Сегмент default
Есть следующие ошибки: Warning: sybase_query(): Sybase: Server message: Can't allocate space for object 'documentation_values' in database 'wb' because 'default' segment is full/has no free extents. If you ran out of space in syslogs, dump the transaction log. Otherwise, use ALTER DATABASE to increase the size of the segment. (severity 17, procedure N/A) in Warning: sybase_query(): Sybase: Server message: Unable to allocate new text value, dbid 4. (severity 17, procedure N/A) in Пробовал следующее: sp_extendsegment 'default', 'wb','wb' Пишет: No such device exists -- run sp_helpdb to list the devices for the current database. (return status = 1) 1> sp_helpdb 2> go name db_size owner dbid created status ------------------------ ------------- ------------------------ ------ -------------- ------------------------------------------------------------------------------------------------------ master 6.0 MB sa 1 Aug 22, 2006 mixed log and data model 2.0 MB sa 3 Aug 22, 2006 mixed log and data sybsystemdb 2.0 MB sa 31513 Aug 22, 2006 mixed log and data sybsystemprocs 120.0 MB sa 31514 Aug 22, 2006 trunc log on chkpt, mixed log and data tempdb 203.0 MB sa 2 May 21, 2008 select into/bulkcopy/pllsort, trunc log on chkpt, mixed log and data wb 2348.0 MB cyber 4 Aug 22, 2006 select into/bulkcopy/pllsort, mixed log and data 1> sp_helpdb wb 2> go name db_size owner dbid created status ------------------------ ------------- ------------------------ ------ -------------- ------------------------------------------------------------------------------------------------------ wb 2348.0 MB cyber 4 Aug 22, 2006 select into/bulkcopy/pllsort, mixed log and data (1 row affected) device_fragments size usage created free kbytes ------------------------------ ------------- -------------------- ------------------- ---------------- data 10.0 MB data only Aug 23 2006 9:53PM 14 data 5.0 MB log only Aug 23 2006 9:53PM not applicable data 285.0 MB data only Aug 23 2006 9:53PM 42 data 300.0 MB log only Aug 23 2006 9:53PM not applicable data 400.0 MB data and log Aug 23 2006 9:53PM 14 data 50.0 MB log only Aug 23 2006 9:53PM not applicable data 200.0 MB data and log Aug 23 2006 9:53PM 140 data 5.0 MB log only Aug 23 2006 9:53PM not applicable data 113.0 MB data and log Aug 23 2006 9:53PM 280 data 1.0 MB log only Aug 23 2006 9:53PM not applicable data 679.0 MB data and log Aug 23 2006 9:53PM 2324 logs 300.0 MB data and log Aug 23 2006 9:53PM 0 -------------------------------------------------------------- log only free kbytes = 301140 device segment ------------------------------ -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- data default data logsegment data system logs default logs logsegment logs system Как исправить ошибку? Заранее спасибо! ... |
| 21.05.2008, 20:52 |
Сегмент default
мдаа, это порнография, а не база... общем, место у вас кончилось в базе исправить так: 1) создать новый девайс Код: plaintext Код: plaintext покажите вывод (полностью) скрипта : Код: plaintext 1. 2. 3. 4. 5. ... |
| 21.05.2008, 21:42 |
Сегмент default
select @@version Adaptive Server Enterprise/12.5.2/EBF 11949 ESD#1/P/Linux Intel/Enterprise Linux/ase1252/1838/32-bit/OPT/Sat May 29 01:03:02 2004 1> exec sp_helpdevice 2> go device_name physical_name description status cntrltype device_number low high ------------------------------ ---------------------------------------------- -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- ------ --------- ------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- data /opt/sybase/12.5/data/data.dat special, dsync on, physical disk, 3072.00 MB 16386 0 2 33554432 35127295 logs /opt/sybase/12.5/data/logs.dat special, dsync on, physical disk, 600.00 MB 16386 0 3 50331648 50638847 master /opt/sybase/12.5/data/master.dat special, dsync on, default