Postgresql on RHEL 9.5 is 70% slower than 9.4 and 9.6
Всем привет ! коллеги, наткнулся на письмо в мэйл лист: PG PERFORMANCE mail list We have found that queries through PgBouncer 1.7.2 (with transaction pooling) to local PostgreSQL are almost two times slower in 9.5.3 than in 9.4.8 on RHEL 6 hosts (all packages are updated to last versions). Meanwhile the problem can’t be reproduced i.e. on Ubuntu 14.04 (also fully-updated). Here is how the results look like for 9.4, 9.5 and 9.6. All are built from latest commits on yesterday in * REL9_4_STABLE (a0cc89a28141595d888d8aba43163d58a1578bfb), * REL9_5_STABLE (e504d915bbf352ecfc4ed335af934e799bf01053), * master (6ee7fb8244560b7a3f224784b8ad2351107fa55d). All of them are build on the host where testing is done (with stock gcc versions). Sysctls, pgbouncer config and everything we found are the same, postgres configs are default, PGDATA is in tmpfs. All numbers are reproducible, they are stable between runs. Shortly: OS PostgreSQL version TPS Avg. latency RHEL 6 9.4 44898 1.425 ms RHEL 6 9.5 26199 2.443 ms RHEL 6 9.6 43027 1.487 ms Ubuntu 14.04 9.4 67458 0.949 ms Ubuntu 14.04 9.5 64065 0.999 ms Ubuntu 14.04 9.6 64350 0.995 ms You could see that the difference between major versions on Ubuntu is not significant, but on RHEL 9.5 is 70% slower than 9.4 and 9.6. проверил на centos 7, получил ту же картину : OS PG TPS AVG latency Centos 7 9.5.3 23.711023 168.421 Centos 7 9.5.3 26.609271 150.188 Centos 7 9.5.3 25.220044 158.416 Centos 7 9.5.3 25.598977 156.047 Centos 7 9.4.8 278.572191 14.077 Centos 7 9.4.8 247.237755 16.177 Centos 7 9.4.8 240.007524 16.276 Centos 7 9.4.8 237.862238 16.596 ... |
| 06.06.2016, 11:08 |
djeday84, ох :)) не успел дописать.. Кто знает, когда можно ждать исправлений в 9.5 ? ... |
| 06.06.2016, 11:09 |
djeday84, Вот ссылка на обсуждение: www.postgresql.org/message-id/flat/26239E39-A838-4611-B7BA-0E96D2DF3253@simply.name Пока ничего нет... ... |
| 06.06.2016, 11:55 |
djeday84проверил на centos 7, получил ту же картину обратите внимание, что у вас запросы не R/O скорее всего и результаты тестов отличаются в 10(!!!) раз. ... |
| 07.06.2016, 11:05 |
djeday84djeday84, ох :)) не успел дописать.. Кто знает, когда можно ждать исправлений в 9.5 ? Для начала приведите методику вашего тестирования (так как в --hackers обсуждается взаимодействие через pgbouncer). И сверьте что конфиги у вас одинаковые. В 10 раз разницу можно получить на R/W тесте многими методами (простейший это syncronous_commit on/off на механическом диске). -- Maxim Boguk www.postgresql-consulting.ru ... |
| 07.06.2016, 11:13 |
start [/forum/topic.php?fid=53&gotonew=1&tid=1997188]: |
205ms |
48ms |
| others: | 247ms |
| total: | 557ms |
