kechkfault: engine 0: scheduler infected with signal 11
У меня есть сервер такой конфигурации: Linux 2.4.18-5aspsmp #1 SMP i686 memory - 2064684K gcc version 2.96 20000731 Поставил SYBASE-11.9.2, пытаюсь ее инициализировать с такими параметрами srvbuild.release_directory: /opt/sybase-11.9.2 srvbuild.product: sqlsrv srvbuild.server_name: sybase srvbuild.new_config: yes srvbuild.do_add_server: yes srvbuild.do_upgrade: no srvbuild.network_protocol_list: tcp srvbuild.network_hostname_list: 217.16.18.124 srvbuild.network_port_list: 4100 srvbuild.master_device_physical_name: /opt/sybase-11.9.2/Sybase/master.db srvbuild.master_device_size: 100 srvbuild.master_database_size: 50 srvbuild.errorlog: /opt/sybase-11.9.2/install/sybase.log srvbuild.sybsystemprocs_device_physical_name: /opt/sybase-11.9.2/Sybase/subsystemprocs.db srvbuild.sybsystemprocs_device_size: 60 srvbuild.sybsystemprocs_database_size: 60 srvbuild.sybsystemdb_device_physical_name: USE_DEFAULT srvbuild.sybsystemdb_device_size: 5 srvbuild.sybsystemdb_database_size: 5 srvbuild.default_backup_server: SYB_BACKUP Настройки сервера: kernel.shmmax = 1073740000 для sybase bash-2.05a$ ulimit -a core file size (blocks, -c) 0 data seg size (kbytes, -d) unlimited file size (blocks, -f) unlimited max locked memory (kbytes, -l) unlimited max memory size (kbytes, -m) unlimited open files (-n) 90000 pipe size (512 bytes, -p) 8 stack size (kbytes, -s) 8192 cpu time (seconds, -t) unlimited max user processes (-u) 7168 virtual memory (kbytes, -v) unlimited для root [root@tyan etc]# ulimit -a core file size (blocks, -c) 0 data seg size (kbytes, -d) unlimited file size (blocks, -f) unlimited max locked memory (kbytes, -l) unlimited max memory size (kbytes, -m) unlimited open files (-n) 90000 pipe size (512 bytes, -p) 8 stack size (kbytes, -s) 8192 cpu time (seconds, -t) unlimited max user processes (-u) 7168 virtual memory (kbytes, -v) unlimited В лог вылетает такая ошибка: kernel Logging SQL Server messages in file '/opt/sybase-11.9.2/install/sybase.log'. kernel Directory Control Layer (DCL) using directory driver: InterfacesDriver kernel Network and device connection limit is 9990. server Number of proc buffers allocated: 1087. server Proc header memory allocated 543 pages for each per engine cache server Number of blocks left for proc headers: 1134. server Memory allocated for the default data cache cache: 8162 Kb server Size of the 2K memory pool: 8162 Kb kernel Initializing virtual device 0, '/opt/sybase-11.9.2/Sybase/master.db' kernel Virtual device 0 started using standard unix i/o. kernel Worker Thread Manager is not enabled for use in SQL Server. kernel Either the config parameter 'use security services' is set to 0, or ASE does not support use of external security m00:00000:00000:2003/07/12 23:01:58.28 kernel engine 0, os pid 6270 online server No active traceflags server Opening Master Database ... server Loading SQL Server's default sort order and character set kernel network name 217.16.18.124, type ether, port 4100 kernel current process (0x40004) infected with 11 kernel kechkfault: engine 0: scheduler infected with signal 11 kernel pc 0x8428543 ucbacktrace+0x67(0x0,0x1,0x86d035c,0xb,0x9011614) kernel pc 0x8431f4a keipanic+0x5e(0xc378,0x0,0xb,0x86d035c,0xb) kernel pc 0x8430802 kechkfault+0x46(0xb,0x86d035c,0x900ee60,0x0,0x176fc8) kernel pc 0x84361cb kisignal+0x3f(0xb,0x0,0x0,0x2b,0x2b) kernel end of stack trace, kernel service process: kpid 262148 kernel ueshutdown: exiting kernel Abnormal exit detected - SQL