powered by simpleCommunicator - 2.0.59     © 2025 Programmizd 02
Форумы / Sybase ASA, ASE, IQ [игнор отключен] [закрыт для гостей] / биндю базу в кеш, а используется и ругается на default
    #36562085
blzz
есть Adaptive Server Enterprise/12.5.3/EBF 13339 ESD#7/P/x86_64/Enterprise Linux/ase1253/1951/64-bit/OPT/Fri Mar 24 00:39:11 2006 на RHEL 3.
Код: plaintext
1.
2.
3.
4.
5.
--создаю девайсы:
disk init name "device_190", size="32G", physname="/dev/raw/raw190"
disk init name "arc_2000_log", size="1G", physname="/sybase/test/arc_2000_log"
--создаю базу.
create database arc_2000_test on device_190="28G" log on arc_2000_log="1G"
создал отдельно-стоящий mixed cache, для работы с этой базой: second_data_cache, забиндил базу на этот кеш.
загружаю дамп в эту базу. по окончанию load, в конце выскакивает.
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
02:00000:00158:2010/04/05 20:49:52.54 server  Device Information:
                                 Device number = 88
                                 Phyname = /dev/raw/raw190
02:00000:00158:2010/04/05 20:49:52.54 server  Buffer Information:
                                 Buf addr = 0x0x2d63a463c0, Mass addr = 0x0x2d63a463c0
                                 Buf pageno = 32, Mass pageno = 32, dbid = 24
                                 Buf virtpg = 1476395040, Mass virtpg = 1476395040
                                 Buf stat = 0x1, Mass stat = 0x1008
                                 Mass keep = 1, Mass awaited = 0
02:00000:00158:2010/04/05 20:49:52.54 server  Page Information from first read attempt: Page read from cache ppageno = 16, pobjid = 3, pindid = 0 pnextpg = 18, pprevpg = 0 plevel = 0, pstat = 0x11 pts_hi = 0, pts_lo = 86
02:00000:00158:2010/04/05 20:49:52.55 server  Page Information from second read attempt: Page read from disk ppageno = 16, pobjid = 3, pindid = 0 pnextpg = 18, pprevpg = 0 plevel = 0, pstat = 0x11 pts_hi = 0, pts_lo = 86
02:00000:00158:2010/04/05 20:49:52.55 server  SDES Information:
                                 dbid = 24, objid = 2, scur.pageid = 32
                                 sstat = 0x2002005, sstat2 = 0x0
                                 suid = 1, cacheid = 0
02:00000:00158:2010/04/05 20:49:52.55 server  PSS Information:
                                 pstat = 0x1010000, pcurdb = 24, pspid = 158
                                 p2stat = 0x1000, p3stat = 0x800
                                 plasterror = 0, preverror = 0, pattention = 0
02:00000:00158:2010/04/05 20:49:52.55 server  End diagnostics for read failure:
02:00000:00158:2010/04/05 20:49:52.55 server  Error: 697, Severity: 21, State: 5
02:00000:00158:2010/04/05 20:49:52.55 server  An attempt was made to fetch logical page '32' for object '2' in database '24' from cache 'default data cache'. Wrong logical page '16' was found in cache.
ну согласно troubleshoot guide перегружаю сервер ....
при попытке recovery выскакивает в логе:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
00:00000:00001:2010/04/05 20:55:17.62 server  Starting diagnostics for read failure:
00:00000:00001:2010/04/05 20:55:17.62 server  Device Information:
                                 Device number = 88
00:00000:00001:2010/04/05 20:55:17.62 server  Buffer Information:
                                 Buf addr = 0x0x2d654888c8, Mass addr = 0x0x2d654888c8
00:00000:00001:2010/04/05 20:55:17.62 server  Page Information from first read attempt: Page read from cache ppageno = 16, pobjid = 3, pindid = 0 pnextpg = 18, pprevpg = 0 plevel = 0, pstat = 0x11 pts_hi = 0, pts_lo = 86
00:00000:00001:2010/04/05 20:55:17.62 server  Page Information from second read attempt: Page read from disk ppageno = 16, pobjid = 3, pindid = 0 pnextpg = 18, pprevpg = 0 plevel = 0, pstat = 0x11 pts_hi = 0, pts_lo = 86
00:00000:00001:2010/04/05 20:55:17.62 server  SDES Information:
00:00000:00001:2010/04/05 20:55:17.62 server  PSS Information:
                                 pstat = 0x0, pcurdb = 1, pspid = 1
                                 p2stat = 0x1110, p3stat = 0x900
00:00000:00001:2010/04/05 20:55:17.62 server  End diagnostics for read failure:
00:00000:00001:2010/04/05 20:55:17.63 server  Error: 697, Severity: 21, State: 5
00:00000:00001:2010/04/05 20:55:17.63 server  An attempt was made to fetch logical page '32' for object '2' in database '24' from cache 'default data cache'. Wrong logical page '16' was found in cache.
00:00000:00001:2010/04/05 20:55:17.90 server  Error: 834, Severity: 20, State: 4
00:00000:00001:2010/04/05 20:55:17.90 server  Illegal attempt to clean buffer: BUF=0x0x0000002d65488990, MASS=0x0x0000002d65488990, Buf#=0, page=0x0x0000002c06016000, dbid=24, Mass vpage=1476395009, Buf lpage=1, Mass stat=0x44001008, Buf stat=0x1, size=2048, cid=0 ('default data cache'), Pinned xdes=0x(nil), spid=0.
дамп не битый - проверял на другом сервере.
вопрос: почему при recovery для этой базы используется default data cache, если забинден другой это нормально? можно ли сменить его на другой?
