ASA 9.0.2 Репликация через FTP, ошибка Error: WSAETIMEDOUT, socket call timed out.
Есть локальная сеть 192.168.0.XX в ней сервер БД Win 2016 192.168.0.5, есть микротик в который приходит инет 192.168.0.9 есть фтп сервер 192.168.0.21 запускаю репликацию по фтп, внутри локальной сети все работает фтп по порту 45621. Порт 45621 проброшен. выношу одну из баз наружу (адрес соответственно меняю на свой статический внешний) и не пашет. вот лог по дебагу: I. 12/01 17:30:55. SQL Remote Message Agent Version 9.0.2.3951 I. 12/01 17:30:55. I. 12/01 17:30:55. Copyright © 1989-2007 Sybase, Inc. Portions Copyright © 2002-2007, iAnywhere Solutions, Inc. I. 12/01 17:30:55. All rights reserved. All unpublished rights reserved. I. 12/01 17:30:55. I. 12/01 17:30:55. This software contains confidential and trade secret information of I. 12/01 17:30:55. iAnywhere Solutions, Inc. Use, duplication or disclosure of the software and documentation I. 12/01 17:30:55. by the U.S. Government is subject to restrictions set forth in a license I. 12/01 17:30:55. agreement between the Government and iAnywhere Solutions, Inc. or I. 12/01 17:30:55. other written agreement specifying the Government's rights to use the I. 12/01 17:30:55. software and any applicable FAR provisions, for example, FAR 52.227-19. I. 12/01 17:30:55. I. 12/01 17:30:55. iAnywhere Solutions, Inc., One Sybase Drive, Dublin, CA 94568, USA I. 12/01 17:30:55. I. 12/01 17:30:55. SQL Remote Message Link Version 9.0.2.3951 I. 12/01 17:30:55. Connecting on port: "45621" I. 12/01 17:30:55. socket I. 12/01 17:30:55. connect I. 12/01 17:30:55. Getting server response: I. 12/01 17:30:55. 220 (vsFTPd 3.0.3) I. 12/01 17:30:55. USER ftpresurs I. 12/01 17:30:55. Getting server response: I. 12/01 17:30:55. 331 Please specify the password. I. 12/01 17:30:55. User accepted with a password needed. I. 12/01 17:30:55. PASS autoserch I. 12/01 17:30:55. Getting server response: I. 12/01 17:30:56. 230 Login successful. I. 12/01 17:30:56. Password Accepted. I. 12/01 17:30:56. PWD I. 12/01 17:30:56. Getting server response: I. 12/01 17:30:56. 257 "/home/ftpresurs" is the current directory I. 12/01 17:30:56. TYPE A N I. 12/01 17:30:56. Getting server response: I. 12/01 17:30:56. 200 Switching to ASCII mode. I. 12/01 17:30:56. Type set. I. 12/01 17:30:56. PASV I. 12/01 17:30:56. Getting server response: I. 12/01 17:30:56. 227 Entering Passive Mode (192,168,0,21,161,131). I. 12/01 17:30:56. PASV command accepted. I. 12/01 17:30:56. NLST CM1/ I. 12/01 17:30:56. socket I. 12/01 17:30:56. connect I. 12/01 17:31:17. closesocket I. 12/01 17:31:17. Error: WSAETIMEDOUT, socket call timed out. I. 12/01 17:31:17. The address given is invalid. The address must be a directory name with no path separators. I. 12/01 17:31:17. QUIT I. 12/01 17:31:17. Getting server response: I. 12/01 17:31:56. 425 Failed to establish connection. I. 12/01 17:31:56. Socket Closed in FTPClose. I. 12/01 17:31:56. closesocket БУДУ признателен, за любую помощь. ... |
| 01.12.2017, 18:55:44 |
dbimapb, Вообще это к сетевикам Такая же проблема была бы, если бы ты обычный ftp клиентом полез из инета на внутренний сервак Насколько я помню, там надо еще порты пассивного режима пробрасывать Посчитай порт вот тут 227 Entering Passive Mode (192,168,0,21,161,131). Он наверняка закрыт, а именно на нем ждет сервер дальнейшее взаимодействие с клиентом. А клиент пробится не может ... |
| 01.12.2017, 19:09:32 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2009630]: |
160ms |
28ms |
| others: | 191ms |
| total: | 423ms |
