Askanor
CREATE OR REPLACE FUNCTION "public"."GET_TUNING_INFO" ("GROUP_ID111" boolean, out "GROUPID" integer, out "PARAMNAME" "public"."VARCHAR_20", out "INTVAL" integer, inout "STRVAL" text, out "NUMVAL" money, out "DESCRIPTION" text) RETURNS "pg_catalog"."record" AS $body$ DECLARE tun_rec record; BEGIN "DESCRIPTION" := 'asd'; RETURN; END; $body$ LANGUAGE 'plpgsql' VOLATILE RETURNS NULL ON NULL INPUT SECURITY INVOKER; подскажите новичку, почему функция компилируется а на вызов select * from "public"."GET_TUNING_INFO"(True)--, 'CheckStatusSec') ругается что: ERROR: function public.GET_TUNING_INFO(boolean) does not exist HINT: No function matches the given name and argument types. You may need to add explicit type casts. ... |
| 18.09.2006, 07:15 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2006097]: |
58ms |
48ms |
| others: | 228ms |
| total: | 393ms |
