Ошибка при инсталяции Sybase
Добрый день Устанавливаю Sybase 12.5 на Suse 8. Может кто подскажет как побороть? Ругается так: (Jan 26, 2012 7:52:01 PM), Setup.product.install, com.sybase.ismp.ase.wizardbean.Log4jAppender, sis, (wizardbean.ServerPort) - The Specified LDAP config file '/sybase/OCS-12_5/config/libtcl.cfg' has no LDAP entries. (Jan 26, 2012 7:52:03 PM), Setup.product.install, com.sybase.ismp.ase.wizardbean.ExecCommandWithProgress$ExecCommandOutputHandler, err, Building Adaptive Server 'SRRS2MN1': (Jan 26, 2012 7:52:03 PM), Setup.product.install, com.sybase.ismp.ase.wizardbean.ExecCommandWithProgress$ExecCommandOutputHandler, err, Writing entry into directory services... (Jan 26, 2012 7:52:03 PM), Setup.product.install, com.sybase.ismp.ase.wizardbean.ExecCommandWithProgress$ExecCommandOutputHandler, err, Directory services entry complete. (Jan 26, 2012 7:52:03 PM), Setup.product.install, com.sybase.ismp.ase.wizardbean.ExecCommandWithProgress$ExecCommandOutputHandler, err, Building master device... (Jan 26, 2012 7:52:03 PM), Setup.product.install, com.sybase.ismp.ase.wizardbean.ExecCommandWithProgress$ExecCommandOutputHandler, err, sh: line 1: 7864 Segmentation fault /sybase/ASE-12_5/bin/dataserver -d/sybase/data/master.dat -b30M -z2k -sSRRS2MN1 -e/sybase/ASE-12_5/install/SRRS2MN1.log -T1623 -f >/tmp/sbGP8wBp 2>&1 (Jan 26, 2012 7:52:03 PM), Setup.product.install, com.sybase.ismp.ase.wizardbean.ExecCommandWithProgress$ExecCommandOutputHandler, err, Task failed ... |
| 26.01.2012, 21:03 |
Verify Certification: Adaptive Server Enterprise(ASE) 12.5.4 32-bit on Linux x86 is certified on SuSE 10 with a minimum of: kernel 2.6.13-15-smp (2) glibc 2.3.5-40 If the above is correct, then verify: 1. They are not trying to configure the server through the srvbuild utility (configure the server after it has been created) Change Request(CR) 455393: Installer (setup) fails to configure dataserver on some Linux distributions (NOT YET FIXED). Workaround: run the installer without configuring any servers. Users can then configure the servers after the installation by running the srvbuild or srvbuildres utility to build ASE. 2. There is an issue with the installer unsetting the LD_POINTER_GUARD environment variable, set LD_POINTER_GUARD = 1 and rerun the srvbuild ... |
| 27.01.2012, 13:20 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2010187]: |
60ms |
59ms |
| others: | 252ms |
| total: | 425ms |
