Какая функция преобразовывает из string в Integer?
Какая функция преобразовывает из string в Integer? ... |
| 28.08.2007, 17:36 |
4.2.8. Type Casts A type cast specifies a conversion from one data type to another. PostgreSQL accepts two equivalent syntaxes for type casts: CAST ( expression AS type ) expression::type The CAST syntax conforms to SQL; the syntax with :: is historical PostgreSQL usage. ... |
| 28.08.2007, 17:48 |
start [/forum/topic.php?fid=53&gotonew=1&tid=2005108]: |
41ms |
34ms |
| others: | 256ms |
| total: | 379ms |
