006/07/21 10:50:17. Maximum number of Open Server messages allowed: 45568. I. 2006/07/21 10:50:17. Maximum number of stable queues allowed: 32. I. 2006/07/21 10:50:17. Password encryption option: 1. I. 2006/07/21 10:50:17. Default for connection ha_failover is set to 'off', I. 2006/07/21 10:50:17. System configuration complete. I. 2006/07/21 10:50:17. Server using Open Server version Sybase Server-Library/12.0/P-EBF9216/PC Intel/1/OPT/Tue Aug 08 14:07:16 2000 I. 2006/07/21 10:50:17. Server using Open Client version Sybase Client-Library/12.0/P-EBF9216/PC Intel/1/OPT/Tue Aug 08 14:07:16 2000 W. 2006/07/21 10:50:17. WARNING #13061 GLOBAL RS(GLOBAL RS) - eue(4427) Server cshop is using 'rusnocs_cp1251' sort order, which is different from this Replication Server's sort order. в таком сотоянии провисел всю ночь и не родил никаких ошибок... где ковырять??? Спасибо огромное заранее... :( ... |
| 21.07.2006, 10:42 |
Разобрался, был переполнен лог RSSD СТРАННО, Централ дизинформировал... какие мысли почему централ меня обманул???? ... |
| 21.07.2006, 11:14 |
Полсле очистки лога, централ показывает отрицательный лог..., хотя например инфа при чекдб нормальная ... |
| 21.07.2006, 11:17 |
централ показывает, только то что ему отадает в result_set ASE. Да ASE может информировать об отрициательном месте в логе. Для того чтобы это исправить Для того чтобы правильно считал запустите dbcc tablealloc (syslogs, full, fix) Правда, т.к. таблица системная, то для fix надо чтобы она запускалась single user mode. Также есть флажок 7408 Force the server to scan *log segment* allocation pages; to recalculate free log space rather than use saved counts. Или же dbcc dbrepair(dbname, fixlogfreespace) Recalculate free space for transactionlog ... |
| 21.07.2006, 12:03 |
dbcc tablealloc (syslogs, full, fix) - результата не дало dbcc dbrepair(dbname, fixlogfreespace) - 14:29:06.478 DBMS cserv -- Error: Number (10333) Severity (14) State (1) Server (cserv) Incorrect DBCC command: Please see the Commands Reference Manual for DBCC commands and options. как применить флажок....??? т.е. куда его приписать, в батник запуска сервера или куда??? и как "-7408" или просто "7408" ??? ... |
| 21.07.2006, 14:27 |
Collectordbcc tablealloc (syslogs, full, fix) - результата не дало dbcc dbrepair(dbname, fixlogfreespace) - 14:29:06.478 DBMS cserv -- Error: Number (10333) Severity (14) State (1) Server (cserv) Incorrect DBCC command: Please see the Commands Reference Manual for DBCC commands and options. как применить флажок....??? т.е. куда его приписать, в батник запуска сервера или куда??? и как "-7408" или просто "7408" ??? -T7408 в батник ... |
| 21.07.2006, 15:35 |
Эфекта нет... централ так и показывает отрицательный лог ... |
| 21.07.2006, 16:15 |
Ну вы даете dbcc dbrepair(dbname, fixlogfreespace) вместо dbname - имя своей БД поставьте . по поводу флага 7408, ASE после этого перестартовали??? Через батник ??? Using 7408 traceflag. ================ Boot the server with traceflag -T7408 added to your ASE startup script. Once booted, create a dummy transaction in the offending db, then checkpoint the db. use prodQueues go create table mytb ( i int ) go checkpoint go drop table mytb go This dummy table creation is to ensure the checkpoint will really be written to disk. See if it now has the correct value ... |
| 21.07.2006, 19:02 |
:) понятное дело, что имя своей базы ставил... у меня версия ASE 12.0.... смею полагать... нет такой фишки и перестартовал конечно после трейс флага... ... |
| 22.07.2006, 10:37 |
dbcc dbrepair(dbname, fixlogfreespace) команда это вываливает в ерорлог ошибку стека... ... |
| 22.07.2006, 11:27 |
Не обратил внимание что у вас ASE12. Эта версия уже давно устарела dbcc команда и флаг там еще не реализованы ... |
| 22.07.2006, 12:22 |
В следующий раз выполняйте dump tran c опцией with truncate_only а не с опцией with no_log. Т.к. в основном, именно no_log, ведет к тому что появлются отрицательные значений ... |
| 22.07.2006, 12:27 |
я так понимаю, можно забить, на то что централ кажет??? ... |
| 22.07.2006, 12:51 |
use master go sp_stop_rep_agent MYDB go sp_dboption MYDB,'single user',true go use MYDB go checkpoint go dbcc traceon(3604) go dbcc tablealloc(syslogs,full,fix) go и вот тут-то он должен в адвантаже среди великого множества строк сказать что сумма страниц некорректна, и исправить ее use master go sp_dboption MYDB,'single user',false go use MYDB go checkpoint go ... |
| 07.08.2006, 11:08 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2012691]: |
214ms |
48ms |
| others: | 251ms |
| total: | 563ms |
