ssltcp listener does not start with ASE server starting
Есть проблемы при запуске ssl на sap ase 16.0 похожие симптомы ssltcp listener does not start with ASE server starting. ssltcp listener can be started with command: sp_listener 'start','ssltcp:<server_name>:<ssltcp_port>:"CN=<CommonName>"' нашел тут 2651483 - ssltcp listener does not start with ASE server starting( https://apps.support.sap.com/sap/support/knowledge/preview/en/2651483) но при переходе по ссылке требует логин и пароль от sap аккаунта. Может кто-то помочь ознакомиться с содержимым? ... |
| 13.11.2018, 13:07:59 |
spacemb, Symptom ssltcp listener does not start with ASE server starting. ssltcp listener can be started with command: sp_listener 'start','ssltcp:<server_name>:<ssltcp_port>:"CN=<CommonName>"' Environment Adaptive Server Enterprise (ASE) all version Cause There is one more entry of "<server_name>" without ssl in the interfaces(for Unix/Linux)/sql.ini(for Windows) file and it's location is before the ssl entry. <server_name> master tcp ether <host_name/ip address> <port> query tcp ether <host_name/ip address> <port> … <server_name> master tcp ether <host_name/ip address> <port> query tcp ether <host_name/ip address> <port> master tcp ether <host_name/ip address> <ssltcp_port> ssl="CN='<server_name>'" query tcp ether <host_name/ip address> <ssltcp_port> ssl="CN='<server_name>'" Resolution Remove the entry of "<server_name>" without ssl from the interfaces file. ... |
| 13.11.2018, 19:50:06 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2009604]: |
149ms |
28ms |
| others: | 198ms |
| total: | 415ms |
