ASE перестал грузится...
ASE 12.5.1 перестал загружаться в логах пишет 00:00000:00000:2004/07/05 13:27:43.55 kernel kscsinit: connectivity library error. Operation: cs_ctx_alloc(). кто то сталкивался ? в чем беда ? OS - linux ... |
| 05.07.2004, 13:37 |
обычно еще ДО того (Operation: cs_ctx_alloc()) строчки в логе интересные бывают. Их бы... ... |
| 05.07.2004, 15:25 |
00:00000:00000:2004/07/05 12:38:16.69 kernel Warning: There is no valid license for ASE server product. Server is booting with all the option features disabled. 00:00000:00000:2004/07/05 12:38:16.69 kernel Using config area from primary master device. 00:00000:00000:2004/07/05 12:38:16.70 kernel Detected 4 physical CPU's 00:00000:00000:2004/07/05 12:38:16.70 kernel Internal run-time model set for Linux - Native 00:00000:00000:2004/07/05 12:38:16.70 kernel Using 1024 file descriptors. 00:00000:00000:2004/07/05 12:38:16.70 kernel Adaptive Server Enterprise/12.5.1/EBF 1429/P/Linux Intel/Enterprise Linux/ase1 251/1823/32-bit/OPT/Tue Sep 16 23:43:54 2003 00:00000:00000:2004/07/05 12:38:16.70 kernel Confidential property of Sybase, Inc. 00:00000:00000:2004/07/05 12:38:16.70 kernel Copyright 1987, 2003 00:00000:00000:2004/07/05 12:38:16.70 kernel Sybase, Inc. All rights reserved. 00:00000:00000:2004/07/05 12:38:16.70 kernel Unpublished rights reserved under U.S. copyright laws. 00:00000:00000:2004/07/05 12:38:16.70 kernel 00:00000:00000:2004/07/05 12:38:16.70 kernel This software contains confidential and trade secret information of Sybase, 00:00000:00000:2004/07/05 12:38:16.70 kernel Inc. Use, duplication or disclosure of the software and documentation by 00:00000:00000:2004/07/05 12:38:16.70 kernel the U.S. Government is subject to restrictions set forth in a license 00:00000:00000:2004/07/05 12:38:16.70 kernel agreement between the Government and Sybase, Inc. or other written 00:00000:00000:2004/07/05 12:38:16.70 kernel agreement specifying the Government's rights to use the software and any 00:00000:00000:2004/07/05 12:38:16.70 kernel applicable FAR provisions, for example, FAR 52.227-19. 00:00000:00000:2004/07/05 12:38:16.70 kernel Sybase, Inc. One Sybase Drive, Dublin, CA 94568, USA 00:00000:00000:2004/07/05 12:38:16.70 kernel Using '/opt/sybase/ASE-12_5/billing.cfg' for configuration information. 00:00000:00000:2004/07/05 12:38:16.70 kernel Logging ASE messages in file '/var/log/sybase/billing.log'. 00:00000:00000:2004/07/05 12:38:16.71 kernel kscsinit: connectivity library error. Operation: cs_ctx_alloc() а почему кстати он на лицензию оругался ? вроде все правильно ввел... ... |
| 05.07.2004, 15:35 |
Это видимо слетели настройки Open Client. Посмотрите правильно ли заполнены переменные среды SYBASE и OCS. Запустите dsedit и isql. Напоминаю, что переменные задаются для конкретного польователя - того, под чьим аккаутном запускается сервер. Насчет "There is no valid license" - это так и нужно, эти лицензии используются только для дополнительных опций поставки ASE, таких, как Server-side Java, Full text search и т.п. ... |