Server process level execution bindings will be cleared on startup. в /init/logs/srvbuild0712.002 type = 1 master_device_physical_name = /opt/sybase-11.9.2/Sybase/master.db master_device_size = 30 master_database_size = 5 sybsystemprocs_device_physical_name = /opt/sybase-11.9.2/Sybase/subsystemprocs.db sybsystemprocs_device_size = 60 sybsystemprocs_database_size = 60 errorlog = /opt/sybase-11.9.2/install/sybase.log sybsystemdb_device_physical_name = sybsystemdb_device_size = 5 sybsystemdb_database_size = 5 shmem = /opt/sybase-11.9.2 default_backup_server = SYB_BACKUP server_name = sybase Sat Jul 12 23:01:58 2003: (Shell command) /opt/sybase-11.9.2/bin/buildmaster -d /opt/sybase-11.9.2/Sybase/master.db -s 15360 > /tmp/sbcjmK1k 2>&1 Master device: /opt/sybase-11.9.2/Sybase/master.db writing configuration area writing the MASTER database writing the MODEL database writing allocation pages for remaining 25 MB, (12800 pages) 2 MB 4 MB 6 MB 8 MB 10 MB 12 MB 14 MB 16 MB 18 MB 20 MB 22 MB 24 MB 25 MB Buildmaster complete Sat Jul 12 23:01:58 2003: Buildmaster return code: 0. Sat Jul 12 23:01:58 2003: (Shell command) /opt/sybase-11.9.2/bin/dataserver -d/opt/sybase-11.9.2/Sybase/master.db -e/opt/sybase-11.9.2/install/sybase.log -M/opt/Sat Jul 12 23:02:38 2003: Unable to boot server 'sybase'. если смотреть по strace во время инициализации, то socket(PF_INET, SOCK_STREAM, IPPROTO_IP) = 6 setsockopt(6, SOL_SOCKET, SO_KEEPALIVE, , 4) = 0 setsockopt(6, SOL_SOCKET, SO_LINGER, [0], 8) = 0 setsockopt(6, SOL_TCP, TCP_NODELAY, , 4) = 0 getpid() = 7856 ioctl(6, 0x8902[, 7856]) = 0 fcntl64(6, F_SETOWN, 7856) = 0 ioctl(6, 0x5421, ) = 0 connect(6, {sin_family=AF_INET, sin_port=htons(4100), sin_addr=inet_addr("217.16.18.124")}}, 16) = -1 EINPROGRESS (Operation now in progress) open("/mnt/sdb2/opt/sybase-11.9.2/locales/message/us_english/tcllib.loc", O_RDONLY) = 7 read(7, "; comment character is a semicol"..., 512) = 512 lseek(7, -15, SEEK_CUR) = 497 read(7, "\tescape=\\\t\t; backslash is the es"..., 512) = 512 close(7) = 0 open("/mnt/sdb2/opt/sybase-11.9.2/locales/message/us_english/libinsck.loc", O_RDONLY) = 7 read(7, "\n; comment character is a semico"..., 512) = 512 lseek(7, -16, SEEK_CUR) = 496 read(7, "\tescape=\\\t\t; backslash is the es"..., 512) = 512 close(7) = 0 select(7, , [6], , {60, 0}) = 1 (out [6], left {60, 0}) connect(6, {sin_family=AF_INET, sin_port=htons(4100), sin_addr=inet_addr("217.16.18.124")}}, 16) = -1 ECONNREFUSED (Connection refused) close(6) = 0 close(6) = -1 EBADF (Bad file descriptor) select(5, , [], , {0, 0}) = 0 (Timeout) С чем могут быть связаны такие проблемы? ... |
| 13.07.2003, 21:12 |
С тем, что Sybase давно пора выкинуть а ты еще не выкинул... ... |
| 14.07.2003, 09:58 |
У-у-у как ты...:) Нет такой возможности у меня ("..я его слепила, из того что было..." какая-то песня) Ну а если серьезно, то проблему необходимо решить, и по возможности быстрее. Ты можешь чем-то помочь? ... |
| 14.07.2003, 11:31 |
если кому интерестно: в моем случае вылечилось изменением ulimin -n 1024 у пользователя sybase. ... |
| 14.07.2003, 20:14 |
ruslik2000если кому интерестно: в моем случае вылечилось изменением ulimin -n 1024 у пользователя sybase. Огроменное спасибо! Аналогично, все получилось при установке ASE 11.9 на FreeBSD, только там на время установки сделал sysctl kern.maxfiles=1024 После установки вернул на родину. ... |
| 02.04.2008, 12:55 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2011649]: |
73ms |
48ms |
| others: | 236ms |
| total: | 424ms |
