RECURSIVE function
Собственно вопрос в следующем коллеги по цеху: делаю рекурсивный запрос, в результате запроса на экран ничего не выводится. Т.е. курсор создается в контексте функции, но он пустой. Отдельно проверял tabledata, на экран данные какие-то выводятся...а значит я не так сформировал рекурсию. Прошу прокомментировать. with recursive QW AS ( with tabledata as ( SELECT u.sn_index, (CASE WHEN coalesce(100,0)=0 then u.hi_sn_index ELSE (CASE WHEN u.sn_type=2 THEN null ELSE u.hi_sn_index END) END) as hi_sn_index, u.name, u.nn, a.cl_rezult from (SELECT sum(coalesce(a.cl_rezult,0)) as cl_rezult, u.sn_index from ((with recursive fg_tree as ( select sn_index, sn_index as objindex from n.usn where coalesce(d,0) = 0 union all select c.sn_index, p.objindex from n.usn as c join fg_tree p on p.sn_index = hi_sn_index ) select *from fg_tree )as u LEFT JOIN(select c.cl_objindex,sum(round(cast(c.cl_rezult as numeric),3)) as cl_rezult from d.dc_calculate as c, D.dc_typecalculate as t where coalesce(Cl_validate,0) =1 and t.tc_index = c.tc_index and c.cl_date = timestamp '2015-08-25' and c.ta_index =1 and c.tp_index and ((c.lpu_index = 100 ) or (coalesce(100,0) =0)) --iLPU_INDEX = 100 group by cl_objindex) as a ON (u.objindex =a.cl_objindex)) group by u.sn_index) as A, n.usn as u where a.sn_index = u.sn_index and coalesce(u.d,0)=0 and ((u.lpu_index = 100 ) or (coalesce(100,0) =0)) union all select t.tc_property*10000000000000+c.cl_objindex ,c.cl_objindex, g.gp_name,g.gp_nn, sum(round(coalesce(cast (cl_rezult as numeric),0),3)) as cl_rezult from d.dc_calculate as c, D.dc_typecalculate as t , n.gts_property as g where coalesce(Cl_validate,0) =1 and t.tc_index = c.tc_index and g.gp_index = t.tc_property and c.cl_date = timestamp '2015-08-25' and c.ta_index =1 and c.tp_index =20 and ((c.lpu_index = 100 ) or (coalesce(100,0) =0)) group by cl_objindex,t.tc_property, g.gp_name,g.gp_nn union all select 2000000000000000*c.tc_index+t.tc_property*10000000000+c.cl_objindex,t.tc_property*10000000000000+c.cl_objindex , t.tc_name, tc_nn , sum(round(coalesce(cast(cl_rezult as numeric),0),3)) as cl_rezult from d.dc_calculate as c, D.dc_typecalculate as t where coalesce(Cl_validate,0) =1 and t.tc_index = c.tc_index and c.cl_date = timestamp '2015-08-25' and 0 >=1 and c.ta_index =1 and c.tp_index =20 and ((c.lpu_index = 100 ) or (coalesce(100,0) =0)) group by cl_objindex,c.tc_index ,t.tc_property,t.tc_name, tc_nn) (select 1 as level, sn_index, hi_sn_index, WWW_REPORT.html_table(WWW_REPORT.html_trtd(to_char(cl_rezult,'9999999999999990.999'))) as q, ARRAY[nn] as path from tabledata where cl_rezult <>0 and coalesce(hi_sn_index::text, '') = '' order by nn) UNION ALL (select qw.level+1 as level, Z.sn_index, Z.hi_sn_index, WWW_REPORT.html_table(WWW_REPORT.html_trtd(to_char(Z.cl_rezult,'9999999999999990.999'))) as q, qw.path||z.nn from tabledata as Z JOIN QW ON QW.sn_index = Z.hi_sn_index ORDER BY NN)) select row_number () over () as N_num, f.* from (select WWW_REPORT.html_space((level-1)*5)||name as name, qw.* from qw, n.usn order by path) as f; END; $BODY$ LANGUAGE plpgsql; ... |
| 08.02.2016, 13:42 |
RECURSIVE function
Asew, "Ни мне, Сара, здравствуйте, ни тебе, Сара, до свидания" (сс) а где шапка ф--ии, и что сказано "во первыз строках ея письма" ? ... |
| 08.02.2016, 14:29 |
RECURSIVE function
Asew, Читайте документацию по plpgsql Судя по вашей функции PostgreSQL в принципе не должен что-то выводить. ... |
| 09.02.2016, 09:15 |
RECURSIVE function
qwwqAsew, "Ни мне, Сара, здравствуйте, ни тебе, Сара, до свидания" (сс) а где шапка ф--ии, и что сказано "во первыз строках ея письма" ? а зачем она ? ведь водится что-то или нет можно и простым селектом отдельно tabledata, а потом в составе рекурсивного запроса, где к ней идет обращение.Я сказал, что данные выводятся из tabledata, рекурсия неверно работает... ... |
| 09.02.2016, 11:41 |
RECURSIVE function
mad_nazgulAsew, Читайте документацию по plpgsql Судя по вашей функции PostgreSQL в принципе не должен что-то выводить. Спасибо кЭП=) я и написал, что ничего не выводит, неверна сама рекурсивная часть запроса. ... |
| 09.02.2016, 11:42 |
RECURSIVE function
AsewqwwqAsew, "Ни мне, Сара, здравствуйте, ни тебе, Сара, до свидания" (сс) а где шапка ф--ии, и что сказано "во первыХ строках ея письма" ? а зачем она ? ведь водится что-то или нет можно и простым селектом отдельно tabledata, а потом в составе рекурсивного запроса, где к ней идет обращение.Я сказал, что данные выводятся из tabledata, рекурсия неверно работает...ну, мне например было бы интересно посмотреть, нет ли там конструкции RETURN QUERY; или вы, какабычна делают люди, метко охарактеризованные дипломатичнешим дипломатом всех времен и народов -- лаврушкой как "де'Биллы, ять" путаете "LANGUAGE plpgsql" с "LANGUAGE sql" -- там разные структуры отвечают за вывод. Поверьте на слово. а как работает рекурсия можно выяснить безо всякой ф--ии. если нужен параметр-другой -- PREPARE + EXECUTE -- наше всё. ... |
| 09.02.2016, 12:21 |
RECURSIVE function
AsewСобственно вопрос в следующем коллеги по цеху: делаю рекурсивный запрос, в результате запроса на экран ничего не выводится. Т.е. курсор создается в контексте функции, но он пустой. Отдельно проверял tabledata, на экран данные какие-то выводятся...а значит я не так сформировал рекурсию. Прошу прокомментировать. Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. -- отформатировал ... |
| 09.02.2016, 12:23 |
RECURSIVE function
qwwqAsew, "Ни мне, Сара, здравствуйте, ни тебе, Сара, до свидания" (сс) а где шапка ф--ии, и что сказано "во первыз строках ея письма" ? ))) ... |
| 09.02.2016, 12:59 |
start [/forum/topic.php?fid=53&gotonew=1&tid=1997453]: |
23ms |
164ms |
51ms |
| others: | 227ms |
| total: | 503ms |