| 05.07.2004, 17:22 |
пересобрал базы srvbuild'ом заработало.... ХЗ чего было... ... |
| 06.07.2004, 10:04 |
Аналогичная беда случилась под win 2000 на 12.5.4 esd#10 ASE_DEV. dsedit и прочее - вообще не запускается (только централ запускается, но не более того). Кусок errorlog (ненужное про Sybase, Inc. и copyright laws потёр): автор00:00000:00000:2010/06/29 14:52:34.01 kernel Checked out license ASE_DEV 00:00000:00000:2010/06/29 14:52:34.04 kernel Adaptive Server Enterprise Developer Edition. 00:00000:00000:2010/06/29 14:52:34.07 kernel Using config area from primary master device. 00:00000:00000:2010/06/29 14:52:34.09 kernel Warning: Using default file 'C:\sybase\main.cfg' since a configuration file was not specified. Specify a configuration file name in the RUNSERVER file to avoid this message. 00:00000:00000:2010/06/29 14:52:34.29 kernel Using 100000 file descriptors. 00:00000:00000:2010/06/29 14:52:34.29 kernel Adaptive Server Enterprise/12.5.4/EBF 16791 ESD#10/P/NT (IX86)/OS 4.0/ase1254/2159/32-bit/OPT/Mon Nov 02 05:01:55 2009 00:00000:00000:2010/06/29 14:52:34.85 kernel Using C:\sybase\ as the SYBASE environment variable, found during start-up 00:00000:00000:2010/06/29 14:52:34.92 kernel ASE booted on Windows 2000 build 2195 Service Pack 2. 00:00000:00000:2010/06/29 14:52:34.95 kernel Using 'C:\sybase\main.cfg' for configuration information. 00:00000:00000:2010/06/29 14:52:34.98 kernel Logging ASE messages in file 'C:\sybase\ASE-12_5\install\errorlog'. 00:00000:00000:2010/06/29 14:52:35.21 kernel kscsinit: connectivity library error. Operation: cs_ctx_alloc(). Файлик sybinit.err тоже забавный: авторThe context allocation routine failed when it tried to load localization files!! One or more following problems may caused the failure Your sybase home directory is C:\sybase. Check the environment variable SYBASE if it is not the one you want! Using default locale name: "default" Пролил сверху последний ebf - не полегчало. Все переменные окружения корректные (перепроливал их батником). Файлы в папках charsets и locales тоже нормальные (перепроливал ebf-ом). Мысли будут? ЗЫ. Это я так вернулся из отпуска удачно :( ... |
| 30.06.2010, 09:48 |
проверьте наличие файла c:\sybase\ini\objectid.dat если есть - тогда подкажите содержимое c:\sybase\locales\locales.dat со слов [nt] и до конца секции ... |
| 30.06.2010, 10:26 |
locale = enu, us_english, iso_1 locale = fra, french, iso_1 locale = deu, german, iso_1 locale = rus, russian, cp1251 locale = hun, us_english, cp1250 locale = ell, us_english, cp1253 locale = heb, us_english, cp1255 locale = ara, us_english, cp1256 locale = trk, us_english, cp1254 locale = esp, spanish, iso_1 locale = jpn, japanese, sjis locale = japanese, japanese, sjis locale = chs, chinese, eucgb locale = cht, tchinese, big5 locale = kor, korean, cp949 locale = us_english.utf8, us_english, utf8 locale = default, us_english, cp1251 в последней строке что cp1251 что оригинальное значение iso_1 - пофигу. файлик objectid.dat есть, размер 5018: ; comment character is a semicolon ; ; OBJECTID.DAT ; ; Flat-file database for mapping global object identifiers to local names. ; [file format] version=11.1 list_seperator=, escape=\ [copyright] copyright = "Copyright Sybase Inc., 1996, 2001, 2003. All rights reserved.