Форумы / PostgreSQL [игнор отключен] [закрыт для гостей] / Не могу вызвать функцию(((
6 сообщений из 6, страница 1 из 1
    #39117898
IPmen
Есть функция
Код: plsql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
--select "fnc_create_object"('ddd','ddd','7b70cf00-969e-11e5-8e18-02c2c61bc579', true,'sss')
CREATE OR REPLACE FUNCTION  fnc_create_object
	 _ContextName varchar(50),
	 _ObjectType varchar(50),
	 _OwnerId uuid,
	 _Accessed boolean,
	 _Attributes varchar(50)
RETURNS uuid  AS
$BODY$
DECLARE
 returnid uuid;
 BEGIN
	insert into "Objects"
		"ContextName",
		"ObjectType",
		"OwnerId",
		"Created",
		"Updated",
		"Accessed",
		"Attributes"
	values
		_ContextName,
		_ObjectType,
		_OwnerId,
		CURRENT_TIMESTAMP,
		CURRENT_TIMESTAMP,
		_Accessed,
		_Attributes
	) RETURNING "Id" INTO returnid ;
	return returnid;
end
$BODY$
LANGUAGE 'plpgsql'
вызываю
Код: c#
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
 _objectRepository.Insert(speedUpObject, "public.fnc_create_object", sqlTransaction);
 public Guid Insert(T entity, string insertSql, NpgsqlTransaction sqlTransaction)
            Guid i;
            using (var cmd = _conn.CreateCommand())
                cmd.CommandText = insertSql;
                cmd.CommandType = CommandType.StoredProcedure;
                cmd.Transaction = sqlTransaction;
                InsertCommandParameters(entity, cmd);
                i = new Guid(cmd.ExecuteScalar().ToString());
            return i;
 protected override void InsertCommandParameters(Object entity, NpgsqlCommand cmd)
            var contextParameter = cmd.CreateParameter();
            contextParameter.ParameterName = "_ContextName";
            contextParameter.DbType = System.Data.DbType.String;
            contextParameter.Value = entity.ContextName;
            var ownerIdParameter = cmd.CreateParameter();
            ownerIdParameter.ParameterName = "_OwnerId";
            ownerIdParameter.DbType = System.Data.DbType.Guid;
            ownerIdParameter.Value = entity.OwnerId;
            var  accessedParameter = cmd.CreateParameter();
            accessedParameter.ParameterName = "_Accessed";
            accessedParameter.DbType = System.Data.DbType.Boolean;
            accessedParameter.Value = entity.Accessed;
            var attributesParameter = cmd.CreateParameter();
            attributesParameter.ParameterName = "_Attributes";
            attributesParameter.DbType = System.Data.DbType.String;
            attributesParameter.Value = entity.Attributes;
            var objectTypeParameter = cmd.CreateParameter();
            objectTypeParameter.ParameterName = "_ObjectType";
            objectTypeParameter.DbType = System.Data.DbType.String;
            objectTypeParameter.Value = entity.ObjectType;
Код: xml
1.
2.
 <add name="SpeedUpConnection" connectionString="Server=127.0.0.1;Port=5432;User Id=postgres;Password=1;Database=SpeedUp;Pooling=false"
       providerName="Npgsql" />
выдаёт ошибку
42883: function public.fnc_create_object() does not exist
    #39117936
Hawkmoon
Штатный телепат информирует, что в insertSql идет вызов функции без параметров.
И хоть заинформируй ты команду о своих createParams ах, если ты вызываешь ф-ю без параметров - и ее не существует, значит, ее не существует.
Ты создаешь параметры, создаешь параметры...
А какой SQL их юзает?
select fnc_create_object()?
Туши свет.
    #39118081
IPmen
Hawkmoon
Код: plsql
1.
HawkmoonИ хоть заинформируй ты команду о своих createParams ах, если ты вызываешь ф-ю без параметров - и ее не существует, значит, ее не существует.
не совсем понял я же создаю параметры
    #39118147
Фотография Maxim Boguk
IPmenHawkmoon
Код: plsql
1.
Ваш код никакие параметры в запрос не передает. Как надо делать так чтобы передавал - это вопрос не по PostgreSQL а по используемому вами языку программирования.
Maxim Boguk
www.postgresql-consulting.ru
    #39118862
Hawkmoon
IPmen,
Тебе PG черным по-белому говорит:
function public.fnc_create_object ( ) does not exist.
она может сказать также на:
select public.fnc_create_object(5)
функция public.fnc_create_object (integer) не существует
Или на:
select fnc_create_object('ddd','ddd','7b70cf00-969e-11e5-8e18-02c2c61bc579', true,'sss')
функция fnc_create_object (unknown, unknown, unknown, boolean, unknown) не существует
Но у тебя ругается именно на пустые скобки.
Следовательно - вызов в SQL - БЕЗ ПАРАМЕТРОВ.
Подсказка:
    #39118866
Hawkmoon
http://www.npgsql.org/doc/manual-2.2.html
ctrl-F -> Using parameters in a query
new NpgsqlCommand("select * from tablea where column1 = :value1 ", conn)
