опять трабл с initdb на Соляре 8 у PgSQL 7.4.2
Вот : # /usr/local/pgsql/bin/initdb -D /export/spare/pgsql_db/data The files belonging to this database system will be owned by user "postgres". This user must also own the server process. The database cluster will be initialized with locale C. fixing permissions on existing directory /export/spare/pgsql_db/data... ok creating directory /export/spare/pgsql_db/data/base... ok creating directory /export/spare/pgsql_db/data/global... ok creating directory /export/spare/pgsql_db/data/pg_xlog... ok creating directory /export/spare/pgsql_db/data/pg_clog... ok selecting default max_connections... 20 selecting default shared_buffers... 100 creating configuration files... ok creating template1 database in /export/spare/pgsql_db/data/base/1... ok initializing pg_shadow... ok enabling unlimited row size for system tables... ok initializing pg_depend... ok creating system views... ok loading pg_description... ok creating conversions... ERROR: could not load library "/usr/local/pgsql/lib/ascii_and_mic.so": ld.so.1: /usr/local/pgsql/bin/postgres: fatal: libgcc_s.so.1: open failed: No such file or directory initdb: failed Постгрес вообще на солярку нормально становится ? Библиотеки на месте !!! Помогите, кто-нибудь, кто ставил PostgreSQL на Соляру. Может где ссылочку сделать ? ... |
| 07.06.2004, 18:46:22 |
Вот еще : # echo $PATH /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin # find / -name ld.so.1 /usr/lib/sparcv9/ld.so.1 /usr/lib/ld.so.1 /etc/lib/ld.so.1 # find / -name ascii_and_mic.so /usr/local/pgsql/lib/ascii_and_mic.so # find / -name libgcc_s.so.1 /usr/local/lib/libgcc_s.so.1 /usr/local/lib/sparcv9/libgcc_s.so.1 ... |
| 07.06.2004, 18:57:20 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2007828]: |
42ms |
| others: | 224ms |
| total: | 341ms |