\ Use, duplication, or disclosure by the United States Government\ is subject to restrictions as set forth in FAR subparagraphs\ 52.227-19(a)-(d) for civilian agency contracts and DFARS\ 252.227-7013(c)(1)(ii) for Department of Defense contracts.\ Sybase reserves all unpublished rights under the copyright\ laws of the United States.\ Sybase, Inc. One Sybase Drive, Dublin, CA 94568, USA. " ; ; Objectid.dat File Format: ; ; object_id = local_name1[, local_name2[, local_name3[....[,local_namen]...]]] ; ; The object_id is a sequence of non-negative integer values that are separated ; by a dot(.). ; ; 1.3.6.1.4.1.897 represents enterprises.sybase ; [charset] 1.3.6.1.4.1.897.4.9.1.1 = iso_1 1.3.6.1.4.1.897.4.9.1.2 = cp850 1.3.6.1.4.1.897.4.9.1.197 = cp858 1.3.6.1.4.1.897.4.9.1.3 = cp437 1.3.6.1.4.1.897.4.9.1.4 = roman8 1.3.6.1.4.1.897.4.9.1.218 = roman9 1.3.6.1.4.1.897.4.9.1.5 = mac 1.3.6.1.4.1.897.4.9.1.198 = mac_euro 1.3.6.1.4.1.897.4.9.1.140 = eucjis 1.3.6.1.4.1.897.4.9.1.141 = sjis 1.3.6.1.4.1.897.4.9.1.142 = deckanji 1.3.6.1.4.1.897.4.9.1.190 = utf8 1.3.6.1.4.1.897.4.9.1.191 = ucs2 1.3.6.1.4.1.897.4.9.1.9 = cp860 1.3.6.1.4.1.897.4.9.1.13 = cp1252 1.3.6.1.4.1.897.4.9.1.20 = iso88592 1.3.6.1.4.1.897.4.9.1.21 = cp852 1.3.6.1.4.1.897.4.9.1.22 = cp1250 1.3.6.1.4.1.897.4.9.1.23 = mac_ee 1.3.6.1.4.1.897.4.9.1.50 = iso88595 1.3.6.1.4.1.897.4.9.1.51 = cp855 1.3.6.1.4.1.897.4.9.1.52 = cp866 1.3.6.1.4.1.897.4.9.1.53 = cp1251 1.3.6.1.4.1.897.4.9.1.55 = koi8 1.3.6.1.4.1.897.4.9.1.56 = mac_cyr 1.3.6.1.4.1.897.4.9.1.60 = iso88596 1.3.6.1.4.1.897.4.9.1.62 = cp1256 1.3.6.1.4.1.897.4.9.1.66 = cp864 1.3.6.1.4.1.897.4.9.1.70 = iso88597 1.3.6.1.4.1.897.4.9.1.71 = greek8 1.3.6.1.4.1.897.4.9.1.72 = cp869 1.3.6.1.4.1.897.4.9.1.73 = cp1253 1.3.6.1.4.1.897.4.9.1.74 = macgrk2 1.3.6.1.4.1.897.4.9.1.80 = iso88598 1.3.6.1.4.1.897.4.9.1.81 = cp1255 1.3.6.1.4.1.897.4.9.1.90 = iso88599 1.3.6.1.4.1.897.4.9.1.91 = turkish8 1.3.6.1.4.1.897.4.9.1.92 = cp1254 1.3.6.1.4.1.897.4.9.1.93 = cp857 1.3.6.1.4.1.897.4.9.1.94 = macturk 1.3.6.1.4.1.897.4.9.1.100 = tis620 1.3.6.1.4.1.897.4.9.1.101 = cp874 1.3.6.1.4.1.897.4.9.1.144 = cp932 1.3.6.1.4.1.897.4.9.1.150 = eucksc 1.3.6.1.4.1.897.4.9.1.154 = cp949 1.3.6.1.4.1.897.4.9.1.160 = euccns 1.3.6.1.4.1.897.4.9.1.161 = big5 1.3.6.1.4.1.897.4.9.1.165 = cp950 1.3.6.1.4.1.897.4.9.1.170 = eucgb 1.3.6.1.4.1.897.4.9.1.171 = cp936 1.3.6.1.4.1.897.4.9.1.173 = gb18030 1.3.6.1.4.1.897.4.9.1.168 = big5hk 1.3.6.1.4.1.897.4.9.1.14 = iso15 1.3.6.1.4.1.897.4.9.1.30 = cp1257 1.3.6.1.4.1.897.4.9.1.120 = cp1258 1.3.6.1.4.1.897.4.9.1.200 = iso14 [natlang] ;The