disk, physical disk, 30.00 MB 3 0 0 0 15359 sysprocsdev /opt/sybase/12.5/data/sybsysproc.dat special, dsync on, physical disk, 120.00 MB 16386 0 1 16777216 16838655 tapedump1 /dev/nst0 disk, dump device 16 2 0 0 20000 tapedump2 /dev/nst1 tape, 625 MB, dump device 16 3 0 0 20000 sp_configure 'number of ' Parameter Name Default Memory Used Config Value Run Value Unit Type ------------------------------ ----------- ----------- ------------ ----------- -------------------- ---------- number of alarms 40 4 40 40 number dynamic number of aux scan descriptors 200 #232 200 200 number dynamic number of ccbs 0 0 0 0 number static number of checkpoint tasks 1 0 1 1 number dynamic number of devices 10 #10 10 10 number dynamic number of dtx participants 500 146 500 500 number dynamic number of dump threads 1 0 1 1 number dynamic number of engines at startup 1 0 1 1 number static number of histogram steps 20 0 20 20 number dynamic number of index trips 0 0 0 0 number dynamic number of java sockets 0 0 0 0 number dynamic number of large i/o buffers 6 3112 6 6 number dynamic number of locks 5000 754 5000 5000 number dynamic number of mailboxes 30 6 30 30 number dynamic number of messages 64 6 64 64 number dynamic number of oam trips 0 0 0 0 number dynamic number of open databases 12 1416 12 12 number dynamic number of open indexes 500 592 500 500 number dynamic number of open objects 500 719 500 500 number dynamic number of pre-allocated extent 2 0 2 2 number dynamic number of remote connections 20 33 20 20 number static number of remote logins 20 22 20 20 number static number of remote sites 10 1547 10 10 number static number of sort buffers 500 0 500 500 number dynamic number of user connections 25 3861 25 25 number dynamic number of worker processes 0 0 0 0 number dynamic (1 row affected) ... |
| 21.05.2008, 21:47 |
Сегмент default
далее: Код: plaintext 1. 2. 3. 4. 5. 6. 7. ... |
| 21.05.2008, 23:44 |
Сегмент default
+ интересно вот это: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. ... |
| 21.05.2008, 23:51 |
Сегмент default
1> use master 2> go 1> alter database wb on data='1024M' with override 2> go Extending database by 421888 pages (824.0 megabytes) on disk data Caution: You have set up this database to include space on disk 2 for both data and the transaction log. This can make recovery impossible if that disk fails. 1> sp_helpdb wb 2> go name db_size owner dbid created status ------------------------ ------------- ------------------------ ------ -------------- ------------------------------------------------------------------------------------------------------ wb 3172.0 MB cyber 4 Aug 22, 2006 select into/bulkcopy/pllsort, mixed log and data (1 row affected) device_fragments size usage created free kbytes ------------------------------ ------------- -------------------- ------------------- ---------------- data 10.0 MB data only Aug 23 2006 9:53PM 14 data 5.0 MB log only Aug 23 2006 9:53PM not applicable data 285.0 MB data only Aug 23 2006 9:53PM 42 data 300.0 MB log only Aug 23 2006 9:53PM not applicable data 400.0 MB data and log Aug 23 2006 9:53PM 14 data 50.0 MB log only Aug 23 2006 9:53PM not applicable data 200.0 MB data and log Aug 23 2006 9:53PM 140 data 5.0 MB log only Aug 23 2006 9:53PM not applicable data 113.0 MB data and log Aug 23 2006 9:53PM 280 data 1.0 MB log only Aug 23 2006 9:53PM not applicable data 679.0 MB data and log Aug 23 2006 9:53PM 2324 logs 300.0 MB data and log Aug 23 2006 9:53PM 0 data 824.0 MB data and log May 22 2008 11:49AM 840386 -------------------------------------------------------------- log only free kbytes = 1138100 device segment ------------------------------ -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- data default data logsegment data system logs default logs logsegment logs system (return status = 0) 