выборка данных по массиву
Доброго дня. pg 12.5 Может кто то объяснить или ткнуть в доку 1 запрос select cd.* from form f join form_version fv on fv.form_id = f.id join cell_data cd on cd.form_version_from = fv.id where f.template_id = 37201 план Gather (cost=4591.86..3674000.89 rows=1511461 width=32) Workers Planned: 4 -> Parallel Hash Join (cost=3591.86..3521854.79 rows=377865 width=32) Hash Cond: (cd.form_version_from = fv.id) -> Parallel Seq Scan on cell_data cd (cost=0.00..2729816.06 rows=209927406 width=32) -> Parallel Hash (cost=3549.30..3549.30 rows=3405 width=4) -> Nested Loop (cost=82.91..3549.30 rows=3405 width=4) -> Parallel Bitmap Heap Scan on form f (cost=82.48..1104.44 rows=3255 width=4) Recheck Cond: (template_id = 37201) -> Bitmap Index Scan on form_id_templ_idx (cost=0.00..79.96 rows=10090 width=0) Index Cond: (template_id = 37201) -> Index Scan using form_version_form_id_idx on form_version fv (cost=0.43..0.73 rows=2 width=8) Index Cond: (form_id = f.id) 2 запрос select cd.* from cell_data cd where cd.form_version_from = any (array( select fv.id from form f join form_version fv on fv.form_id = f.id where f.template_id = 37201 )) план Index Scan using cell_data_form_version_from_idx on cell_data cd (cost=5605.38..43005.43 rows=305028 width=32) Index Cond: (form_version_from = ANY ($2)) InitPlan 1 (returns $2) -> Gather (cost=1082.91..5604.80 rows=10555 width=4) Workers Planned: 3 -> Nested Loop (cost=82.91..3549.30 rows=3405 width=4) -> Parallel Bitmap Heap Scan on form f (cost=82.48..1104.44 rows=3255 width=4) Recheck Cond: (template_id = 37201) -> Bitmap Index Scan on form_id_templ_idx (cost=0.00..79.96 rows=10090 width=0) Index Cond: (template_id = 37201) -> Index Scan using form_version_form_id_idx on form_version fv (cost=0.43..0.73 rows=2 width=8) Index Cond: (form_id = f.id) В первом запросе seq scan form_version Во втором index scan по fv.form_id Вообще какой механизм\принцип работы оптимизатора в данных случаях не очень понял. Да во втором случае в плане =any($2), но константа это массив, вроде бы ему надо по каждому элементу массива найти запись в form_version. Что можно предпринимать в таких случаях, чтоб направить запрос в индекс? ... |
| 30.07.2021, 09:21:56 |
kliff, 1)для начала покажите explain analyze и посмотрим на оба плана. Потом будем думать как исправлять (если возможно). PS: а индексы по form_version(form_id) и по cell_data(form_version_from) есть? -- Maxim Boguk лучшая поддержка PostgreSQL: dataegret.ru ... |
| 30.07.2021, 13:25:46 |
Maxim Boguk kliff, 1)для начала покажите explain analyze и посмотрим на оба плана. Потом будем думать как исправлять (если возможно). PS: а индексы по form_version(form_id) и по cell_data(form_version_from) есть? -- Maxim Boguk лучшая поддержка PostgreSQL: dataegret.ru про индексы не понял вопроса, они же в плане есть 2го запроса 1 запрос Gather (cost=4592.71..3682545.31 rows=1514989 width=32) (actual time=18223.673..255031.426 rows=1438658 loops=1) Workers Planned: 4 Workers Launched: 4 Buffers: shared hit=117767 read=6240840 dirtied=25 -> Parallel Hash Join (cost=3592.71..3530046.41 rows=378747 width=32) (actual time=18196.286..254861.298 rows=287732 loops=5) Hash Cond: (cd.form_version_from = fv.id) Buffers: shared hit=117767 read=6240840 dirtied=25 -> Parallel Seq Scan on cell_data cd (cost=0.00..2736171.50 rows=210416150 width=32) (actual time=0.261..235621.765 rows=168011932 loops=5) Buffers: shared