Oracle Forms & Java
Извиняюсь, но еще один вопрос. При выполнении формы в окне Jinitiator получаю: Oracle JInitiator: Version 1.3.1.22 Using JRE version 1.3.1.22-internal Java HotSpot(TM) Client VM User home directory = G:\Documents and Settings\Administrator Proxy Configuration: no proxy JAR cache enabled Location: G:\Documents and Settings\Administrator\Oracle Jar Cache Maximum size: 50 MB Compression level: 0 ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message l: dump classloader list m: print memory usage q: hide console s: dump system properties t: dump thread list x: clear classloader cache 0-5: set trace level to <n> ---------------------------------------------------- Loading http://domain:8889/forms90/java/f90all_jinit.jar from JAR cache proxyHost=null proxyPort=0 connectMode=HTTP, native. Версия апплета Forms: 9.0.4.0 java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.JavaContainer.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) и далее в том же духе Не могли бы вы подсказать, с чем это может быть связано? ... |
| 01.03.2006, 22:18 |
Oracle Forms & Java
Вот последний лог Oracle JInitiator: Version 1.3.1.22 Using JRE version 1.3.1.22-internal Java HotSpot(TM) Client VM User home directory = G:\Documents and Settings\Administrator Proxy Configuration: no proxy JAR cache enabled Location: G:\Documents and Settings\Administrator\Oracle Jar Cache Maximum size: 50 MB Compression level: 0 ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message l: dump classloader list m: print memory usage q: hide console s: dump system properties t: dump thread list x: clear classloader cache 0-5: set trace level to <n> ---------------------------------------------------- Loading http://domain:8889/forms90/java/f90all_jinit.jar from JAR cache Loading http://domain:8889/forms90/webutil/webutil.jar from JAR cache RegisterWebUtil - Loading WebUtil Version 1.0.5 Production Loading http://domain:8889/forms90/webutil/jacob.jar from JAR cache proxyHost=null proxyPort=0 connectMode=HTTP, native. Версия апплета Forms: 9.0.4.0 java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.ButtonItem.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) ... |
| 02.03.2006, 01:48 |
Oracle Forms & Java
Как форум-то запускаешь - из билдера или через браузер? ... |
| 02.03.2006, 11:29 |
Oracle Forms & Java
Посмотри на протоколы HTTP-сервера. Там увидишь, чего не хватает ... |
| 02.03.2006, 12:01 |
Oracle Forms & Java
Форму запускаю из билдера. Про протоколы HTTP сервера не понял. ... |
| 09.03.2006, 21:50 |
Oracle Forms & Java
Металинк говорит, что такое случается при не верной настройке url-а для запуска. Сделай Edit->Preferences->Runtime->Set Default ... |
| 10.03.2006, 13:07 |
Oracle Forms & Java
это говорит лишь о том, что на форме есть некое "зернышко" (JavaBean), implementation class которого апплет найти не может (видимо, забыл указать jar для загрузки) ... |
| 10.03.2006, 15:37 |
Oracle Forms & Java
Да вот вроде как не забыл и все jar'ы webutil'овские прописаны как надо. Со строкой тоже все в порядке, то есть по дефолту билдер проставил то же, что и было. Конфиги: ORACLE - default.env ORACLE_HOME=F:\oracle2\developer904 FORMS90_PATH=F:\oracle2\developer904\forms90;F:\oracle2\webutil\forms WEBUTIL_CONFIG=f:\oracle2\webutil\server\webutil.cfg PATH=F:\oracle2\developer904\bin;f:\oracle2\developer904\jdk\jre\bin\client FORMS90=F:\oracle2\developer904\forms90 CLASSPATH=F:\oracle2\developer904\j2ee\OC4J_BI_Forms\applications\forms90app\forms90web\WEB-INF\lib\f90srv.jar;F:\oracle2\developer904\jlib\repository.jar;F:\oracle2\developer904\jlib\ldapjclnt9.jar;F:\oracle2\developer904\jlib\debugger.jar;F:\oracle2\developer904\jlib\ewt3.jar;F:\oracle2\developer904\forms90\java\f90all_jinit.jar;F:\oracle2\developer904\reports\jlib\rwrun.jar;f:\oracle2\webutil\lib\webutil.jar;f:\oracle2\webutil\lib\jacob.jar;f:\oracle2\developer904\jdk\jre\lib\rt.jar;f:\oracle2\developer904\jlib\debugger.jar;f:\oracle2\developer904\jlib\ewt3.jar;f:\oracle2\developer904\jlib\share.jar;f:\oracle2\developer904\jlib\utj90.jar; ORACLE - forms90.conf AliasMatch ^/forms90/java/(..