Ошибка в Oracle Forms
TYPE T_STRING_TABLE IS TABLE OF VARCHAR2(32767); Имеется процедура, PROCEDURE LIST(P_CONN IN OUT NOCOPY UTL_TCP.CONNECTION, P_DIR IN VARCHAR2, P_LIST OUT T_STRING_TABLE) AS -- -------------------------------------------------------------------------- L_CONN UTL_TCP.CONNECTION; L_LIST T_STRING_TABLE := T_STRING_TABLE(); L_REPLY_CODE VARCHAR2(3) := NULL; BEGIN L_CONN := GET_PASSIVE(P_CONN); SEND_COMMAND(P_CONN, 'LIST ' || P_DIR, TRUE); BEGIN LOOP L_LIST.EXTEND; L_LIST(L_LIST.LAST) := UTL_TCP.GET_LINE(L_CONN, TRUE); DEBUG(L_LIST(L_LIST.LAST)); IF L_REPLY_CODE IS NULL THEN L_REPLY_CODE := SUBSTR(L_LIST(L_LIST.LAST), 1, 3); END IF; IF SUBSTR(L_REPLY_CODE, 1, 1) IN ('4', '5') THEN RAISE_APPLICATION_ERROR(-20000, L_LIST(L_LIST.LAST)); ELSIF (SUBSTR(G_REPLY(G_REPLY.LAST), 1, 3) = L_REPLY_CODE AND SUBSTR(G_REPLY(G_REPLY.LAST), 4, 1) = ' ') THEN EXIT; END IF; END LOOP; EXCEPTION WHEN UTL_TCP.END_OF_INPUT THEN NULL; END; L_LIST.DELETE(L_LIST.LAST); P_LIST := L_LIST; UTL_TCP.CLOSE_CONNECTION(L_CONN); GET_REPLY(P_CONN); END; при обращении к ней в блоке DECLARE CONN UTL_TCP.CONNECTION; L_LIST FTP.T_STRING_TABLE; PATTERN OWA_TEXT.VC_ARR; BEGIN CONN := FTP.LOGIN(...); FTP.LIST(CONN, './OUT', L_LIST); IF L_LIST.COUNT > 0 THEN ... END IF; END; В Oracle Forms возникае ошибка ORA-06531 - Reference to uninitialized collection, при этом в PL/SQL Developer все отрабатывает. ??? ... |
| 05.05.2009, 14:21 |
start [/forum/topic.php?fid=51&gotonew=1&tid=1879133]: |
136ms |
44ms |
| others: | 246ms |
| total: | 482ms |
