powered by simpleCommunicator - 2.0.59     © 2025 Programmizd 02
Форумы / PostgreSQL [игнор отключен] [закрыт для гостей] / Как посмотреть Read Queries в отчёте pg_badger?
    #39951847
EgorStr
Добрый день! Хочу посмотреть количество Read Queries в отчёте pgBadger, но там всё по нулям
Настройки логирования в postgresql.conf такие:
Код: plsql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
105.
106.
107.
108.
109.
110.
111.
112.
113.
114.
115.
116.
117.
118.
119.
120.
121.
122.
123.
124.
125.
126.
# ERROR REPORTING AND LOGGING
# - Where to Log -
log_destination = 'stderr'		# Valid values are combinations of
					# stderr, csvlog, syslog, and eventlog,
					# depending on platform.  csvlog
					# requires logging_collector to be on.
# This is used when logging to stderr:
 logging_collector = on		# Enable capturing of stderr and csvlog
					# into log files. Required to be on for
					# csvlogs.
					# (change requires restart)
# These are only used if logging_collector is on:
log_directory = 'log'			# directory where log files are written,
					# can be absolute or relative to PGDATA
log_filename = 'postgresql-%Y-%m-%d_%H%M%S.log'	# log file name pattern,
					# can include strftime() escapes
#log_file_mode = 0600			# creation mode for log files,
					# begin with 0 to use octal notation
#log_truncate_on_rotation = off		# If on, an existing log file with the
					# same name as the new log file will be
					# truncated rather than appended to.
					# But such truncation only occurs on
					# time-driven rotation, not on restarts
					# or size-driven rotation.  Default is
					# off, meaning append to existing files
					# in all cases.
#log_rotation_age = 1d			# Automatic rotation of logfiles will
					# happen after that time.  0 disables.
#log_rotation_size = 10MB		# Automatic rotation of logfiles will
					# happen after that much log output.
					# 0 disables.
# These are relevant when logging to syslog:
#syslog_facility = 'LOCAL0'
#syslog_ident = 'postgres'
#syslog_sequence_numbers = on
#syslog_split_messages = on
# This is only relevant when logging to eventlog (win32):
#event_source = 'PostgreSQL'
# - When to Log -
log_min_messages = debug5		# values in order of decreasing detail:
					#   debug5
					#   debug4
					#   debug3
					#   debug2
					#   debug1
					#   info
					#   notice
					#   warning
					#   error
					#   log
					#   fatal
					#   panic
log_min_error_statement = notice	# values in order of decreasing detail:
					#   debug5
					#   debug4
					#   debug3
					#   debug2
					#   debug1
					#   info
					#   notice
					#   warning
					#   error
					#   log
					#   fatal
					#   panic (effectively off)
# - What to Log -
#debug_print_parse = on
#debug_print_rewritten = on
#debug_print_plan = on
#debug_pretty_print = on
log_checkpoints = on
log_connections = on
log_disconnections = on
log_duration = on
log_min_duration_statement = 1
#log_error_verbosity = default		# terse, default, or verbose messages
#log_hostname = off
log_line_prefix = '%t [%p]: [%l-1] user=%u, db=%d, client=%h'		# special values:
					#   %a = application name
					#   %u = user name
					#   %d = database name
					#   %r = remote host and port
					#   %h = remote host
					#   %p = process ID
					#   %t = timestamp without milliseconds
					#   %m = timestamp with milliseconds
					#   %n = timestamp with milliseconds (as a Unix epoch)
					#   %i = command tag
					#   %e = SQL state
					#   %c = session ID
					#   %l = session line number
					#   %s = session start timestamp
					#   %v = virtual transaction ID
					#   %x = transaction ID (0 if none)
					#   %q = stop here in non-session
					#        processes
					# e.g. '<%u%%%d> '
log_lock_waits = on			# log lock waits >= deadlock_timeout
log_statement = 'all'			# none, ddl, mod, all
#log_replication_commands = off
#log_temp_files = -1			# log temporary files equal or larger
					# than the specified size in kilobytes;
					# -1 disables, 0 logs all temp files
log_timezone = 'Europe/Moscow'
# - Process Title -
#cluster_name = ''			# added to process titles if nonempty
#update_process_title = off
Запускаю pgBadger вот с такими ключами:
perl pgbadger --prefix '%t [%p]: [%l-1] user=%u, db=%d, client=%h' 'C:\Program Files\PostgreSQL\10\data\log\postgresql-2020-04-27_082508.log'
При этом в Read Queries и в Write Queries пусто, хотя в Queries запросы видны.
Что не так с моими настройками?
Модератор: Вложение удалено.
