Возможна ли установка PostgreSQL 7.4.2 на Solaris 8 на Sparc ?
А то пишет следующее : # make make -C doc all make[1]: Entering directory `/opt/install/sources/postgresql-7.4.2/doc' gzip -d -c man.tar.gz | /usr/sbin/tar xf - for file in man1/*.1; do \ mv $file $file.bak && \ sed -e 's/\\fR(l)/\\fR(5)/' $file.bak >$file && \ rm -f $file.bak || exit; \ done /bin/sh ../config/mkinstalldirs man5 mkdir man5 for file in manl/*.l; do \ sed -e '/^\.TH/s/"l"/"5sql"/' \ -e 's/\\fR(l)/\\fR(5)/' \ $file >man5/`basename $file | sed 's/.l$/.5sql/'` || exit; \ done make[1]: Leaving directory `/opt/install/sources/postgresql-7.4.2/doc' make -C src all make[1]: Entering directory `/opt/install/sources/postgresql-7.4.2/src' make -C port all make[2]: Entering directory `/opt/install/sources/postgresql-7.4.2/src/port' gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-declarations -I../../src/include -c -o isinf.o isinf.c gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-declarations -I../../src/include -c -o getopt_long.o getopt_long.c gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-declarations -I../../src/include -c -o qsort.o qsort.c gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-declarations -I../../src/include -c -o path.o path.c gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-declarations -I../../src/include -c -o sprompt.o sprompt.c gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-declarations -I../../src/include -c thread.c ar crs libpgport.a isinf.o getopt_long.o qsort.o path.o sprompt.o thread.o make[2]: ar: Command not found make[2]: *** [libpgport.a] Error 127 make[2]: Leaving directory `/opt/install/sources/postgresql-7.4.2/src/port' make[1]: *** [all] Error 2 make[1]: Leaving directory `/opt/install/sources/postgresql-7.4.2/src' make: *** [all] Error 2 # ... |
| 01.06.2004, 18:27:58 |
в солярисах я не копенгаген, но в линухе ar - это из gnu binutils соответственно вопрос - стоят ли эти binutils или же их солярисный аналог ... |
| 01.06.2004, 18:52:57 |
вдогонку - судя вот по этому: http://mailman.cs.uchicago.edu/pipermail/swig/2002-October/006030.html find / -name ar вполне может помочь ;) ... |
| 01.06.2004, 18:57:29 |
Спасибо, про ar я не знал... Аналоги binutils в соляре есть, как оказалось, лежат в /usr/ccs/bin На www.sunfreeware.com советуют ставить гнутый вариант. Ща скачаю, поставлю... Может действительно поможет. ... |
| 01.06.2004, 19:08:46 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2007839]: |
51ms |
42ms |
| others: | 196ms |
| total: | 330ms |
