Ошибка pg_probackup при бэкапе со standby
Настроил бэкап с удаленной машины с standby запустил командой pg_probackup backup --instance=mystandby -j2 --progress -b FULL --compress --stream --delete-expired датафайлы забэкапил нормально, но потом выдал ошибку INFO: Progress: (6777/6779). Process file "base/33535/33635.6" INFO: Progress: (6778/6779). Process file "base/33535/33635.5" INFO: Progress: (6779/6779). Process file "base/25341/25441.1" INFO: Data files are transferred, time elapsed: 7m:51s INFO: wait for pg_stop_backup() INFO: pg_stop backup() successfully executed WARNING: Could not read WAL record at 48/9F1C8C48: invalid record length at 48/9F1C8C48: wanted 24, got 0 INFO: Wait for LSN 48/9F1C8C48 in streamed WAL segment /home/pgbackup_user/backup_db/backups/ordering_prod_slv/R19Q68/database/pg_wal/00000001000000480000009F WARNING: Could not read WAL record at 48/9F1C8C48: invalid record length at 48/9F1C8C48: wanted 24, got 0 WARNING: Could not read WAL record at 48/9F1C8C48: invalid record length at 48/9F1C8C48: wanted 24, got 0 WARNING: Could not read WAL record at 48/9F1C8C48: invalid record length at 48/9F1C8C48: wanted 24, got 0 WARNING: Could not read WAL record at 48/9F1C8C48: invalid record length at 48/9F1C8C48: wanted 24, got 0 WARNING: Could not read WAL record at 48/9F1C8C48: invalid record length at 48/9F1C8C48: wanted 24, got 0 И так пару минут пока не прервал по Ctrl+C WARNING: Could not read WAL record at 48/9F1C8C48: invalid record length at 48/9F1C8C48: wanted 24, got 0 WARNING: Could not read WAL record at 48/9F1C8C48: invalid record length at 48/9F1C8C48: wanted 24, got 0 WARNING: Could not read WAL record at 48/9F1C8C48: invalid record length at 48/9F1C8C48: wanted 24, got 0 ^CERROR: Interrupted during waiting for WAL streaming WARNING: Backup R19Q68 is running, setting its status to ERROR Что-то упустил я в настройке? ... |
| 20.10.2021, 12:34:07 |
Спросите тут github ... |
| 20.10.2021, 13:29:40 |
посмотрите сторону pgBackRest Несколько проще в плане настройки и никаких проблем в бекапе со стендбая. Бекап на с3 и шифрование в комплекте. ... |
| 20.10.2021, 14:22:35 |
Guzya, да, там уже есть такая тема, туда и написал. Правда там нет решения тоже пока ... |
| 20.10.2021, 18:11:58 |
mefman посмотрите сторону pgBackRest Несколько проще в плане настройки и никаких проблем в бекапе со стендбая. Бекап на с3 и шифрование в комплекте. Спасибо за совет, тоже надо попробовать ... |
| 20.10.2021, 18:12:40 |
Судя по всему, это не ошибка, а предупреждение, что еще нет нужного лога, так как master не переключился и не выдал его standby-серверу. Через некоторое время, как только мастер переключит логи, то нужный wal-сегмент приходит на стендбай и бэкап завершается со статусом ОК ... |
| 21.10.2021, 14:10:03 |
start [/forum/topic.php?fid=53&gotonew=1&tid=1993818]: |
192ms |
47ms |
| others: | 235ms |
| total: | 532ms |
