что за interrupted
Что за interrupted вылезает в логах? Работа происходит с 1 таблицей (только insert), работает работает и тут бац такое, после этого sequence_id в таблице подскакивает ровно на 33 вперёд. version PostgreSQL 7.4.7 on i386-pc-linux-gnu, compiled by GCC i386-linux-gcc (GCC) 3.3.5 (Debian 1:3.3.5-12) 2006-03-03 09:06:34 [1593] LOG: database system was interrupted at 2006-03-03 09:02:14 MSK 2006-03-03 09:06:34 [1593] LOG: checkpoint record is at 0/7FB3FB0 2006-03-03 09:06:34 [1593] LOG: redo record is at 0/7FB3FB0; undo record is at 0/0; shutdown FALSE 2006-03-03 09:06:34 [1593] LOG: next transaction ID: 238024; next OID: 229904 2006-03-03 09:06:34 [1593] LOG: database system was not properly shut down; automatic recovery in progress 2006-03-03 09:06:34 [1593] LOG: redo starts at 0/7FB4010 2006-03-03 09:06:34 [1593] LOG: record with zero length at 0/7FB8198 2006-03-03 09:06:34 [1593] LOG: redo done at 0/7FB8174 2006-03-03 09:06:37 [1593] LOG: database system is ready 2006-03-03 09:06:40 [1629] LOG: connection received: host=[local] port= 2006-03-03 09:06:40 [1629] LOG: connection authorized: user=root database=esme 2006-03-03 10:02:02 [1760] LOG: connection received: host=[local] port= 2006-03-03 10:02:02 [1760] LOG: connection authorized: user=postgres database=template1 2006-03-03 10:02:03 [1769] LOG: connection received: host=[local] port= 2006-03-03 10:02:03 [1769] LOG: connection authorized: user=postgres database=template1 2006-03-03 10:02:03 [1770] LOG: connection received: host=[local] port= 2006-03-03 10:02:03 [1770] LOG: connection authorized: user=postgres database=esme 2006-03-03 10:02:05 [1771] LOG: connection received: host=[local] port= 2006-03-03 10:02:05 [1771] LOG: connection authorized: user=postgres database=template1 2006-03-03 10:12:04 [1773] LOG: recycled transaction log file "0000000000000007" 2006-03-03 10:31:17 [1588] LOG: database system was interrupted at 2006-03-03 10:27:10 MSK 2006-03-03 10:31:17 [1588] LOG: checkpoint record is at 0/80AE7B0 2006-03-03 10:31:17 [1588] LOG: redo record is at 0/80AE7B0; undo record is at 0/0; shutdown FALSE 2006-03-03 10:31:17 [1588] LOG: next transaction ID: 238250; next OID: 238096 2006-03-03 10:31:17 [1588] LOG: database system was not properly shut down; automatic recovery in progress 2006-03-03 10:31:17 [1588] LOG: redo starts at 0/80AE7F0 2006-03-03 10:31:17 [1588] LOG: record with zero length at 0/80B2978 2006-03-03 10:31:17 [1588] LOG: redo done at 0/80B2954 2006-03-03 10:31:20 [1588] LOG: database system is ready ... |
| 05.03.2006, 05:07 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2006591]: |
73ms |
55ms |
| others: | 262ms |
| total: | 448ms |
