Restore BackUP DB
Всем привет. Прошу прощения но я новичок в администрирование БД ASE. У меня уст. DB ASE 12.5.4 Задача. Мне нужно восстановить бекап за апрель месяц. Мои действия: Запускаю утилиту для работы с БД из под командной строки: 1. isql -U user -S hostname Использую команду для восстановления бекапа: 2. load database logging from "/opt/backup_minick/20100509013022_db01_logging.dump" go дальше как я могу видеть идет восстановление архива: Backup Server session id is: 12. Use this value when executing the 'sp_volchanged' system stored procedure after fulfilling any volume change request from the Backup Server. Backup Server: 6.28.1.1: Dumpfile name 'logging101290152E' section number 1 mounted on disk file '/opt/backup_minick/20100509013022_db01_logging.dump' Backup Server: 4.188.1.1: Database logging: 403710 kilobytes (1%) LOADED. Backup Server: 4.188.1.1: Database logging: 802744 kilobytes (2%) LOADED. Backup Server: 4.188.1.1: Database logging: 1209906 kilobytes (3%) LOADED. Backup Server: 4.188.1.1: Database logging: 1603048 kilobytes (4%) LOADED. ...................................... ...................................... Backup Server: 4.188.1.1: Database logging: 34414978 kilobytes (100%) LOADED. Backup Server: 3.42.1.1: LOAD is complete (database logging). Caution: You have set up this database to include space on disk 6 for both data and the transaction log. This can make recovery impossible if that disk fails. All dumped pages have been loaded. ASE is now clearing pages above page 8601600, which were not present in the database just loaded. Processed 532 allocation unit(s) out of 5312 units (allocation page 8737536). 10% completed. Processed 1063 allocation unit(s) out of 5312 units (allocation page 8873472). 20% completed. Processed 1594 allocation unit(s) out of 5312 units (allocation page 9009408). 30% completed. Processed 2125 allocation unit(s) out of 5312 units (allocation page 9145344). 40% completed. Processed 2656 allocation unit(s) out of 5312 units (allocation page 9281280). 50% completed. Processed 3188 allocation unit(s) out of 5312 units (allocation page 9417472). 60% completed. Processed 3719 allocation unit(s) out of 5312 units (allocation page 9553408). 70% completed. Processed 4250 allocation unit(s) out of 5312 units (allocation page 9689344). 80% completed. Processed 4781 allocation unit(s) out of 5312 units (allocation page 9825280). 90% completed. Processed 5312 allocation unit(s) out of 5312 units (allocation page 9961216). 100% completed. ASE has finished clearing database pages. Started estimating recovery log boundaries for database 'logging'. Database 'logging', checkpoint=(4397446, 15), first=(4397446, 15), last=(4398237, 21). Completed estimating recovery log boundaries for database 'logging'. Started ANALYSIS pass for database 'logging'. Completed ANALYSIS pass for database 'logging'. Started REDO pass for database 'logging'. The total number of log records to process is 35883. Redo pass for database 'logging': 6000 records done (16%); 29883 records left. Redo pass for database 'logging': 12000 records done (33%); 23883 records left. Redo pass for database 'logging': 18000 records done (50%); 17883 records left. Redo pass for database 'logging': 24000 records done (66%); 11883 records left. Redo pass for database 'logging': 30000 records done (83%); 5883 records left. Redo pass of recovery has processed 8206 committed and 8 aborted transactions. Completed REDO pass for database 'logging'. Use the ONLINE DATABASE command to bring this database online; ASE will not bring it online automatically. Вопрос, что это значит? Redo pass of recovery has processed 8206 committed and 8 aborted transactions. Completed REDO pass for database 'logging'. Use the ONLINE DATABASE command to bring this database online; ASE will not bring it online automatically. Теперь я вообще не могу подключиться к БД "logging". Как мне восстановить ее и данные из архива? Заранее спасибо. ... |
