Поиск в таблице по значения в массиве БУДЕТ !!!!!!!!!!!!!!!!!!!!!!!!!!
pgsql-hackers (at) postgresql (dot) org Сообщение Markus Schiltknecht <markus ( at ) bluegap ( dot ) ch> writes: > I'm trying to speed up a query with a lookup table. This lookup table > gets very big and should still fit into memory. It does not change very > often. Given these facts I decided to use an array, as follows: > CREATE TABLE lookup_table (id INT PRIMARY KEY, items INT[] NOT NULL); > I know this is not considered good database design, but it saves a lot > of overhead for tuple visibility compared to a 1:1 table. > To fetch an item via the lookup_table I tried to use the following > query: > SELECT i.id, i.title FROM item i > JOIN lookup_table lut ON i.id = ANY(lut.items) > WHERE lut.id = $LOOKUP_ID; > Unfortunately that one seems to always use a sequential scan over items. FWIW, "indexcol = ANY(array)" searches are indexable in CVS tip. There's no hope in any existing release though :-( > I tried to circumvent the problem with generate_series: > SELECT i.id, i.title FROM generate_series(0, $MAX) s > JOIN lookup_table lut ON s = ANY(lut.items) > JOIN item i ON s = i.id > WHERE lut.id = $LOOKUP_ID; Seems like the hard way --- why aren't you searching over array subscripts? SELECT i.id, i.title FROM generate_series(1, $MAX) s JOIN lookup_table lut ON s <= array_upper(lut.items) JOIN item i ON i.id = lut.items[s] WHERE lut.id = $LOOKUP_ID; $MAX need only be as large as the widest array in lookup_table. regards, tom lane Ура Ура Ура Ура Ура Ура Ура Ура Ура Ура Ура Ура Интересно, а у оракла или mssql или db2 такое есть/будет ? (извините за детский глупый вопрос) ... |
| 28.02.2006, 20:23 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2006604]: |
98ms |
29ms |
| others: | 230ms |
| total: | 400ms |
