powered by simpleCommunicator - 2.0.60     © 2026 Programmizd 02
Форумы / PostgreSQL [игнор отключен] [закрыт для гостей] / Поясните разницу между Vacuum и Vacuum analyze
2 сообщений из 2, страница 1 из 1
    #34581154
nedba
Сталкнулся с PG совсем недавно. Доки читал усилено.
Но так и не понял разницы между Vacuum и Vacuum analyze.
Vacuum analyze - включает ли в себя Vacuum или надо выполнять сначала Vacuum, а потом Vacuum analyze? Или как вариант Vacuum, а потом Vacuum analyze, потом Vacuum Full для таблицы?
Поясните разницу, те кто знают...
    #34581290
assa
VACUUMName
VACUUM — garbage-collect and optionally analyze a database
VACUUM ANALYZE performs a VACUUM and then an ANALYZE for each selected table. This is a handy combination form for routine maintenance scripts. See ANALYZE* for more details about its processing.
Plain VACUUM (without FULL) simply reclaims space and makes it available for re-use. This form of the command can operate in parallel with normal reading and writing of the table, as an exclusive lock is not obtained. VACUUM FULL does more extensive processing, including moving of tuples across blocks to try to compact the table to the minimum number of disk blocks. This form is much slower and requires an exclusive lock on each table while it is being processed.
*ANALYZE Name
ANALYZE — collect statistics about a database
Synopsis
ANALYZE [ VERBOSE ] [ table [ (column [, ...] ) ] ]
