PostgreSQL упал после неправильной авторизации
Версия 9.4 б ОС : CentOS Лог : 016-02-21 21:22:34 GET DETAIL: Connection matched pg_hba.conf line 83: "host all all ::1/128 md5" .... .... 2016-02-21 21:22:37 GET DETAIL: Connection matched pg_hba.conf line 83: "host all all ::1/128 md5" 2016-02-21 21:22:37 GET FATAL: password authentication failed for user "postgres" 2016-02-21 21:22:37 GET DETAIL: Connection matched pg_hba.conf line 83: "host all all ::1/128 md5" 2016-02-21 21:22:37 GET LOG: CreateProcess call failed: A blocking operation was interrupted by a call to WSACancelBlockingCall. (error code 299) 2016-02-21 21:22:37 GET LOG: could not fork new process for connection: No error 2016-02-21 21:22:37 GET LOG: incomplete startup packet 2016-02-21 21:22:38 GET FATAL: password authentication failed for user "postgres" 2016-02-21 21:22:38 GET DETAIL: Connection matched pg_hba.conf line 83: "host all all ::1/128 md5" 2016-02-21 21:22:42 GET FATAL: password authentication failed for user "postgres" 2016-02-21 21:22:42 GET DETAIL: Connection matched pg_hba.conf line 83: "host all all ::1/128 md5" 2016-02-21 21:24:26 GET LOG: could not receive data from client: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full. 2016-02-21 21:24:26 GET LOG: incomplete startup packet 2016-02-21 21:24:29 GET FATAL: password authentication failed for user "postgres" 2016-02-21 21:24:45 GET PANIC: could not write to log file 000000010000000100000041 at offset 4259840, length 8192: Invalid argument 2016-02-21 21:24:45 GET STATEMENT: COMMIT 2016-02-21 21:24:53 GET LOG: server process (PID 470944) was terminated by exception 0xC0000409 2016-02-21 21:24:53 GET DETAIL: Failed process was running: COMMIT 2016-02-21 21:24:53 GET HINT: See C include file "ntstatus.h" for a description of the hexadecimal value. 2016-02-21 21:24:53 GET LOG: terminating any other active server processes Конфиги : PostgreSQL.conf: is : Код: plsql 1. 2. 3. 4. 5. pg_hba.conf is : # IPv4 local connections: Код: sql 1. 2. помогите разобраться пожалуйста ... |
| 23.02.2016, 17:52 |
вы уточните, у вас centos или windows ? ... |
| 23.02.2016, 18:29 |
Oleg Bartunovвы уточните, у вас centos или windows ? Извиняюсь ошибка , ОС - Windows ... |
| 23.02.2016, 18:40 |
NewBie77, а версия какая? «Версия 9.4» недостаточно, напишите полную версию. ... |
| 23.02.2016, 21:22 |
ЁшNewBie77, а версия какая? «Версия 9.4» недостаточно, напишите полную версию. там 9.4 , без 9.4.х . Ночью собераюсь перейти на 9.4.6 но не уверен что поможет ... |
| 23.02.2016, 21:46 |
Вопрос решили? ... |
| 26.02.2016, 08:48 |
start [/forum/topic.php?fid=53&gotonew=1&tid=1997399]: |
174ms |
37ms |
| others: | 202ms |
| total: | 463ms |
