Востановление Barman replication
Ситуация такая: Изучаю постгрю. Протестил на стенде PITR восстановление 9.6 из бэкапа бармена. БД поднялась, все норм. Однако бармен не может запустить репликацию wal. Насколько я понимаю из-за расхождения таймлайн на сервере бд и у себя. 2017-11-14 07:18:02,130 [4730] barman.command_wrappers INFO: db111: pg_receivewal: starting log streaming at 7/2D000000 (timeline 1) 2017-11-14 07:18:02,134 [4730] barman.command_wrappers INFO: db111: pg_receivewal: could not send replication command "START_REPLICATION": pg_receivewal: disconnected 2017-11-14 07:18:02,135 [4730] barman.server ERROR: ArchiverFailure:pg_receivexlog terminated with error code: 1 2017-11-14 07:19:02,153 [4738] barman.wal_archiver INFO: No xlog segments found from streaming for db111. 2017-11-14 07:19:02,170 [4739] barman.server INFO: Starting receive-wal for server db111 2017-11-14 07:19:02,224 [4739] barman.wal_archiver INFO: Synchronous WAL streaming for barman_receive_wal: False 2017-11-14 07:19:02,226 [4739] barman.wal_archiver INFO: Activating WAL archiving through streaming protocol 2017-11-14 07:19:02,263 [4739] barman.command_wrappers INFO: db111: pg_receivewal: starting log streaming at 7/2D000000 (timeline 1) 2017-11-14 07:19:02,269 [4739] barman.command_wrappers INFO: db111: pg_receivewal: could not send replication command "START_REPLICATION": pg_receivewal: disconnected 2017-11-14 07:19:02,270 [4739] barman.server ERROR: ArchiverFailure:pg_receivexlog terminated with error code: 1 Куда его ткнуть шоб он завелся? И еще вопрос, реплику приводят в чувство после восстановления мастера при помощи pg_rewind? ... |
| 14.11.2017, 10:21 |
start [/forum/search_topic.php?author=kab18&author_mode=last_posts&do_search=1]: |
321ms |
29ms |
| others: | 539ms |
| total: | 958ms |