*) "F:\oracle2\developer904/forms90/java/$1" AliasMatch ^/forms90/jinitiator/(..*) "F:\oracle2\developer904/jinit/$1" AliasMatch ^/forms90/html/(..*) "F:\oracle2\developer904/tools/web90/html/$1" AliasMatch ^/forms90/webutil/(..*) "f:\oracle2/webutil/lib/$1" #Далее стандартно ORACLE - formsweb.cfg webUtilArchive=/forms90/webutil/webutil.jar,/forms90/webutil/jacob.jar [default] baseHTML=f:\oracle2\webutil\server\webutilbase.htm baseHTMLjinitiator=f:\oracle2\webutil\server\webutiljini.htm baseHTMLjpi=f:\oracle2\webutil\server\webutiljpi.htm baseHTMLie=baseie.htm HTMLdelimiter=% workingDirectory= envFile=default.env IE=JInitiator archive_jini=f90all_jinit.jar archive_ie=f90all.cab archive=f90all.jar,f90all_jinit.jar networkRetries=0 jinit_download_page=/forms90/jinitiator/us/jinit_download.htm jinit_classid=clsid:CAFECAFE-0013-0001-0018-ABCDEFABCDEF jinit_exename=jinit.exe#Version=1,3,1,18 jinit_mimetype=application/x-jinit-applet;version=1.3.1.18 jpi_download_page=http://java.sun.com/products/plugin/1.3/plugin-install.html jpi_classid=clsid:8AD9C840-044E-11D1-B3E9-00805F499D93 jpi_codebase=http://java.sun.com/products/plugin/1.3/jinstall-13-win32.cab#Version=1,3,0,0 jpi_mimetype=application/x-java-applet;version=1.3 WEBUTIL - webutil.cfg logging.file= logging.enabled=FALSE logging.errorsonly=FALSE logging.connections=FALSE install.syslib.location=http://domain:8889/forms90/webutil install.syslib.0.7.1=jacob.dll|94208|1.0|true install.syslib.0.9.1=jnisharedstubs.dll|65582|1.0|true install.syslib.0.9.2=d2kwut60.dll|192512|1.0|true transfer.database.enabled=TRUE transfer.appsrv.enabled=FALSE transfer.appsrv.workAreaRoot=f:/oracle2/webutil transfer.appsrv.accessControl=TRUE transfer.appsrv.read.1=f:/oracle2/webutil transfer.appsrv.read.2=c:/ transfer.appsrv.write.1=f:/oracle2/webutil transfer.appsrv.write.2=c:/ WEBUTIL - webutil.env ORACLE_HOME=F:\oracle2\developer904 FORMS90_PATH=F:\oracle2\developer904\forms90 WEBUTIL_CONFIG=f:\oracle2\webutil\server\webutil.cfg PATH=F:\oracle2\developer904\bin;f:\oracle2\developer904\jdk\jre\bin\client CLASSPATH=f:\oracle2\webutil\lib\webutil.jar;f:\oracle2\webutil\lib\jacob.jar;f:\oracle2\developer904\jlib\debugger.jar;f:\oracle2\developer904\jlib\ewt3.jar:f:\oracle2\developer904\jlib\share.jar;f:\oracle2\developer904\jlib\utj90.jar;f:\oracle2\developer904\jdk\jre\lib\rt.jar Кроме того обстоятельства, что CLASSPATH в default.env превышает 512 символов, ничего подозрительного не вижу. ... |
| 10.03.2006, 19:44 |
Oracle Forms & Java
Неужели ни у кого не возникало проблем с настройкой webutil? ... |
| 18.03.2006, 20:54 |
Oracle Forms & Java
heavenmasterНеужели ни у кого не возникало проблем с настройкой webutil?А почему подозрения пали на webutil? Простая форма, без webutil, запускается нормально? ... |
| 20.03.2006, 12:06 |
Oracle Forms & Java
Угу. А что еще может быть? ... |
| 29.03.2006, 21:35 |
Oracle Forms & Java
попробуй так --- в файле ORACLE - formsweb.cfg строку webUtilArchive=/forms90/webutil/webutil.jar,/forms90/webutil/jacob.jar перенеси в самый конец и ещё [default] .... .... и исправь !!!!!!!! archive_jini=f90all_jinit.jar => archive_jini=f90all_jinit.jar,webutil.jar !!!!!!!!! ...... - вроде больше ничего не вижу... ... |
| 08.07.2006, 02:48 |
start [/forum/topic.php?fid=51&gotonew=1&tid=1879310]: |
101ms |
61ms |
| others: | 255ms |
| total: | 481ms |
