commit закрывает курсор ?
asa 902 подскажите, так должно быть, когда Commit или autocommit-действие закрывает курсор ? для примера: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. будет ругаться на close curs1 заранее спасибо! ... |
| 28.04.2008, 16:25 |
а зачем здесь вообще курсор?! ... |
| 28.04.2008, 16:34 |
Марсельподскажите, так должно быть, когда Commit или autocommit-действие закрывает курсор ?Да, так должно быть. Читать BOL. SQL Anywhere® Server - Programming > Using SQL in Applications > Controlling transactions in applications > Cursors and transactionsIn general, a cursor closes when a COMMIT is performed. There are two exceptions to this behavior: The close_on_endtrans database option is set to Off. A cursor is opened WITH HOLD, which is the default with Open Client and JDBC. If either of these two cases is true, the cursor remains open on a COMMIT. ROLLBACK and cursors If a transaction rolls back, then cursors close except for those cursors opened WITH HOLD. However, don't rely on the contents of any cursor after a rollback. The draft ISO SQL3 standard states that on a rollback, all cursors (even those cursors opened WITH HOLD) should close. You can obtain this behavior by setting the ansi_close_cursors_on_rollback option to On. Savepoints If a transaction rolls back to a savepoint, and if the ansi_close_cursors_on_rollback option is On, then all cursors (even those cursors opened WITH HOLD) opened after the SAVEPOINT close. Cursors and isolation levels You can change the isolation level of a connection during a transaction using the SET OPTION statement to alter the isolation_level option. However, this change does not affect open cursors. ... |
| 28.04.2008, 18:00 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2011603]: |
441ms |
47ms |
| others: | 206ms |
| total: | 745ms |
