powered by simpleCommunicator - 2.0.59     © 2025 Programmizd 02
Форумы / PostgreSQL [игнор отключен] [закрыт для гостей] / Можно ли помочь оптимизатору ?
2 сообщений из 2, страница 1 из 1
    #39821594
rinace
Интересный пример работы оптимизатора
Как обычно имеется 2 запроса(отличающиеся только входными параметрами) , с хорошим и не очень временем выполнения.
Запрос 1(быстрый):
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
SELECT "PC_NAME","CUSTOMER_PARTNUMBER","LOTID","REPORTED_VALUE","SHIPMENT_NAME",s."SHIPMENT_DATE", "REPORT_NAME",p."SOITECPARAM_NAME",
"CUSTOMERPARAM_NAME" || ' ' || "TYPE_CALCUL" as "CUSTOMERPARAM_NAME", "SOI_GROUP_PARAMETER", "LOWER_SPEC_LIMIT","UPPER_SPEC_LIMIT"
FROM lot_data l, shipment s, parameters p, shipment_pc sp, pc pc, report_parameters_groups gr
WHERE s."SHIPMENT_ID" = l."SHIPMENT_ID" and p."PARAMETER_ID" = l."PARAMETER_ID" and p."SOITECPARAM_NAME" = gr."SOITECPARAM_NAME" and
s."SHIPMENT_ID" = sp."SHIPMENT_ID" and pc."PC_ID" = sp."PC_ID" and s."SHIPMENT_DATE" >= '2018-11-16' and s."SHIPMENT_DATE" <= '2019-05-15' and pc."PC_NAME" in ('C1161-049-01')
        QUERY PLAN
 Gather  (cost=1270.30..96958.09 rows=8699 width=132) (actual time=1361.072..2096.656 rows=72267 loops=1)
   Workers Planned: 2
   Workers Launched: 2
   ->  Hash Join  (cost=270.30..95062.82 rows=3625 width=132) (actual time=1358.845..2040.379 rows=24089 loops=3)
         Hash Cond: ((p."SOITECPARAM_NAME")::text = (gr."SOITECPARAM_NAME")::text)
         ->  Nested Loop  (cost=234.50..94999.35 rows=3625 width=104) (actual time=1357.937..2018.144 rows=24089 loops=3)
               ->  Hash Join  (cost=234.09..93388.66 rows=3625 width=79) (actual time=1357.907..1907.946 rows=24089 loops=3)
                     Hash Cond: (l."SHIPMENT_ID" = s."SHIPMENT_ID")
                     ->  Parallel Seq Scan on lot_data l  (cost=0.00..83181.67 rows=2649567 width=33) (actual time=0.018..970.644 rows=2118060 loops=3)
                     ->  Hash  (cost=233.99..233.99 rows=8 width=58) (actual time=12.045..12.046 rows=22 loops=3)
                           Buckets: 1024  Batches: 1  Memory Usage: 10kB
                           ->  Nested Loop  (cost=0.84..233.99 rows=8 width=58) (actual time=10.810..12.027 rows=22 loops=3)
                                 ->  Nested Loop  (cost=0.55..200.09 rows=21 width=28) (actual time=0.461..0.609 rows=84 loops=3)
                                       ->  Index Scan using unique_pc on pc  (cost=0.27..8.30 rows=1 width=28) (actual time=0.414..0.415 rows=1 loops=3)
                                             Index Cond: (("PC_NAME")::text = 'C1161-049-01'::text)
                                       ->  Index Only Scan using shipmentpc_idx1 on shipment_pc sp  (cost=0.28..191.58 rows=21 width=8) (actual time=0.045..0.152 rows=84 loops=3)
                                             Index Cond: ("PC_ID" = pc."PC_ID")
                                             Heap Fetches: 4
                                 ->  Index Scan using shipment_pkey on shipment s  (cost=0.28..1.61 rows=1 width=30) (actual time=0.135..0.135 rows=0 loops=252)
                                       Index Cond: ("SHIPMENT_ID" = sp."SHIPMENT_ID")
                                       Filter: (("SHIPMENT_DATE" >= '2018-11-16 00:00:00'::timestamp without time zone) AND ("SHIPMENT_DATE" <= '2019-05-15 00:00:00'::timestamp without time zone))
                                       Rows Removed by Filter: 1
               ->  Index Scan using parameters_idx1 on parameters p  (cost=0.41..0.43 rows=1 width=33) (actual time=0.003..0.003 rows=1 loops=72267)