hit=79263 read=6240837 dirtied=25 -> Parallel Hash (cost=3549.97..3549.97 rows=3419 width=4) (actual time=27.968..27.972 rows=2085 loops=5) Buckets: 16384 Batches: 1 Memory Usage: 608kB Buffers: shared hit=38297 read=3 -> Nested Loop (cost=82.91..3549.97 rows=3419 width=4) (actual time=0.353..27.107 rows=2085 loops=5) Buffers: shared hit=38297 read=3 -> Parallel Bitmap Heap Scan on form f (cost=82.48..1104.44 rows=3255 width=4) (actual time=0.263..3.916 rows=1836 loops=5) Recheck Cond: (template_id = 37201) Heap Blocks: exact=350 Buffers: shared hit=1061 -> Bitmap Index Scan on form_id_templ_idx (cost=0.00..79.96 rows=10090 width=0) (actual time=0.954..0.955 rows=9182 loops=1) Index Cond: (template_id = 37201) Buffers: shared hit=29 -> Index Scan using form_version_form_id_idx on form_version fv (cost=0.43..0.73 rows=2 width=8) (actual time=0.011..0.012 rows=1 loops=9182) Index Cond: (form_id = f.id) Buffers: shared hit=37236 read=3 Planning Time: 4.160 ms Execution Time: 255100.478 ms 2. запрос Index Scan using cell_data_form_version_from_idx on cell_data cd (cost=5610.54..43095.65 rows=305724 width=32) (actual time=37.804..45285.326 rows=1438658 loops=1) Index Cond: (form_version_from = ANY ($2)) Buffers: shared hit=82368 read=18627 dirtied=56 InitPlan 1 (returns $2) -> Gather (cost=1082.91..5609.97 rows=10600 width=4) (actual time=2.049..31.851 rows=10425 loops=1) Workers Planned: 3 Workers Launched: 3 Buffers: shared hit=38299 -> Nested Loop (cost=82.91..3549.97 rows=3419 width=4) (actual time=0.508..26.195 rows=2606 loops=4) Buffers: shared hit=38299 -> Parallel Bitmap Heap Scan on form f (cost=82.48..1104.44 rows=3255 width=4) (actual time=0.408..5.135 rows=2296 loops=4) Recheck Cond: (template_id = 37201) Heap Blocks: exact=283 Buffers: shared hit=1061 -> Bitmap Index Scan on form_id_templ_idx (cost=0.00..79.96 rows=10090 width=0) (actual time=1.265..1.266 rows=9182 loops=1) Index Cond: (template_id = 37201) Buffers: shared hit=29 -> Index Scan using form_version_form_id_idx on form_version fv (cost=0.43..0.73 rows=2 width=8) (actual time=0.008..0.009 rows=1 loops=9182) Index Cond: (form_id = f.id) Buffers: shared hit=37238 Planning Time: 4.459 ms Execution Time: 45367.751 ms ... |
| 02.08.2021, 09:36:50 |
kliff, 1)а какие настройки seq_page_cost / random_page_cost у вас стоят? что то больно резво оно на seq scan переключается где не надо... 2)вообще правильная форма этого запроса это Код: sql 1. 2. 3. 4. 5. 6. 7. попробуйте и пришлите какой план у неё получается (explain analyze). -- Maxim Boguk лучшая поддержка PostgreSQL: dataegret.ru ... |
| 02.08.2021, 09:58:00 |
Maxim Boguk, Параметры оптимизатора были экспериментально выведены на пг 9.5 и потом в таком же виде мигрировали на 12.5 версию seq_page_cost = 0.1 random_page_cost = 0.11 ваш запрос Gather (cost=4592.93..3450201.38 rows=1515557 width=32) (actual time=1481.243..253496.767 rows=1438699 loops=1) Workers Planned: 4 Workers Launched: 4 Buffers: shared hit=126889 read=6234277 dirtied=46 -> Parallel Hash Semi Join (cost=3592.93..3297645.68 rows=378889 width=32) (actual time=1492.398..253269.593 rows=287740 loops=5) Hash Cond: (cd.form_version_from = fv.id) Buffers: shared hit=126889 read=6234277 dirtied=46 -> Parallel Seq Scan on cell_data cd (cost=0.00..2737272.88 rows=210500848 width=32) (actual time=0.058..236090.025 rows=168077706 loops=5) Buffers: shared hit=88367 read=6234277 dirtied=46 -> Parallel Hash (cost=3550.14..3550.14 rows=3423 width=4) (actual time=20.504..20.507 rows=2086 loops=5) Buckets: 16384 Batches: 1 Memory Usage: 608kB Buffers: shared hit=38315 -> Nested Loop (cost=82.91..3550.14 rows=3423 width=4) (actual time=0.348..19.665 rows=2086 loops=5) Buffers: shared hit=38315 -> Parallel Bitmap Heap Scan on form f (cost=82.48..1104.44 rows=3255 width=4) (actual time=0.266..4.732 rows=1837 loops=5) Recheck Cond: (template_id = 37201) Heap Blocks: exact=309 Buffers: shared hit=1064 -> Bitmap Index Scan on form_id_templ_idx (cost=0.00..79.96 rows=10090 width=0) (actual time=0.955..0.955 rows=9187 loops=1) Index Cond: (template_id = 37201) Buffers: shared hit=29 -> Index Scan using form_version_form_id_idx on form_version fv (cost=0.43..0.73 rows=2 width=8) (actual time=0.007..0.008 rows=1 loops=9185) Index Cond: (form_id = f.id) Buffers: shared hit=37251 Planning Time: 5.398 ms Execution Time: 253553.697 ms ... |
| 02.08.2021, 11:04:29 |
kliff, Интересно... а если сделать explain (analyze, costs, buffers, timing) запрос ощущение что 90% времени на работу с диском уходит и скорее всего надо глобально косты править или seq/random page cost поднимать (пропорционально) или parallel_tuple_cost/parallel_setup_cost повышать чтобы оно в параллельное выполнение не скатывалось. Какие у вас кстати значения для parallel_tuple_cost и parallel_setup_cost ? PS: оценки количества строк у базы все верные... значит план строиться из разумных предположений о количестве строк и значит цены каких то участков некорректны если выбирается такой план. -- Maxim Boguk лучшая поддержка PostgreSQL: dataegret.ru ... |
| 02.08.2021, 11:15:16 |
Maxim Boguk, эти параметры не правили потому что в 9.5 этих параметров не было. Сейчас они дефолтные #parallel_tuple_cost = 0.1 # same scale as above #parallel_setup_cost = 1000.0 # same scale as above ... |
| 02.08.2021, 12:38:32 |
Maxim Boguk, повышение parallel_tuple_cost/parallel_setup_cost дало то, что parallel seq_sсan заменился на seq_sсan, стало еще хуже перебрал кучу разных комбинаций seq_page_cost\random_page_cost В районе этих значений set seq_page_cost = 3.1; set random_page_cost = 0.1; запрос переходит на индекс Nested Loop (cost=8473.39..30179095.28 rows=1516150 width=32) (actual time=64.501..964.653 rows=1438998 loops=1) Buffers: shared hit=103340 read=41 dirtied=2 -> HashAggregate (cost=8472.81..8579.00 rows=10619 width=4) (actual time=64.433..68.463 rows=10438 loops=1) Group Key: fv.id Buffers: shared hit=38334 -> Nested Loop (cost=0.86..8446.27 rows=10619 width=4) (actual time=0.153..60.871 rows=10438 loops=1) Buffers: shared hit=38334 -> Index Scan using form_id_templ_idx on form f (cost=0.43..1106.60 rows=10090 width=4) (actual time=0.085..11.469 rows=9189 loops=1) Index Cond: (template_id = 37201) Buffers: shared hit=1067 -> Index Scan using form_version_form_id_idx on form_version fv (cost=0.43..0.71 rows=2 width=8) (actual time=0.004..0.005 rows=1 loops=9189) Index Cond: (form_id = f.id) Buffers: shared hit=37267 -> Index Scan using cell_data_form_version_from_idx on cell_data cd (cost=0.57..2535.17 rows=30601 width=32) (actual time=0.044..0.069 rows=138 loops=10438) Index Cond: (form_version_from = fv.id) Buffers: shared hit=65006 read=41 dirtied=2 Planning Time: 3.999 ms Execution Time: 1017.383 ms ... |
| 02.08.2021, 13:22:16 |
start [/forum/topic.php?fid=53&gotonew=1&tid=1993915]: |
194ms |
43ms |
| others: | 184ms |
| total: | 466ms |
