Запрос
Всем привет! Tables: CREATE TABLE "public"."baseline" ( "baseline_pk" INTEGER NOT NULL, "fromdatetime" TIMESTAMP WITH TIME ZONE NOT NULL, "todatetime" TIMESTAMP WITH TIME ZONE NOT NULL, CONSTRAINT "baseline_fromdatetime_ukc" UNIQUE("fromdatetime"), CONSTRAINT "baseline_pkc" PRIMARY KEY("baseline_pk"), CONSTRAINT "baseline_todatetime_ukc" UNIQUE("todatetime") ) CREATE TABLE "public"."task" ( "task_pk" INTEGER NOT NULL, "sourcesystem_fk" INTEGER NOT NULL, CONSTRAINT "task_pkc" PRIMARY KEY("task_pk"), CONSTRAINT "task_sourcesystem_fkc" FOREIGN KEY ("sourcesystem_fk") REFERENCES "public"."sourcesystem"("sourcesystem_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE ) CREATE TABLE "public"."plantaskrelation" ( "plantaskrelation_pk" INTEGER NOT NULL, "plan_fk" INTEGER NOT NULL, "from_baseline_fk" INTEGER NOT NULL, "to_baseline_fk" INTEGER NOT NULL, "parent_task_fk" INTEGER, "child_task_fk" INTEGER NOT NULL, "taskrelationtype_fk" INTEGER NOT NULL, "treenodehash" VARCHAR(246) NOT NULL, CONSTRAINT "plantaskrelation_1_ukc" UNIQUE("plan_fk", "from_baseline_fk", "treenodehash"), CONSTRAINT "plantaskrelation_2_ukc" UNIQUE("plan_fk", "to_baseline_fk", "parent_task_fk", "child_task_fk"), CONSTRAINT "plantaskrelation_pkc" PRIMARY KEY("plantaskrelation_pk"), CONSTRAINT "plantaskrelation_child_task_fkc" FOREIGN KEY ("child_task_fk") REFERENCES "public"."task"("task_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE, CONSTRAINT "plantaskrelation_from_baseline_fkc" FOREIGN KEY ("from_baseline_fk") REFERENCES "public"."baseline"("baseline_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE, CONSTRAINT "plantaskrelation_parent_task_fkc" FOREIGN KEY ("parent_task_fk") REFERENCES "public"."task"("task_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE, CONSTRAINT "plantaskrelation_plan_fkc" FOREIGN KEY ("plan_fk") REFERENCES "public"."plan"("plan_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE, CONSTRAINT "plantaskrelation_taskrelationtype_fkc" FOREIGN KEY ("taskrelationtype_fk") REFERENCES "public"."taskrelationtype"("taskrelationtype_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE, CONSTRAINT "plantaskrelation_to_baseline_fkc" FOREIGN KEY ("to_baseline_fk") REFERENCES "public"."baseline"("baseline_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE ) CREATE TABLE "public"."baselinedtask" ( "baselinedtask_pk" INTEGER NOT NULL, "task_fk" INTEGER NOT NULL, "from_baseline_fk" INTEGER NOT NULL, "to_baseline_fk" INTEGER NOT NULL, "tasktype_fk" INTEGER NOT NULL, "primary_plan_fk" INTEGER NOT NULL, "sourcereference" VARCHAR(40) NOT NULL, "name" VARCHAR(254) NOT NULL, CONSTRAINT "baselinedtask_1_ukc" UNIQUE("task_fk", "from_baseline_fk"), CONSTRAINT "baselinedtask_2_ukc" UNIQUE("task_fk", "to_baseline_fk"), CONSTRAINT "baselinedtask_pkc" PRIMARY KEY("baselinedtask_pk"), CONSTRAINT "baselinedtask_from_baseline_fkc" FOREIGN KEY ("from_baseline_fk") REFERENCES "public"."baseline"("baseline_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE, CONSTRAINT "baselinedtask_primary_plan_fkc" FOREIGN KEY ("primary_plan_fk") REFERENCES "public"."plan"("plan_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE, CONSTRAINT "baselinedtask_task_fkc" FOREIGN KEY ("task_fk") REFERENCES "public"."task"("task_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE, CONSTRAINT "baselinedtask_to_baseline_fkc" FOREIGN