Проблемы при инсталяции Sybase RS 12.6
Добрый день! не могу проинсталировать Sybase RS 12.6 на HP Unix true 64 При запуске setup: ./setup -is:javahome /usr/opt/java131 выдает ошибку: An unhandled error occurred -- specify system property "is.debug" for more infor mation. в логе пишет Log file created by ISMP installer @Sat Aug 5 10:24:57 ALMT 2006 INSTALLER_PATH=/sybase_work/sybase12/repserver/./setup.internal command line switch -is:javahome is specifed. Verifying the JVM with the JVM fil es specifed with the launcher. Verifying... /usr/opt/java131/bin/java -cp /sybase_work/sybase12/istemp4262921 7102457/Verify.jar Verify java.version Verification passed for /usr/opt/java131 using the JVM file /sybase_work/sybase1 2/istemp42629217102457/custom.jvm. -cp:p operand is empty -cp:a operand is empty Installer JAR archive is not embedded. Run time Java arguments are not specified. LAUNCH_COMMAND=/usr/opt/java131/bin/java -cp .:::::"classes\log4j.jar":"classes ^Gse_sis.jar":"suite":::::: -Dtemp.dir="/sybase_work/sybase12" -Dis.jvm.home=" /usr/opt/java131" -Dis.jvm.temp="0" -Dis.media.home="" -Dis.launcher.file="/syba se_work/sybase12/repserver/./setup.internal" -Dis.jvm.file="/sybase_work/sybase1 2/istemp42629217102457/custom.jvm" -Dis.external.home="/sybase_work/sybase12/rep server/." -Xmx40m -Xms20m run 1>>log1 2>>/sybase_work/sybase12/istemp42629217 102457/APP_STDERR Помогите плиз. ... |
| 05.08.2006, 09:05 |
CD HP Installshield doesn't work if it uses the mount command locally Workaround : =============== Use the following command: mount -F cdfs -o ro,rr /dev/dsk/c1t2d0 /cdrom Please note the options (-o ro,rr) The rr means use the rock-ridge extensions. If you mount the cd without this option you will get a failure like this: ... |
| 07.08.2006, 11:26 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2012689]: |
177ms |
| others: | 212ms |
| total: | 455ms |
