powered by simpleCommunicator - 2.0.59     © 2025 Programmizd 02
Форумы / PostgreSQL [игнор отключен] [закрыт для гостей] / Backend sent unrecognized response type: u при выполнении процедуры
    #39658968
ASukhov1986
Здравствуйте, в коде программы есть метод на C#:
Код: c#
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
public void ProcOrganisations()
            using (var connection = m_dbSrc.GetConnection())
                using (var transaction = connection.SafeBeginTransaction())
                    using (var command = dbLayer.GetCommand(@"""ProcOrganisations""", connection, transaction))
                        command.CommandType = CommandType.StoredProcedure;
                        command.CommandTimeout = 3600;
                        try
                            command.SafeExecuteNonQuery();
                            transaction.SafeCommit();
                        catch (Exception exception)
                            Lib.HandleException(exception);
                            transaction.SafeRollback();
Тест процедуры ProcOrganisations:
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
CREATE OR REPLACE FUNCTION "ProcOrganisations"()
RETURNS VOID AS $$
DECLARE
    csmRow RECORD;
BEGIN
    FOR csmRow IN (SELECT CSM.CSM_CODE
                   FROM CSM
                     INNER JOIN (SELECT CSM_CODE AS FICT_CSM_CODE
                                 FROM CSM
                                 WHERE DELETE_DATE IS NULL) FICT_CSM
                       ON FICT_CSM.FICT_CSM_CODE=CSM.CSM_CODE
                   ORDER BY PARENT_CODE DESC, CSM_NAME) LOOP
        PERFORM "UpdateUsageReports"(csmRow.csm_code);<---вызов процедуры "UpdateUsageReports"
        PERFORM "SetPastBills"(csmRow.csm_code);<-----вызов процедуры "SetPastBills"
    END LOOP;
END;
$$ LANGUAGE plpgsql;
Тест процедуры "UpdateUsageReports":
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
CREATE OR REPLACE FUNCTION "UpdateUsageReports"(orgId INTEGER)
RETURNS VOID AS $$
DECLARE
    csmRow RECORD;
BEGIN
     FOR csmRow IN (select aaa.*, bill.bill_id
                    from ( select sum(MARK_QTY) as USED_QTY, max(REPORT_DATE) as REPORT_DATE, YEAR, MONTH
			                      from CSM_USAGE_REPORT_ACTUAL
                            where CSM_CODE=orgId
                            group by YEAR, MONTH
                         ) aaa
                      inner join bill on bill.csm_code=orgId and bill.year=aaa.year and bill.month=aaa.month
                    where bill.item_count != aaa.used_qty and bill.type_id=1 and node_id is null) LOOP
           update BILL set ITEM_COUNT=csmRow.USED_QTY, ITEM_RATE=0, AMOUNT=0, OPER_DATE=csmRow.REPORT_DATE where BILL_ID=csmRow.bill_id;
     END LOOP;
     FOR csmRow IN (select sum(MARK_QTY) as USED_QTY, REPORT_DATE, YEAR, MONTH
                    where CSM_CODE=orgId and (MONTH not in (select CSM_USAGE_REPORT_ACTUAL.MONTH
                                                              inner join BILL on CSM_USAGE_REPORT_ACTUAL.YEAR = BILL.YEAR and CSM_USAGE_REPORT_ACTUAL.MONTH = BILL.MONTH and
        CSM_USAGE_REPORT_ACTUAL.CSM_CODE = BILL.CSM_CODE
                                                            where CSM_USAGE_REPORT_ACTUAL.CSM_CODE=orgId) or
                                              YEAR not in (select CSM_USAGE_REPORT_ACTUAL.YEAR
                                                           where CSM_USAGE_REPORT_ACTUAL.CSM_CODE=orgId))
                    group by REPORT_DATE, YEAR, MONTH
                    order by REPORT_DATE) LOOP
           insert into BILL
           (TYPE_ID, ITEM_COUNT, ITEM_RATE, AMOUNT, ITEM_COUNT_REM, YEAR, MONTH, CSM_CODE, OPER_DATE)
			     values (1, csmRow.USED_QTY, 0, 0, 0, csmRow.year, csmRow.month, orgId, csmRow.report_date);
     END LOOP;
     delete from bill
     where bill_id not in ( select distinct bill_id
                            from bill
			                      inner join CSM_USAGE_REPORT_ACTUAL on bill.csm_code=CSM_USAGE_REPORT_ACTUAL.csm_code and
        bill.year=CSM_USAGE_REPORT_ACTUAL.year and
        bill.month=CSM_USAGE_REPORT_ACTUAL.month
     ) and type_id=1 and node_id is null;
END;
Тест процедуры "SetPastBills":
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
CREATE OR REPLACE FUNCTION "SetPastBills"(orgId INTEGER)
RETURNS VOID AS $$
DECLARE
    csmRow RECORD;
    nMarkUsed bigint;
    nItemCount bigint;
BEGIN
     nMarkUsed=(select coalesce(SUM(ITEM_COUNT), 0)
		            from BILL
		            where CSM_CODE=orgId and TYPE_ID=1 and NODE_ID is null);
                    from (select BILL_ID, OPER_DATE, coalesce(sum(END_NO - START_NO + 1), 0) as QTY,
                            case when OPER_DATE < current_date - 90 * interval '1 day' then 1 else 0 end as OVERDUE
                          from BILL
                            inner join MARK_DOC on BILL.SHIPMENT_ID=MARK_DOC.MDOC_ID
                            inner join CSM_INTERVAL on CSM_INTERVAL.MDOC_ID=BILL.SHIPMENT_ID
                          where NODE_ID is NULL and CSM_INTERVAL.CSM_CODE=orgId
                          group by bill_id, oper_date) aaa
                    order by OPER_DATE) LOOP
           nItemCount = csmRow.QTY;
          IF (nMarkUsed > nItemCount) THEN
             nMarkUsed = nMarkUsed - nItemCount;
          ELSE
             nItemCount = nItemCount - nMarkUsed;
	           nMarkUsed = 0;
          END IF;
          IF (nMarkUsed <= 0 and nItemCount > 0 and csmRow.OVERDUE = 1) THEN
               update BILL set TYPE_ID=2, ITEM_COUNT=nItemCount,AMOUNT=ITEM_RATE*nItemCount where BILL_ID=csmRow.bill_id;
          ELSE
               update BILL set TYPE_ID=NULL where BILL_ID=csmRow.bill_id;
          END IF ;
     END LOOP;
END;
Выполнение на сервере процедуры "ProcOrganisations" осуществляется без ошибок, а в программе с ошибкой:
Backend sent unrecognized response type: P
А иногда перед ней возникает следующее диагностическое сообщение (я запуская программу из среды разработки VS 2008) приведенное на рисунке:
