Установка pgadmin4 на fedora 32
Здравствуйте всем! Пытался установить pgadmin4 на fedora 32, все делал по инструкции. Когда пытаюсь запустить выдает ошибку: [root@localhost fred]# sudo python3 /usr/lib/python3.8/site-packages/pgadmin4-web/setup.py Traceback (most recent call last): File "/usr/lib/python3.8/site-packages/pgadmin4-web/setup.py", line 413, in <module> setup_db() File "/usr/lib/python3.8/site-packages/pgadmin4-web/setup.py", line 347, in setup_db app = create_app() File "/usr/lib/python3.8/site-packages/pgadmin4-web/pgadmin/__init__.py", line 400, in create_app driver.init_app(app) File "/usr/lib/python3.8/site-packages/pgadmin4-web/pgadmin/utils/driver/__init__.py", line 40, in init_app DriverRegistry.load_drivers() File "/usr/lib/python3.8/site-packages/pgadmin4-web/pgadmin/utils/driver/registry.py", line 88, in load_drivers module = import_module(module_name) File "/usr/lib64/python3.8/importlib/__init__.py", line 127, in import_module return _bootstrap._gcd_import(name[level:], package, level) File "<frozen importlib._bootstrap>", line 1014, in _gcd_import File "<frozen importlib._bootstrap>", line 991, in _find_and_load File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 671, in _load_unlocked File "<frozen importlib._bootstrap_external>", line 783, in exec_module File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed File "/usr/lib/python3.8/site-packages/pgadmin4-web/pgadmin/utils/driver/psycopg2/__init__.py", line 19, in <module> import psycopg2 File "/usr/lib64/python3.8/site-packages/psycopg2/__init__.py", line 51, in <module> from psycopg2._psycopg import ( # noqa ImportError: /usr/lib64/python3.8/site-packages/psycopg2/_psycopg.cpython-38-x86_64-linux-gnu.so: undefined symbol: PQencryptPasswordConn psycopg2 вроде установлен. ... |
| 19.05.2020, 17:53:55 |
Python 2 нужен для установки, как гласит всемирная паутина. ... |
| 21.05.2020, 22:07:00 |
не, все не так посмотрите здесь https://github.com/psycopg/psycopg2/issues/1093 ... |
| 21.05.2020, 22:18:31 |
start [/forum/topic.php?fid=53&gotonew=1&tid=1994678]: |
72ms |
42ms |
| others: | 194ms |
| total: | 363ms |