                     Index Cond: ("PARAMETER_ID" = l."PARAMETER_ID")
         ->  Hash  (cost=20.91..20.91 rows=1191 width=28) (actual time=0.853..0.854 rows=1191 loops=3)
               Buckets: 2048  Batches: 1  Memory Usage: 88kB
               ->  Seq Scan on report_parameters_groups gr  (cost=0.00..20.91 rows=1191 width=28) (actual time=0.009..0.381 rows=1191 loops=3)
 Planning time: 2.358 ms
  Execution time: 2123.327 ms
Запрос 2 (медленный):
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
s."SHIPMENT_ID" = sp."SHIPMENT_ID" and pc."PC_ID" = sp."PC_ID" and s."SHIPMENT_DATE" >= '2019-04-16' and s."SHIPMENT_DATE" <= '2019-05-16' and pc."PC_NAME" in ('C21264-024-03')
        QUERY PLAN
 Nested Loop  (cost=2.09..49060.25 rows=1328 width=132) (actual time=11022.561..11867.253 rows=4176 loops=1)
   ->  Nested Loop  (cost=1.81..48659.05 rows=1328 width=104) (actual time=11022.541..11847.173 rows=4176 loops=1)
         ->  Nested Loop  (cost=1.40..48068.98 rows=1328 width=79) (actual time=11022.513..11834.426 rows=4176 loops=1)
               Join Filter: (s."SHIPMENT_ID" = l."SHIPMENT_ID")
               ->  Nested Loop  (cost=0.84..233.99 rows=1 width=58) (actual time=1.447..1.535 rows=6 loops=1)
                     ->  Nested Loop  (cost=0.55..200.09 rows=21 width=28) (actual time=0.587..0.667 rows=20 loops=1)
                           ->  Index Scan using unique_pc on pc  (cost=0.27..8.30 rows=1 width=28) (actual time=0.519..0.520 rows=1 loops=1)
                                 Index Cond: (("PC_NAME")::text = 'C21264-024-03'::text)
                           ->  Index Only Scan using shipmentpc_idx1 on shipment_pc sp  (cost=0.28..191.58 rows=21 width=8) (actual time=0.065..0.130 rows=20 loops=1)
                                 Heap Fetches: 2
                     ->  Index Scan using shipment_pkey on shipment s  (cost=0.28..1.61 rows=1 width=30) (actual time=0.042..0.042 rows=0 loops=20)
                           Filter: (("SHIPMENT_DATE" >= '2019-04-16 00:00:00'::timestamp without time zone) AND ("SHIPMENT_DATE" <= '2019-05-16 00:00:00'::timestamp without time zone))
               ->  Index Scan using lot_data_pkey on lot_data l  (cost=0.56..47796.17 rows=3106 width=33) (actual time=1961.536..1971.761 rows=696 loops=6)
         ->  Index Scan using parameters_idx1 on parameters p  (cost=0.41..0.43 rows=1 width=33) (actual time=0.002..0.002 rows=1 loops=4176)
   ->  Index Scan using report_parameters_groups_pkey on report_parameters_groups gr  (cost=0.28..0.30 rows=1 width=28) (actual time=0.004..0.004 rows=1 loops=4176)
         Index Cond: (("SOITECPARAM_NAME")::text = (p."SOITECPARAM_NAME")::text)
 Planning time: 1.509 ms
  Execution time: 11868.160 ms
Интересная особенность состоит в том, что в первом плане для доступа к таблице lot_data используется :
Код: plaintext
1.
Parallel Seq Scan on lot_data l  (cost=0.00..83181.67 rows=2649567 width=33) (actual time=0.018.. 970.644  rows=2118060  loops=3 )
во втором плане для доступа к таблице lot_data используется :
Код: plaintext
Index Scan using lot_data_pkey on lot_data l  (cost=0.56..47796.17 rows=3106 width=33) (actual time=1961.536.. 1971.761  rows=696  loops=6 )
В результате получается, что доступ по индексу оказывается более тяжелым , чем последовательное чтение.
Вопросы
1)можно ли в данной ситуации помочь оптимизатору ?
2) Есть подозрение, поподробнее посмотреть статистику pg_stat для таблицы lot_data , на ,что обратить внимание ?
3) Может быть дело вообще не в таблице lot_data ? На , что еще обратить внимание ?
    #39821657
gav21
rinace,
а покажите план с опцией explain (analyze,buffers)