language are coded based on language codes defined in the ISO 639. ;ISO 639 assign three characters to each language. We use the sequential ;number of the each letter to form a six digits code to use as the ;language codes. ; eng 1.3.6.1.4.1.897.4.9.2.051407 = us_english, english ; fra 1.3.6.1.4.1.897.4.9.2.061801 = french ; ger 1.3.6.1.4.1.897.4.9.2.070518 = german ; jpn 1.3.6.1.4.1.897.4.9.2.101614 = japanese ; esl 1.3.6.1.4.1.897.4.9.2.051912 = spanish ; zho 1.3.6.1.4.1.897.4.9.2.260815 = chinese ; kor 1.3.6.1.4.1.897.4.9.2.111518 = korean ; por 1.3.6.1.4.1.897.4.9.2.161518 = portuguese, portugue ; pol 1.3.6.1.4.1.897.4.9.2.161512 = polish ; tha 1.3.6.1.4.1.897.4.9.2.200801 = thai [collate] 1.3.6.1.4.1.897.4.9.3.39 = altnoacc 1.3.6.1.4.1.897.4.9.3.45 = altdict 1.3.6.1.4.1.897.4.9.3.46 = altnocsp 1.3.6.1.4.1.897.4.9.3.47 = scandict 1.3.6.1.4.1.897.4.9.3.48 = scannocp 1.3.6.1.4.1.897.4.9.3.50 = binary 1.3.6.1.4.1.897.4.9.3.51 = dictionary, dictiona 1.3.6.1.4.1.897.4.9.3.52 = nocase 1.3.6.1.4.1.897.4.9.3.53 = nocasepref, nocasepr 1.3.6.1.4.1.897.4.9.3.54 = noaccents, noaccent 1.3.6.1.4.1.897.4.9.3.55 = espdict 1.3.6.1.4.1.897.4.9.3.56 = espnocs 1.3.6.1.4.1.897.4.9.3.57 = espnoac 1.3.6.1.4.1.897.4.9.3.58 = rusdict 1.3.6.1.4.1.897.4.9.3.59 = rusnocs 1.3.6.1.4.1.897.4.9.3.60 = rusnocsnopref 1.3.6.1.4.1.897.4.9.3.63 = cyrdict 1.3.6.1.4.1.897.4.9.3.64 = cyrnocs 1.3.6.1.4.1.897.4.9.3.65 = cyrnocsnopref 1.3.6.1.4.1.897.4.9.3.69 = hundict 1.3.6.1.4.1.897.4.9.3.70 = hunnoac 1.3.6.1.4.1.897.4.9.3.71 = hunnocs 1.3.6.1.4.1.897.4.9.3.72 = turdict 1.3.6.1.4.1.897.4.9.3.73 = turnoac 1.3.6.1.4.1.897.4.9.3.74 = turnocs 1.3.6.1.4.1.897.4.9.3.80 = czedict 1.3.6.1.4.1.897.4.9.3.81 = czenoac 1.3.6.1.4.1.897.4.9.3.82 = czenocs [secmech] 1.3.6.1.4.1.897.4.6.1 = dce 1.3.6.1.4.1.897.4.6.2 = nds 1.3.6.1.4.1.897.4.6.3 = NTLM 1.3.6.1.4.1.897.4.6.6 = csfkrb5 ... |
| 30.06.2010, 11:10 |
Сергей Васкецов wrote: Ты можешь сервак не пытаться запускать, а запускать просто isql Если добъёшься, чтобы isql запускался, сервак тоже станет запускаться. проверь, чтобь в %SYBASE%\locales был бы каталог us_english. Если его нет -- сделай копию или хардлинк каталога english оттуда же с именем us_english. Posted via ActualForum NNTP Server 1.4 ... |
| 30.06.2010, 11:28 |
MasterZivЕсли его нет -- сделай копию или хардлинк каталога english оттуда же с именем us_english. Каталога не было и раньше работало без него. Сделал копию english - не помогло (без изменений). ... |
| 30.06.2010, 11:36 |
Сергей ВаскецовMasterZivЕсли его нет -- сделай копию или хардлинк каталога english оттуда же с именем us_english. Каталога не было и раньше работало без него. Сделал копию english - не помогло (без изменений). я бы скопировал содержимое Sybase.bat и батника запуска сервера в один файл и попробовал бы запустить ASE вручную этим файлом ... |
| 30.06.2010, 13:38 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2010604]: |
139ms |
32ms |
| others: | 215ms |
| total: | 421ms |
