Sybase ASE, трудности set option
почитал авторAdaptive Server Enterprise 15.0 > Reference Manual: Commands > Interactive SQL Commands Chapter 2: Interactive SQL Commands -------------------------------------------------------------------------------- set option Description Changes the values of Interactive SQL options. Syntax Syntax 1 set [ temporary] option [ user_id. | public. ]option_name = [ option_value ] user_id : identifier , string or hostvar option_name : identifier , string or hostvar Syntax 2 set permanent Syntax 3 set Parameters temporary indicates that the options you set are only for this session. option indicates that you are setting the subsequent option. user_id is ID of the user setting the option. public indicates that the option is being set for all users. option_name is the name of the option you are setting. option_value is the value of the option you are setting. identifier is the identifier you are using for the connection information. string is the string you are using for the connection information. hostvar is the variable information for the host name and port Usage set permanent in Syntax 2 saves all current Interactive SQL options. These settings are automatically established every time Interactive SQL is started for the current user ID. Syntax 3 displays all of the current option settings. If there are temporary options set for Interactive SQL or the database server, these are displayed; otherwise, the permanent option settings are displayed. -------------------------------------------------------------------------------- Copyright © 2005. Sybase Inc. All rights reserved. dbisql по команде set показывает список опций, где можно увидеть On_error, на попытку задать set option ON_ERROR='CONTINUE' равно как и set option BELL='on' dbisql отвечает 'ON_ERROR' (BELL) is not a recognized SET TRACING option. в гугле такой строчки нет, сайбез онлайн бук тоже не нашел. ... |
| 14.04.2011, 16:39 |
> dbisql по команде set показывает список опций, где можно увидеть On_error, > > > на попытку задать > set option ON_ERROR='CONTINUE' равно как и set option BELL='on' > > dbisql отвечает > > > 'ON_ERROR' (BELL) is not a recognized SET TRACING option. Подозреваю, что dbisql либо универсальный клиент для всех СУБД (от Sybase), либо клиент для ASA. В ASE такой опции нет. Posted via ActualForum NNTP Server 1.4 ... |
| 14.04.2011, 16:50 |
humpty1почитал авторAdaptive Server Enterprise 15.0 > Reference Manual: Commands > Interactive SQL Commands ..... dbisql отвечает isql и dbisql это две очень разные программы. ... |
| 14.04.2011, 17:34 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2010354]: |
58ms |
25ms |
| others: | 240ms |
| total: | 363ms |
