Panorama
Сабж, он же SQLAnywhere 11. Сегодня пришло приглашение участвовать в бета-программе :) ... |
| 28.03.2008, 10:12 |
Panorama
Хм... всего полтора года прошло от выпуска 10-и. Что в 11-ой нового? ... |
| 28.03.2008, 17:08 |
Panorama
Как-то не очень много, как для следующей версии. http://www.sybase.com/files/Technical_Documents/PanoramaRevGuide.pdf -EMBEDDED FULL-TEXT SEARCH -Immediately Maintained Materialized Views -Read-Only Mirror Server -Relay Server Architecture -MOBILINK SYNCHRONIZATION WITH MYSQL MySQL 5.0 is now a supported consolidated database for SQL Anywhere Panorama. The support provides full bi-directional synchronization between SQL Anywhere or UltraLite remote databases and a MySQL 5.0 consolidated database running the InnoDB storage engine. -ADO.NET 3.5, ADO.NET ENTITY FRAMEWORK, AND VISUAL STUDIO 2008 SUPPORT -JSON WEB SERVICES SUPPORT JSON (JavaScript Object Notation) is a simple, lightweight data exchange format that is ideal for representing and exchanging data structures. Although it is programming language independent, JSON www.sybase.com/iAnywhere 18 is most often used with JavaScript because a JSON object can be evaluated simply to recreate and use the data structure. SQL Anywhere Panorama allows web service requests, using its built-in HTTP server, to return JSON formatted result sets. The result set is returned as an array of key-value pairs, with each key corresponding to a column in the result set. ... |
| 28.03.2008, 17:17 |
Panorama
Ну, наличие FTS, JSON, IMV - уже хорошо. А там в списке еще много чего по мелочи. ... |
| 29.03.2008, 14:21 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2011659]: |
180ms |
57ms |
| others: | 242ms |
| total: | 534ms |
