GIST индексы бывают опасны
Если в многостолбцовом GIST индексе в первом столбце много неуникальных значений, начинаются глюки. При использовании btree_gist для varchar : вплоть до неверного(!!!!) результата select-а, использующего этот индекс. Не говоря уже о значительном росте времени на доавление. Here's smaller example of presentation bugs 1614 and 1616. Run on PostgreSQL 8.0.1/8.0.2 on Windows and PostgreSQL 8.0.1 on Slackware 10.0 (throw PGAdmin3) /* contrib/btree_gist installed */ /*tool function for drop table*/ create or replace function drop_try_gist() returns void as $$ begin begin drop table try_gist; exception when OTHERS then NULL; end; return; end; $$ language plpgsql; /*tool function for fill table*/ create or replace function fill_try_gist(fields text[][],counts int[]) returns void as $$ declare i int; j int; f_low int; f_upp int; comm text; commt text; begin f_low:=array_lower(fields,2); f_upp:=array_upper(fields,2); comm:='insert into try_gist ("'|| array_to_string(fields[1:1][f_low:f_upp],'","') || '") values ('; for i in array_lower(counts,1) .. array_upper(counts,1) loop commt=comm || array_to_string(fields[i+1 : i+1][f_low:f_upp],',') ||')'; for j in 1 .. counts loop execute replace(commt,'#$i$#',j::text); end loop; end loop; return; end; $$ language plpgsql; /*testing gist with text field*/ create or replace function create_try_gist_text() returns void as $$ begin perform drop_try_gist(); CREATE TABLE try_gist ( id serial NOT NULL, port varchar(30), phone varchar(30), CONSTRAINT try_gist_pkey PRIMARY KEY (id) ) WITHOUT OIDS; return; end; $$ language plpgsql; create or replace function try_gist_text() returns setof int as $$ declare i record; begin for i in execute '(select count(*) as c from try_gist where port=''two'' and phone='''')' loop return next i.c; end loop; execute 'create index ix_try_gist on try_gist using gist ((port::text),(phone::text) )'; for i in execute '(select count(*) as c from try_gist where port=''two'' and phone='''')' loop return next i.c; end loop; return; end; $$ language plpgsql; set enable_seqscan=off; select create_try_gist_text(); select fill_try_gist('{{"port","phone"},{"''''","''#$i$#''"},{"''two''","''''"}}','{2225,21}'); select * from try_gist_text(); /*returns try_gist_text(int4) ------------------- 21 21 */ select create_try_gist_text(); select fill_try_gist('{{"port","phone"},{"''two''","''''"},{"''''","''#$i$#''"}}','{21,2225}'); select * from try_gist_text(); /*returns try_gist_text(int4) ------------------- 21 0 */ vacuum full verbose try_gist; /* Postgres 8.0.2 Windows INFO: vacuuming "public.try_gist" INFO: "try_gist": found 0 removable, 2246 nonremovable row versions in 15 pages DETAIL: 0 dead row versions cannot be removed yet. Nonremovable row versions range from 45 to 48 bytes long. ... INFO: index "ix_try_gist" now contains 2246 row versions in 430 pages !!! DETAIL: 0 index pages have been deleted, 0 are currently reusable. ... */ /* Postgres 8.0.1 Slackware 10.0 NFO: vacuuming "public.try_gist" INFO: "try_gist": found 0 removable, 2246 nonremovable row versions in 14 pages DETAIL: 0 dead row versions cannot be removed yet. ... INFO: index "ix_try_gist" now contains 2246 row versions in 628 pages !!! DETAIL: 0 index pages have been deleted, 0 are currently reusable. ... */ create or replace function create_try_gist_int4() returns void as $$ begin perform drop_try_gist(); CREATE TABLE try_gist ( id serial NOT NULL, portn int4, phonen int4, CONSTRAINT try_gist_pkey PRIMARY KEY (id) ) WITHOUT OIDS; return; end; $$ language plpgsql; create or replace function try_gist_int4() returns setof int as $$ declare i record; begin for i in execute '(select count(*) as c from try_gist where portn=10 and phonen=0)' loop return next i.c; end loop; execute 'create index ix_try_gist on try_gist using gist ( portn,phonen )'; for i in execute '(select count(*) as c from try_gist where portn=10 and phonen=0)' loop return next i.c; end loop; return; end; $$ language plpgsql; select create_try_gist_int4(); select fill_try_gist('{{"portn","phonen"},{"0","#$i$#"},{"10","0"}}','{2225,21}'); select * from try_gist_int4(); /*returns right, but works (on creating index) 6 seconds in 8.0.2/Windows and >18 seconds on 8.0.1/Slackware*/ vacuum full verbose try_gist; /* Postgres 8.0.2 Windows INFO: vacuuming "public.try_gist" INFO: "try_gist": found 0 removable, 2246 nonremovable row versions in 15 pages DETAIL: 0 dead row versions cannot be removed yet. INFO: index "ix_try_gist" now contains 2246 row versions in 7603 pages !!!!!!!! DETAIL: 0 index pages have been deleted, 0 are currently reusable. */ /* Postgres 8.0.1 Slackware 10.0 INFO: vacuuming "public.try_gist" INFO: "try_gist": found 0 removable, 2246 nonremovable row versions in 13 pages DETAIL: 0 dead row versions cannot be removed yet. ... INFO: index "ix_try_gist" now contains 2246 row versions in 7603 pages DETAIL: 0 index pages have been deleted, 0 are currently reusable. */ Пример корявый, но то,что нужно показывает. Эфект не повторился для contrib/seg (хотя, может не внимательно смотрел). Эфект разрастания индекса и времени инсерта повторился для contrib/intarray: окончания вставки 20000 строк я не дождался за 10 минут. Интересно, что в примере для text ( где пропадают строки), если делать select только по полю port, строки видны. Кроме того в реальных данных (на которых столкнулся с глюком) пропала также одна строчка, где port="" и phone<>"" !!!! Писал я письма в pqsql-bugs, просил хотя бы ответить, что баг замечен, ведутся работы - не ответили. Начинаю рассылку по форумам. Если кто реально знаком с разработчиками, прошу обратить их внимание на проблему. Приветствутся ссылки на другие уважаемые форумы PostgreSQL. Может я паникер? ... |
| 13.05.2005, 18:07 |
GiST support ведется ребятами отсюда: http://www.sai.msu.su/~megera/postgres/gist/ Напиши им лично - ответят (мне всегда отвечали). ... |
| 22.07.2005, 11:26 |
Потеря данных в селекте не наблюдается в версии 8.0.3. Так что я спокоен. Огромный размер индекса остался (в данном частном случае : первая колонка слабо уникальна), но я понял, что работы ведутся, подождем версии 8.1. ... |
| 27.07.2005, 10:16 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2007105]: |
58ms |
37ms |
| others: | 241ms |
| total: | 391ms |
