список значений из БД в Oracle Forms 6i
Как можно заполнить список ListItem значениями из БД? ... |
| 18.12.2008, 09:56 |
счас нашел вот чего - пригодится? Note: As an alternative to defining list item values at design time, you can also add list elements individually at runtime by using the ADD_LIST_ELEMENT built-in subprogram, or you can populate the list from a record group at runtime using the POPULATE_LIST built-in. If you populate the list from a record group, be sure that the record group you are using to populate the list contains the relevant values before you call POPULATE_LIST. If the record group is a static record group, it will already contain the appropriate values. Otherwise, you should populate the group at runtime using one of the record group subprograms. ... |
| 18.12.2008, 11:10 |
POP_LIST('CLSS_MILITARY_ACCOUNT', 'PARAM_VIEW.MILITARY', null); PROCEDURE POP_LIST (gr_name in varchar2, item_name in varchar2, regim in number) IS rg_name varchar2(50); rg_id RecordGroup; errcode number; status number; list_id item; list_name varchar2(50); str varchar2(4000); BEGIN rg_name := UPPER(RTRIM(gr_name)); list_name := UPPER(RTRIM(item_name)); list_id := FIND_ITEM(list_name); CLEAR_LIST(list_id); If rg_name = 'CLSS_MILITARY_ACCOUNT' then str := 'select vcname, TO_CHAR(iCLSS_MILITARY_ACCOUNTid) from CLSS_MILITARY_ACCOUNT order by 1'; Elsif rg_name = 'TYPE_DOC' then str := 'select vcdocument_name, TO_CHAR(idocument_typeid) from document_type order by isort asc'; end if; rg_id := FIND_GROUP(rg_name); if Id_Null(rg_id) then rg_id := CREATE_GROUP_FROM_QUERY(rg_name, str); else DELETE_GROUP_ROW(rg_id, ALL_ROWS); DELETE_GROUP(rg_id); rg_id := CREATE_GROUP_FROM_QUERY(rg_name, str); end if; errcode := POPULATE_GROUP(rg_id); POPULATE_LIST(list_id, rg_id); END; ... |
| 18.12.2008, 11:24 |
start [/forum/topic.php?fid=51&gotonew=1&tid=1879159]: |
148ms |
44ms |
| others: | 221ms |
| total: | 447ms |
