[Sysadmins] [sisyphus] postgresql (emaphores (SEMMNS), would be exceeded)
rpm -qa | grep postgresql postgresql-7.4.9-alt1.1 postgresql-server-7.4.9-alt1.1 # tcpip_socket = true max_connections = 100 # note: increasing max_connections costs about 500 bytes of shared # memory per connection slot, in addition to costs from shared_buffers # and max_locks_per_transaction. #superuser_reserved_connections = 2 #port = 5432 # unix_socket_directory = '/var/sockets' #unix_socket_group = 'sockets' #unix_socket_permissions = 0777 # octal #virtual_host = '' # what interface to listen on; defaults to any #rendezvous_name = '' # defaults to the computer name postgres[14947]: [1-1] LOG: could not create IPv6 socket: Address family not supported by protocol postgres[14947]: [2-1] FATAL: could not create semaphores: No space left on device postgres[14947]: [2-2] DETAIL: Failed system call was semget(5432018, 17, 03600). postgres[14947]: [2-3] HINT: This error does *not* mean that you have run out of disk space. postgres[14947]: [2-4] ^IIt occurs when either the system limit for the maximum number of semaphore sets (SEMMNI), or the system wide maximum number of postgres[14947]: [2-5] semaphores (SEMMNS), would be exceeded. You need to raise the respective kernel parameter. Alternatively, reduce PostgreSQL's postgres[14947]: [2-6] consumption of semaphores by reducing its max_connections parameter (currently 512). postgres[14947]: [2-7] ^IThe PostgreSQL documentation contains more information about configuring your system for PostgreSQL. postgres[14947]: [3-1] LOG: shmctl(25755662, 0, 0) failed: Invalid argument postgresql: failed Как с этим бороться ? max_connections = 100 если уменьшить до 100 конектов то postgresql стартует но вот это остается : LOG: could not create IPv6 socket: Address family not supported by protocol И как всетаки решить проблему целиком ? ... |
| 10.05.2006, 20:21 |
дамп тоже сделать не получается: pg_dumpall > outfile pg_dumpall: could not connect to database "template1": could not connect to server: No such file or directory Is the server running locally and accepting connections on Unix domain socket "/tmp/.s.PGSQL.5432"? в логах есть: postgres[13098]: [4-1] FATAL: could not open file "/var/lib/pgsql/data/global/1262": Permission denied postgres[12961]: [8-1] LOG: could not open temporary statistics file "/var/lib/pgsql/data/global/pgstat.tmp.12946": Permission denied ... |
| 10.05.2006, 22:48 |
Zloipostgres[14947]: [2-7] ^IThe PostgreSQL documentation contains more information about configuring your system for PostgreSQL. Zloi, не злись. Тебе вель говорят - смотри доку. В документации к 8.1 это раздел 16.4.1. Кстати, а почему ты 7.4 юзаешь? ... |
| 11.05.2006, 09:05 |
что делать с этим : дамп тоже сделать не получается: pg_dumpall > outfile pg_dumpall: could not connect to database "template1": could not connect to server: No such file or directory Is the server running locally and accepting connections on Unix domain socket "/tmp/.s.PGSQL.5432"? в логах есть: postgres[13098]: [4-1] FATAL: could not open file "/var/lib/pgsql/data/global/1262": Permission denied postgres[12961]: [8-1] LOG: could not open temporary statistics file "/var/lib/pgsql/data/global/pgstat.tmp.12946": Permission denied ... |
| 11.05.2006, 10:00 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2006397]: |
34ms |
| others: | 244ms |
| total: | 334ms |
