2634110 - SDK and jConnect interoperability - SAP ASE
Помогите плиз получить содержимое статьи . Спасибо! ... |
| 17.09.2018, 12:00:45 |
Symptom Which SDK, and jConnect are compatible with different versions of SAP ASE? Environment SAP Adaptive Server Enterprise (ASE) SAP Adaptive Server Enterprise (ASE) Software Developer Kit (SDK) jConnect Resolution The jConnect jdbc driver is part of SDK for SAP ASE. SAP ASE interoperability with jConnect: SAP ASE 12.5.4 - jConnect 5.5, jConnect 6.0.x SAP ASE 15.0 - jConnect 5.5, 6.0.5 SAP ASE 15.5 - jConnect 5.5, 6.0.x, and 7.0.x SAP ASE 15.7 - jConnect 6.0.x, and 7.0.x SAP ASE 16.0 - jConnect 7.0, and 16.0 SAP SDK and jConnect versions: SAP SDK 12.5.1 - comes with jConnect 5.5, contains jconn2.jar under the jConnect 5_5 subdirectory, works with java 1.3 SAP SDK 15.0 and 15.5 - comes with jConnect 6.0.5, contains jconn3.jar under the jConnect–6_0 subdirectory, works with java 1.4 and higher SAP SDK 15.5 - comes with jConnect 7.0.0, contains jconn4.jar under the jConnect-7_0 subdirectory, works with java 1.6 and higher SAP SDK 15.7 - comes with jConnect 7.0.7, contains jconn4.jar under the jConnect-7_0 subdirectory, works with java 1.6 and higher SAP SDK 16.0 - comes with jConnect 16.0, contains jconn4.jar under the jConnect-16_0 subdirectory, works with java 1.6 and higher Keywords certification, certified, supported ... |
| 17.09.2018, 13:15:19 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2009611]: |
195ms |
41ms |
| others: | 228ms |
| total: | 519ms |
