Zombies of the future (pgbouncer-1-6)
надо тестить! http://pgbouncer.github.io/2015/08/pgbouncer-1-6/ для себя отметил: https://github.com/pgbouncer/pgbouncer/blob/master/NEWS 2015-08-01 - PgBouncer 1.6 - "Zombies of the future" "Zombies of the future" – * Pooling mode can be configured both per-database and per-user. * Per-database and per-user connection limits: max_db_connections and max_user_connections. * Add DISABLE/ENABLE commands to prevent new connections. * Show remote_pid in SHOW CLIENTS/SERVERS. Available for clients that connect over unix sockets and both tcp and unix socket server. In case of tcp-server, the pid is taken from cancel key. * Add separate config param (dns_nxdomain_ttl) for controlling negative dns caching. * Add the client host IP address and port to application_name. This is enabled by a config parameter application_name_add_host which defaults to 'off'. – * Fix cancellation of of waiting clients. * Don't allow new server connections when PAUSE <db> was issued. – Pavel Stehule Andrew Dunstan Magnus Hagander Heikki Linnakangas Peter Eisentraut Marko Kreen ... ... |
| 03.08.2015, 20:36 |
Misha Tyurin, PgBouncer 1.7.x https://pgbouncer.github.io/changelog.html#pgbouncer-17x "Colors Vary After Resurrection" * Support Host Based Access control file, like pg_hba.conf in Postgres. ... |
| 22.03.2016, 12:57 |
start [/forum/topic.php?fid=53&gotonew=1&tid=1997339]: |
164ms |
| others: | 200ms |
| total: | 417ms |