1> use master 2> go 1> sp_configure 'memory' 2> go Parameter Name Default Memory Used Config Value Run Value Unit Type ------------------------------ ----------- ----------- ------------ ----------- -------------------- ---------- additional network memory 0 0 0 0 bytes dynamic allocate max shared memory 0 0 0 0 switch dynamic heap memory per user 4096 0 4096 4096 bytes dynamic lock shared memory 0 0 0 0 switch static max memory 32768 320426 160213 160213 memory pages(2k) dynamic memory alignment boundary 2048 0 2048 2048 bytes static memory per worker process 1024 4 1024 1024 bytes dynamic Memory Use 0 0 0 0 not applicable NULL messaging memory 400 0 400 400 memory pages(2k) dynamic Physical Memory 0 0 0 0 not applicable NULL shared memory starting address 0 0 0 0 not applicable static total logical memory 32768 177332 88666 88666 memory pages(2k) read-only total physical memory 0 177332 0 88666 memory pages(2k) read-only (1 row affected) An additional 143094 K bytes of memory is available for reconfiguration. This is the difference between 'max memory' and 'total logical memory'. (return status = 1) 1> sp_helpcache 2> go Cache Name Config Size Run Size Overhead ------------------------ ------------- ---------- ---------- default data cache 100.00 Mb 100.00 Mb 6.58 Mb Memory Available For Memory Configured Named Caches To Named Caches -------------------- ---------------- 100.01 Mb 100.00 Mb ------------------ Cache Binding Information: ------------------ Cache Name Entity Name Type Index Name Status ---------- ----------- ---- ---------- ------ (return status = 0) 1> sp_configure 'cache' 2> go Parameter Name Default Memory Used Config Value Run Value Unit Type ------------------------------ ----------- ----------- ------------ ----------- -------------------- ---------- abstract plan cache 0 0 0 0 switch dynamic Cache Manager 0 0 0 0 not applicable NULL extended cache size 0 32 0 0 memory pages(2k) dynamic global cache partition number 1 0 1 1 number static Meta-Data Caches 0 0 0 0 not applicable NULL permission cache entries 15 #190 15 15 number dynamic procedure cache size 3271 42346 20000 20000 memory pages(2k) dynamic size of unilib cache 0 120 0 0 bytes dynamic statement cache size 0 0 0 0 memory pages(2k) dynamic total data cache size 0 109134 0 109134 kilobytes read-only user log cache size 2048 0 2048 2048 bytes static user log cache spinlock ratio 20 0 20 20 ratio dynamic 1> use wb 2> go 1> sp_helpsegment logsegment 2> go segment name status ------- ------------------------------ ------ 2 logsegment 0 device size ------------------------------ ---------------------- data 2577.0MB logs 300.0MB free_pages ----------- 569018 table_name index_name indid ------------------------------ ------------------------------ ------ syslogs syslogs 0 total_size total_pages free_pages used_pages reserved_pages ----------------- --------------- --------------- --------------- --------------- 2877.0MB 1473024 569018 7720 0 (return status = 0) ... |
| 22.05.2008, 10:52 |
Сегмент default
ну всё, теперь у вас в базе есть еще 1 Гб под данные и лог девайс data заполнен - когда упрётесь в недостаток свободного места в базе придется создавать новый девайс кстати, у вас идет совмещение данных и лога, поэтому при "удачно подобранной" транзакции места под данные может не хватить даже после текущего расширения бекап логов настроен? опция 'trunc log on chkpt' на базе не стоит... серверу Sybase отведено всего 300 Мб оперативки - подозреваю, что можно увеличить объем и потенциально увеличить быстродействие сервера на вашем месте я бы перелил базу раскидал данные на девайс data, а лог - на девайс log, как похоже изначально и задумывалось ... |
| 22.05.2008, 11:17 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2011563]: |
177ms |
62ms |
| others: | 240ms |
| total: | 541ms |