| 04.06.2010, 12:29 |
Restore BackUP DB
dembi, "Use the ONLINE DATABASE command to bring this database online; ASE will not bring it online automatically." выполни там же online database logging ... |
| 04.06.2010, 12:41 |
Restore BackUP DB
Спасибо большое. Помогло. Еще есть вопрос. Мне нужно создать БД "setup". Я так понимаю сначала мне нужно создать dev на которых будет размещена это БД. Как правильно создаются dev ? Заранее спасибо. ... |
| 04.06.2010, 13:08 |
Restore BackUP DB
dembi wrote: > Еще есть вопрос. Мне нужно создать БД "setup". create database > Я так понимаю сначала мне нужно создать dev на которых будет размещена > это БД. Правильно понимаешь. > Как правильно создаются dev ? Как создаются девайсы -- написано в документации, комманда disk init. Posted via ActualForum NNTP Server 1.4 ... |
| 04.06.2010, 13:15 |
Restore BackUP DB
Пробую создать dev но получаю ошибку: 1> disk init 2> name='dev_setup_dat_01', 3> physname='/opt/sybase/vol/dev_setup_dat_01', 4> size='128MB' 5> go Msg 5107, Level 16, State 6: Server 'STINGRAY', Line 1: Value is wrong type for parameter 'SIZE' (requires type 'int'). В чем может быть проблема? Заранее спасибо. ... |
| 04.06.2010, 13:17 |
Restore BackUP DB
Устройства создал: 1> disk init 2> name='dev_setup_dat_01', 3> physname='/opt/sybase/vol/dev_setup_dat_01', 4> size='128M' 5> go 1> disk init 2> name='dev_setup_log_01', 3> physname='/opt/sybase/vol/dev_setup_log_01', 4> size='128M' 5> go Создал БД "setup" c опцией "for load" Пытаюсь восстановить архив и получаю ошибку: 1> load database setup from "/opt/backup_minick/20100604021459_db01_setup.dump" 2> go Backup Server session id is: 17. Use this value when executing the 'sp_volchanged' system stored procedure after fulfilling any volume change request from the Backup Server. Backup Server: 6.28.1.1: Dumpfile name 'setup1015501FA3 ' section number 1 mounted on disk file '/opt/backup_minick/20100604021459_db01_setup.dump' Msg 3105, Level 16, State 1: Server 'STINGRAY', Line 1: Data on dump will not fit into current database. Need 512 Mbyte database. Дело в том, что на старом сервере было выделено именно по 128 Мб под данные и логи. Как быть теперь, создать дополнительные dev чтобы общий объем был под данные более 512 Мб? Если нет, то поправьте меня. Заранее спасибо. ... |
| 04.06.2010, 13:26 |
Restore BackUP DB
Все большое спасибо за помощь ))) Я изменил размер используя утилиту "disk resize". ... |
| 04.06.2010, 13:51 |
Restore BackUP DB
dembi wrote: > Value is wrong type for parameter 'SIZE' (requires type 'int'). > В чем может быть проблема? size='128M' Posted via ActualForum NNTP Server 1.4 ... |
| 04.06.2010, 13:53 |
Restore BackUP DB
Пожалуйста, кто-то может подсказать почему не получается у меня восстановить архив? автор load database logging from "/opt/backup_minick/11.txt" 2> go Backup Server session id is: 26. Use this value when executing the 'sp_volchanged' system stored procedure after fulfilling any volume change request from the Backup Server. Backup Server: 4.10.2.1: Label validation error: first label not VOL1. Backup Server: 6.31.2.4: Volume rejected. Backup Server: 1.14.2.2: Unrecoverable I/O or volume error. This DUMP or LOAD session must exit. Backup Server: 6.32.2.3: /opt/backup_minick/11.txt: volume not valid or not requested (server: , session id: 26.) Backup Server: 1.14.2.4: Unrecoverable I/O or volume error. This DUMP or LOAD session must exit. Msg 8009, Level 16, State 1: Server 'STINGRAY', Line 1: Error encountered by Backup Server. Please refer to Backup Server messages for details. ... |
| 25.06.2010, 17:14 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2010609]: |
134ms |
27ms |
| others: | 247ms |
| total: | 437ms |
