free + postgresql
Добрый день. Собираю freeradius на ubuntu, в качестве БД использую postgresql. проблема такая - при использовании только логина и пароля в таблице - radcheck все работает отлично, freeradius -X выдает Accept. при попытке сделать групповые политики (radcheck + radgroupreply + radusergroup) получаем следующее Executing section authorize from file /etc/freeradius/sites-enabled/default +group authorize { ++[preprocess] = ok ++[chap] = noop ++[mschap] = noop ++[digest] = noop [suffix] No '@' in User-Name = "user", looking up realm NULL [suffix] No such realm "NULL" ++[suffix] = noop [eap] No EAP-Message, not doing EAP ++[eap] = noop ++[files] = noop [sql] expand: %{User-Name} -> user [sql] sql_set_user escaped user --> 'user' rlm_sql (sql): Reserving sql socket id: 17 [sql] expand: SELECT id, UserName, Attribute, Value, Op FROM radcheck WHERE Username = '%{SQL-User-Name}' ORDER BY id -> SELECT id, UserName, Attribute, Value, Op FROM radcheck WHERE Username = 'user' ORDER BY id rlm_sql_postgresql: Status: PGRES_FATAL_ERROR rlm_sql_postgresql: Error terminating connection due to administrator command rlm_sql_postgresql: Postgresql Fatal Error: [57P01: ADMIN SHUTDOWN] Occurred!! rlm_sql (sql): Attempting to connect rlm_sql_postgresql #17 rlm_sql (sql): Connected new DB handle, #17 rlm_sql_postgresql: Status: PGRES_TUPLES_OK rlm_sql_postgresql: query affected rows = 1 , fields = 5 [sql] expand: SELECT GroupName FROM radusergroup WHERE UserName='%{SQL-User-Name}' ORDER BY priority -> SELECT GroupName FROM radusergroup WHERE UserName='user' ORDER BY priority rlm_sql_postgresql: Status: PGRES_TUPLES_OK rlm_sql_postgresql: query affected rows = 1 , fields = 1 [sql] expand: SELECT id, GroupName, Attribute, Value, op FROM radgroupcheck WHERE GroupName = '%{Sql-Group}' ORDER BY id -> SELECT id, GroupName, Attribute, Value, op FROM radgroupcheck WHERE GroupName = 'group3' ORDER BY id rlm_sql_postgresql: Status: PGRES_TUPLES_OK rlm_sql_postgresql: query affected rows = 0 , fields = 5 [sql] User found in group group3 [sql] expand: SELECT id, GroupName, Attribute, Value, op FROM radgroupreply WHERE GroupName = '%{Sql-Group}' ORDER BY id -> SELECT id, GroupName, Attribute, Value, op FROM radgroupreply WHERE GroupName = 'group3' ORDER BY id rlm_sql_postgresql: Status: PGRES_TUPLES_OK rlm_sql_postgresql: query affected rows = 1 , fields = 5 rlm_sql (sql): Released sql socket id: 17 ++[sql] = ok ++[expiration] = noop ++[logintime] = noop [pap] WARNING! No "known good" password found for the user. Authentication may fail because of this. ++[pap] = noop +} # group authorize = ok ERROR: No authenticate method (Auth-Type) found for the request: Rejecting the user Failed to authenticate the user. Using Post-Auth-Type Reject # Executing group from file /etc/freeradius/sites-enabled/default +group REJECT { [sql] expand: %{User-Name} -> user [sql] sql_set_user escaped user --> 'user' [sql] expand: %{User-Password} -> 12345678 [sql] expand: INSERT INTO radpostauth (username, pass, reply, authdate) VALUES ('%{User-Name}', '%{%{User-Password}:-Chap-Password}', '%{reply:Packet-Type}', NOW()) -> INSERT INTO radpostauth (username, pass, reply, authdate) VALUES ('user', '12345678', 'Access-Reject', NOW()) rlm_sql (sql) in sql_postauth: query is INSERT INTO radpostauth (username, pass, reply, authdate) VALUES ('user', '12345678', 'Access-Reject', NOW()) rlm_sql (sql): Reserving sql socket id: 16 rlm_sql_postgresql: Status: PGRES_FATAL_ERROR rlm_sql_postgresql: Error terminating connection due to administrator command rlm_sql_postgresql: Postgresql Fatal Error: [57P01: ADMIN SHUTDOWN] Occurred!! rlm_sql (sql): Attempting to connect rlm_sql_postgresql #16 rlm_sql (sql): Connected new DB handle, #16 rlm_sql_postgresql: Status: PGRES_COMMAND_OK rlm_sql_postgresql: query affected rows = 1 rlm_sql (sql): Released sql socket id: 16 ++[sql] = ok [eap] Request didn't contain an EAP-Message, not inserting EAP-Failure ++[eap] = noop [attr_filter.access_reject] expand: %{User-Name} -> user attr_filter: Matched entry DEFAULT at line 11 ++[attr_filter.access_reject] = updated +} # group REJECT = updated Delaying reject of request 7 for 1 seconds ... |
| 17.10.2016, 09:21 |
start [/forum/topic.php?fid=53&gotonew=1&tid=1996937]: |
173ms |
| others: | 215ms |
| total: | 452ms |
