uuid не ставится: как?
вроде все по напсианому делаю, выполяю скрипт, но получаю: postgres@s-postresql:/usr/share/postgresql/8.2/contrib$ psql -U postgres -d template1 -f /usr/share/postgresql/8.2/contrib/uuid.sql SET psql:/usr/share/postgresql/8.2/contrib/uuid.sql:7: NOTICE: type "uuid" is not yet defined DETAIL: Creating a shell type definition. psql:/usr/share/postgresql/8.2/contrib/uuid.sql:7: ERROR: incompatible library "/usr/lib/postgresql/8.2/lib/uuid.so": missing magic block HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro. psql:/usr/share/postgresql/8.2/contrib/uuid.sql:13: ERROR: type uuid does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:19: ERROR: function uuid_in(cstring) does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:22: ERROR: type "uuid" does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:33: ERROR: type uuid does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:40: ERROR: type uuid does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:47: ERROR: type uuid does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:54: ERROR: type uuid does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:61: ERROR: type uuid does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:68: ERROR: type uuid does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:84: ERROR: type "uuid" does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:93: ERROR: type "uuid" does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:104: ERROR: type "uuid" does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:113: ERROR: type "uuid" does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:122: ERROR: type "uuid" does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:132: ERROR: type "uuid" does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:140: NOTICE: type "uuid" is not yet defined DETAIL: Creating a shell type definition. psql:/usr/share/postgresql/8.2/contrib/uuid.sql:140: ERROR: incompatible library "/usr/lib/postgresql/8.2/lib/uuid.so": missing magic block HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro. psql:/usr/share/postgresql/8.2/contrib/uuid.sql:155: NOTICE: type "uuid" is not yet defined DETAIL: Creating a shell type definition. psql:/usr/share/postgresql/8.2/contrib/uuid.sql:155: ERROR: incompatible library "/usr/lib/postgresql/8.2/lib/uuid.so": missing magic block HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro. psql:/usr/share/postgresql/8.2/contrib/uuid.sql:162: NOTICE: type "uuid" is not yet defined DETAIL: Creating a shell type definition. psql:/usr/share/postgresql/8.2/contrib/uuid.sql:162: ERROR: incompatible library "/usr/lib/postgresql/8.2/lib/uuid.so": missing magic block HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro. psql:/usr/share/postgresql/8.2/contrib/uuid.sql:170: ERROR: type uuid does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:186: ERROR: type "uuid" does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:207: ERROR: type uuid does not exist psql:/usr/share/postgresql/8.2/contrib/uuid.sql:214: ERROR: type uuid does not exist postgres@s-postresql:/usr/share/postgresql/8.2/contrib$ ... |
| 27.08.2007, 19:52 |
Winnipuhпорешил.Рассказал бы. Вдруг у кого еще такое же будет ... |
| 28.08.2007, 12:05 |
pamir Winnipuhпорешил.Рассказал бы. Вдруг у кого еще такое же будет рассказ участника событий: 1. месяц назад ставил 8.2.4 и в него добавлял uuid - все прошло без вмешательства, как напсиано, скомпилировал, выполнил скрипт - сработало. 2. вчера начал ставить - получил ошибку (см. выше), перекомпилировал - та же фигня. Порылся, нашел, руками в uuid.c файл дописал #ifdef PG_MODILE_MAGIC PG_MODILE_MAGIC; #endif пересобрал, выполнил скрипт - прошло. Т.е постгрес стал требовать в расширенных so такого контекста, а автор uuid видимо "забил" на него давно. В 8.3 uuid уже будет встроенным типом, так что.... ... |
| 28.08.2007, 12:22 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2005112]: |
59ms |
60ms |
| others: | 250ms |
| total: | 429ms |