KEY ("to_baseline_fk") REFERENCES "public"."baseline"("baseline_pk") ON DELETE RESTRICT ON UPDATE RESTRICT NOT DEFERRABLE ) Задача: выбрать PlanTaskRelation (PTR), BaselinedTask (BT), Task (T) указав: planPk, baselinePk, sourcesystemPk, такие чтоб: PTR содержал в поле childTaskFk ссылку на T, BT содержал в поле taskFk ссылку на T, PTR & BT были бы внутри указанного Baseline`a (Bactive), по датам from-to, ниже виден кусочек запроса: " AND Bactive.fromDateTime <= PTR_to.toDateTime " + " AND Bactive.toDateTime > PTR_Bfrom.fromDateTime " + " AND BT.fromBaselineFk = PTR_Bfrom.baselinePk " + " AND BT.toBaselineFk = PTR_Bto.baselinePk " у меня это всё безобразие просто связывается по датам и Pk, работает ДОЛГО! (пример из Hibernate`a : " SELECT DISTINCT PTR_whereChild, BT, Tparent FROM "+ " lv.ctco.taskods.domain.task.PlanTaskRelation as PTR_whereChild, " + " lv.ctco.taskods.domain.task.PlanTaskRelation as PTR_parentChild, " + " lv.ctco.taskods.domain.task.Task as Tparent, " + " lv.ctco.taskods.domain.task.Task as Tchild, " + " lv.ctco.taskods.domain.task.BaselinedTask as BT, " + " lv.ctco.taskods.domain.common.Baseline as Bactive, " + " lv.ctco.taskods.domain.common.Baseline as Bfrom_parentChild, " + " lv.ctco.taskods.domain.common.Baseline as Bto_parentChild, " + " lv.ctco.taskods.domain.common.Baseline as Bfrom_whereChild, " + " lv.ctco.taskods.domain.common.Baseline as Bto_whereChild, " + " lv.ctco.taskods.domain.common.Baseline as Bfrom_BT, " + " lv.ctco.taskods.domain.common.Baseline as Bto_BT " + " WHERE " + // init Active Baseline by PK " Bactive.baselinePk = :activeBaselinePk " + // Select PTR by planFk, childTaskFk " AND PTR_whereChild.childTaskFk = Tparent.taskPk " + " AND PTR_whereChild.planFk = :planFk " + // and given PTR are inside active baseline " AND PTR_whereChild.fromBaselineFk = Bfrom_whereChild.baselinePk "+ " AND PTR_whereChild.toBaselineFk = Bto_whereChild.baselinePk "+ " AND Bactive.fromDateTime <= Bto_whereChild.toDateTime " + " AND Bactive.toDateTime > Bfrom_whereChild.fromDateTime "+ // Select PTR by childTaskFk, parentTaskFk, planFk " AND PTR_parentChild.childTaskFk = Tchild.taskPk " + " AND PTR_parentChild.parentTaskFk = Tparent.taskPk " + " AND Tchild.sourceSystem = " + SourceSystem.ATLASSIAN_JIRA.getSourceSystemPk() + " " + " AND Tparent.sourceSystem = " + SourceSystem.MS_PROJECT.getSourceSystemPk() + " " + " AND PTR_parentChild.planFk = :planFk " + // and given PTR are inside active baseline " AND PTR_parentChild.fromBaselineFk = Bfrom_parentChild.baselinePk " + " AND PTR_parentChild.toBaselineFk = Bto_parentChild.baselinePk " + " AND Bactive.fromDateTime <= Bto_parentChild.toDateTime " + " AND Bactive.toDateTime > Bfrom_parentChild.fromDateTime " + // link ActiveBaseline and ParentTask to BaselinedTask (we will need it later to create TaskModel) // Select BT by taskFk, primaryPlanFk " AND BT.taskFk = Tparent.taskPk " + " AND BT.primaryPlanFk = :planFk " + // and given BT are inside activeBaseline " AND Bactive.fromDateTime <= Bto_BT.toDateTime " + " AND Bactive.toDateTime > Bfrom_BT.fromDateTime " + " AND BT.fromBaselineFk = Bfrom_BT.baselinePk " + " AND BT.toBaselineFk = Bto_BT.baselinePk " ) Вопрос: варианты оптимизации? ... |
| 18.10.2006, 19:27 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2006029]: |
147ms |
| others: | 235ms |
| total: | 452ms |
